Properties Search Implementation #77824
Closed
opened 2020-06-13 01:45:36 +02:00 by Hans Goudey · 20 comments
Member
Status: In polishing phase
Team
Commissioner: @WilliamReynish
Project leader: @HooglyBoogly
Big picture: Method to filter properties in the properties editor, but general enough to use elsewhere too
Use cases:
  • A general way to find that one setting you always lose track of
  • In more complicated situations, a faster way to navigate to a property than to scroll to and expand the relevant panels
Design:
#71185
Engineer plan:
Two new "passes" will be needed:
  1. A filter for buttons that don't match the filter at the end of the layout code,
  2. A "simple layout" pass, which runs a simpler version of the layout code for panels in all tabs to highlight the ones with active items.
    It would also be conceivable to build the property search layout during the same pass as the regular layout code,
    but there are a few downsides to that method, mostly in the added complexity to the regular layout code.
Work plan
Milestone 1 - Poperty Search and Panels
Time estimate: A week or two
  • Search filter
    • RNA property buttons
    • Operator buttons
    • Search based on label buttons
    • Menu buttons
    • Box buttons
    • Add some fuzziness to the matching (D9145)
  • Highlighting and dimming of buttons
    • Highlight on panel headers
    • Highlight on subpanel label text
    • Dimming of icons_only=True buttons (e.g., lock)
    • Highlight button labels
  • Interaction with panels
    • Search closed panels and their subpanels
    • Change panel expansion
      • Auto expand matching panels and subpanels (and collapse others)
      • Revert expansion to before search (keep changes where user interacted) (D8984)
    • Panels animate as the search changes
    • Match entire panel if panel label matches search
  • Make pin button work in header
  • ctrl-F to activate search box
    • alt-F to clear seach box
Milestone 2 - Highlight Tabs with Filtered Items
  • Duplicate the properties editor and run the search
    • Get search to run
    • Store "has property" per tab
    • Fix all consequences of duplicating the space / memory leaks
  • Add the ability to gray out some icons to tabs layout
  • Investigate performance
  • ? Switch to the next highlighted tab if the current tab is empty
Milestone 3 - Performance
Time estimate: About a week
  • ? Use ghash instead of string lookups
  • ? Look into using ED_region_tag_redraw_no_rebuild for some interactions
Branch: master
**Status:** In polishing phase --- **Team** **Commissioner:** @WilliamReynish **Project leader:** @HooglyBoogly **Description** **Big picture:** Method to filter properties in the properties editor, but general enough to use elsewhere too **Use cases**: * A general way to find that one setting you always lose track of * In more complicated situations, a faster way to navigate to a property than to scroll to and expand the relevant panels **Design:** #71185 **Engineer plan:** Two new "passes" will be needed: 1. A filter for buttons that don't match the filter at the end of the layout code, 2. A "simple layout" pass, which runs a simpler version of the layout code for panels in all tabs to highlight the ones with active items. It would also be conceivable to build the property search layout during the same pass as the regular layout code, but there are a few downsides to that method, mostly in the added complexity to the regular layout code. **Work plan** **Milestone 1 - Poperty Search and Panels** Time estimate: *A week or two* - [x] Search filter - [x] RNA property buttons - [x] Operator buttons - [x] Search based on label buttons - [x] Menu buttons - [x] Box buttons - [ ] Add some fuzziness to the matching ([D9145](https://archive.blender.org/developer/D9145)) - [x] Highlighting and dimming of buttons - [x] Highlight on panel headers - [x] Highlight on subpanel label text - [x] Dimming of icons_only=True buttons (e.g., lock) - [x] Highlight button labels - [x] Interaction with panels - [x] Search closed panels and their subpanels - [x] Change panel expansion - [x] Auto expand matching panels and subpanels (and collapse others) - [ ] Revert expansion to before search (keep changes where user interacted) ([D8984](https://archive.blender.org/developer/D8984)) - [x] Panels animate as the search changes - [x] Match entire panel if panel label matches search - [x] Make pin button work in header - [x] ctrl-F to activate search box - [x] alt-F to clear seach box **Milestone 2 - Highlight Tabs with Filtered Items** Time estimate: *A week* - [x] Duplicate the properties editor and run the search - [x] Get search to run - [x] Store "has property" per tab - [x] Fix all consequences of duplicating the space / memory leaks - [x] Add the ability to gray out some icons to tabs layout - [x] Investigate performance - [x] `?` Switch to the next highlighted tab if the current tab is empty **Milestone 3 - Performance** Time estimate: About a week - [ ] `?` Use ghash instead of string lookups - [ ] `?` Look into using `ED_region_tag_redraw_no_rebuild` for some interactions **Branch**: `master`
Hans Goudey self-assigned this 2020-06-13 01:45:36 +02:00
Author
Member
Author
Member
Added subscribers: @HooglyBoogly, @WilliamReynish
Added subscriber: @DuarteRamos
Added subscriber: @ManuelGrad
This comment was removed by @manuelgrad1
*This comment was removed by @manuelgrad1*
Contributor
Added subscriber: @RedMser
This issue was referenced by a550937116
This issue was referenced by a55093711644f1a87eb058d2bed20d530a4de155
This issue was referenced by 67e630609b
This issue was referenced by 67e630609bb408e366398cb7ea9fdc09f31190e7
This issue was referenced by 6b29c3fa07
This issue was referenced by 6b29c3fa07f54a0b0d123a90049fbad36a1334c2
This issue was referenced by f59ce4d55c
This issue was referenced by f59ce4d55c04a61a10d9e9567b53ee652972b60a
This issue was referenced by 8bcdcab659
This issue was referenced by 8bcdcab659fb688d976a50d892dcb4285ff2a180
This issue was referenced by bedbd8655e
This issue was referenced by bedbd8655ed1d331aeaf756874c46dbed93168a1
Added subscriber: @Vyach
Thanks a lot for seach through addon list! It helps a lot now!
I use many addons and disabled some of them to keep workspace clean.
So search allow to switch em easier.
Thanks a lot for seach through addon list! It helps a lot now! I use many addons and disabled some of them to keep workspace clean. So search allow to switch em easier.
Author
Member
Thanks for mentioning that. I'm glad it helps!
This issue was referenced by 96dd299055
This issue was referenced by 96dd299055a1ce35819480f3c4b938f8e6f91537
This issue was referenced by 7c633686e9
This issue was referenced by 7c633686e99512d33391f30e4602213ed3890802
This issue was referenced by 54da72d3cd
This issue was referenced by 54da72d3cd546ecbd2560d7d57cbed33064bbee1
Author
Member
Author
Member
#82236 contains some follow-up improvements
Thomas Dinges added this to the 2.92 milestone 2023-02-08 16:16:04 +01:00
6 Participants
Reference: blender/blender#77824
