GPencil: Material filter is not working in modifiers #76594
Closed
opened 2020-05-09 20:55:40 +02:00 by Vyacheslav Kobozev · 13 comments
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.59
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-05-06 16:18, hash: 9605c26166
Modifier work with material only when filter inverted. If it is intended, it is higly counter-intuitive. But I am sure it is a bug.
untitled1.blend
2020-05-09_21-50-17.mp4
**System Information** Operating system: Windows-7-6.1.7601-SP1 64 Bits Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.59 **Blender Version** Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-05-06 16:18, hash: `9605c26166` Worked: (newest version of Blender that worked as expected) **Short description of error** Modifier work with material only when filter inverted. If it is intended, it is higly counter-intuitive. But I am sure it is a bug. [untitled1.blend](https://archive.blender.org/developer/F8523599/untitled1.blend) ![37084154.jpg](https://archive.blender.org/developer/F8523606/37084154.jpg) [2020-05-09_21-50-17.mp4](https://archive.blender.org/developer/F8523595/2020-05-09_21-50-17.mp4)
Added subscriber: @Vyach
Antonio Vazquez self-assigned this 2020-05-10 10:08:02 +02:00
It looks the material filter is not working. I can reproduce it.
Added subscribers: @JulianEisel, @ideasman42
@ideasman42 @JulianEisel I have found a very weird bug in the prop_search function.
Here it' s an extract of the code I have in python:
row.prop_search(md, "material", gpd, "materials", text="", icon='SHADING_TEXTURE')
row.prop_search(md, "vertex_group", ob, "vertex_groups", text="")
And this is the Panel... looks carefully to Material... there is a extra blank in front.
{F8525463}
And here is what I have in the variable (set by RNA).
prop = RNA_def_property(srna, "material", PROP_STRING, PROP_NONE);
RNA_def_property_string_sdna(prop, NULL, "materialname");
RNA_def_property_ui_text(prop, "Material", "Material name");
RNA_def_property_update(prop, 0, "rna_GpencilModifier_update");```
![image.png](https://archive.blender.org/developer/F8525466/image.png)
You can see the name of the material is " Green", not "Green" as expected....
And this is the Data:
![image.png](https://archive.blender.org/developer/F8525469/image.png)
As you can see, something is happening in `prop_search`
@ideasman42 @JulianEisel I have found a very weird bug in the `prop_search` function. Here it' s an extract of the code I have in python: ```row.prop_search(md, "layer", gpd, "layers", text="", icon='GREASEPENCIL') row.prop_search(md, "material", gpd, "materials", text="", icon='SHADING_TEXTURE') row.prop_search(md, "vertex_group", ob, "vertex_groups", text="") ``` And this is the Panel... looks carefully to Material... there is a extra blank in front. {F8525463} And here is what I have in the variable (set by RNA). ``` ``` prop = RNA_def_property(srna, "material", PROP_STRING, PROP_NONE); RNA_def_property_string_sdna(prop, NULL, "materialname"); RNA_def_property_ui_text(prop, "Material", "Material name"); RNA_def_property_update(prop, 0, "rna_GpencilModifier_update");``` ``` ![image.png](https://archive.blender.org/developer/F8525466/image.png) You can see the name of the material is " Green", not "Green" as expected.... And this is the Data: ![image.png](https://archive.blender.org/developer/F8525469/image.png) As you can see, something is happening in `prop_search`
The strange is that this problem is only with Materials, but not with Layers or Vertex groups that use the same code logic.
Antonio Vazquez changed title from Grease pencil modifiers: material filter works inverted to GPencil: Material filter is not working in modifiers 2020-05-10 10:32:44 +02:00
Member
Data-blocks (materials are data-blocks, GPencil layers and vertex groups are not) get a 3 character prefix to indicate their linking state and user-count, see https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/lib_id.c$2092-2109.
This is done for all search menu templates and shouldn't be an issue. The issue probably lies somewhere else.
Data-blocks (materials are data-blocks, GPencil layers and vertex groups are not) get a 3 character prefix to indicate their linking state and user-count, see https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/lib_id.c$2092-2109. This is done for all search menu templates and shouldn't be an issue. The issue probably lies somewhere else.
Proposed fix: D7681
Proposed fix: [D7681](https://archive.blender.org/developer/D7681)
@JulianEisel What is your plan here?
We have 3 options:
  1. I can do a quick hack and solve it for 2.83. In 2.90 I can apply the D7681 fix.
  2. You can apply your quick fix to prop_search.
  3. We can apply D7681 now to 2.83.
I don't like too much the option 3), so IMHO it's better apply solution 1) or 2) to 2.83 and apply the correct fix with pointer (D7681) in 2.90.
@JulianEisel What is your plan here? We have 3 options: 1) I can do a quick hack and solve it for 2.83. In 2.90 I can apply the [D7681](https://archive.blender.org/developer/D7681) fix. 2) You can apply your quick fix to `prop_search`. 3) We can apply [D7681](https://archive.blender.org/developer/D7681) now to 2.83. I don't like too much the option 3), so IMHO it's better apply solution 1) or 2) to 2.83 and apply the correct fix with pointer ([D7681](https://archive.blender.org/developer/D7681)) in 2.90.
Member
I'm just doing some final checking, but will commit my quick 2.83 fix in a moment. D7681 can go into 2.90 then.
I'm just doing some final checking, but will commit my quick 2.83 fix in a moment. [D7681](https://archive.blender.org/developer/D7681) can go into 2.90 then.
Member
Member
Committed 249ccab111 for the 2.83 release. @antoniov also committed d63956d0e5, which fixes this specific issue too, but is too unsafe for 2.83. It does however fix the case of duplicated data-block names due to linking/library-overrides.
Thanks @JulianEisel I have tested and the problem is solved in 2.83 and also solved in the right way in 2.90.
Reference: blender/blender#76594
