The overlay for bone ik limits has visual artifacts #77803
Closed
opened 2020-06-12 16:30:47 +02:00 by Ramón Grill · 15 comments
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: 211b6c29f7
Worked: 2.82.7
The sphere that is drawn in the 3D viewport after you select a bone with ik limits has visual artifacts. As far as I can tell, this always happens and requires no special reproduction steps besides creating an armature bone with ik limits enabled under the 'Bone Properties' panel.
Out of curiosity, I took a look at the code. The cause appears to be, that the shader, which is used to the draw the lines of the ik limit overlay, is also used for drawing the sphere. The shader (armature_wire_frag.glsl) does antialiasing for lines, which causes artifacts when it is used for not-lines.
Create an armature with at least 2 bones. Then select a bone and enable ik limits on the x and z axis.
ik_overlay_bug.blend
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14 **Blender Version** Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: `211b6c29f7` Worked: 2.82.7 **Short description of error** The sphere that is drawn in the 3D viewport after you select a bone with ik limits has visual artifacts. As far as I can tell, this always happens and requires no special reproduction steps besides creating an armature bone with ik limits enabled under the 'Bone Properties' panel. Out of curiosity, I took a look at the code. The cause appears to be, that the shader, which is used to the draw the lines of the ik limit overlay, is also used for drawing the sphere. The shader (armature_wire_frag.glsl) does antialiasing for lines, which causes artifacts when it is used for not-lines. ![image.png](https://archive.blender.org/developer/F8622365/image.png) **Exact steps for others to reproduce the error** Create an armature with at least 2 bones. Then select a bone and enable ik limits on the x and z axis. [ik_overlay_bug.blend](https://archive.blender.org/developer/F8611588/ik_overlay_bug.blend)
Author
Added subscriber: @ramon_grill
Added subscriber: @mano-wii
Member
Added subscriber: @Jeroen-Bakker
Member
Seems like it draws into the lineTex buffer with alpha 0.
It does draw the solids to the linesTex and colorTex. and afterwards the outline is drawn on top. When drawing the solids it should not effect the lineTex.
Seems like it draws into the lineTex buffer with alpha 0. ![lineTex.png](https://archive.blender.org/developer/F8624378/lineTex.png) ![lineTex.jpg](https://archive.blender.org/developer/F8624387/lineTex.jpg) It does draw the solids to the linesTex and colorTex. and afterwards the outline is drawn on top. When drawing the solids it should not effect the lineTex.
This issue was referenced by 17ddb4c4ea
This issue was referenced by 17ddb4c4ea0f68a7f4c38f54291ec641deb6f1f9
This issue was referenced by e54058b121
This issue was referenced by e54058b1212202f5386ab53336e32ed01c441126
Jeroen Bakker self-assigned this 2020-06-16 10:20:41 +02:00
Member
Author
I retested this on the latest daily build and the sphere is now invisible. It does obscure other overlays, so something is being rendered.
version: 2.90.0 Alpha, branch: master, commit date: 2020-06-19 13:42, hash: 59b523c3c9, type: Release
build date: 2020-06-19, 12:31:39
I retested this on the latest daily build and the sphere is now invisible. It does obscure other overlays, so *something* is being rendered. ![Annotation 2020-06-19 191348.png](https://archive.blender.org/developer/F8632330/Annotation_2020-06-19_191348.png) version: 2.90.0 Alpha, branch: master, commit date: 2020-06-19 13:42, hash: 59b523c3c98e, type: Release build date: 2020-06-19, 12:31:39
Added subscriber: @fclem
Changed status from 'Resolved' to: 'Confirmed'
@Jeroen-Bakker you need to make sure the shader still writes to the lineTex buffer. Otherwise it's Undefined behavior. I overlooked that in the patch.
This issue was referenced by e553408bee
This issue was referenced by e553408bee693d7cbff1b359af330f4963d2db12
This issue was referenced by 0aa7c11788
This issue was referenced by 0aa7c1178851cce79202e007bfab017ff0be5eab
Member
5 Participants
Reference: blender/blender#77803
