Adjust Last Operation: Other changes outside that panel are reverted back automatically #78171
Open
opened 2020-06-23 19:35:39 +02:00 by Vyacheslav Kobozev · 35 comments
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-22 22:06, hash: 51bf04383a
Here the demo and file
2020-06-23_20-30-11.mp4
Scene state reset.blend
  1. Add some objects, add last one
  2. Change visibility for other objects via outliner
  3. Change property in adjustment popup
  4. Scene settings resetted to previous
**System Information** Operating system: Windows-7-6.1.7601-SP1 64 Bits Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87 **Blender Version** Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-22 22:06, hash: `51bf04383a` Worked: (newest version of Blender that worked as expected) **Short description of error** Here the demo and file [2020-06-23_20-30-11.mp4](https://archive.blender.org/developer/F8639389/2020-06-23_20-30-11.mp4) [Scene state reset.blend](https://archive.blender.org/developer/F8639397/Scene_state_reset.blend) **Exact steps for others to reproduce the error** 1. Add some objects, add last one 2. Change visibility for other objects via outliner 3. Change property in adjustment popup 4. Scene settings resetted to previous
Added subscriber: @Vyach
#103647 was marked as duplicate of this issue
#102239 was marked as duplicate of this issue
#96006 was marked as duplicate of this issue
#91038 was marked as duplicate of this issue
#92398 was marked as duplicate of this issue
#89460 was marked as duplicate of this issue
#88642 was marked as duplicate of this issue
#88224 was marked as duplicate of this issue
#85705 was marked as duplicate of this issue
#81370 was marked as duplicate of this issue
#80615 was marked as duplicate of this issue
#58839 was marked as duplicate of this issue
#63915 was marked as duplicate of this issue
Vyacheslav Kobozev changed title from Scene state reset during changing property for new object to Scene`s state resets during changing property for new object 2020-06-23 21:35:32 +02:00
Member
Added subscribers: @WilliamReynish, @JulianEisel, @ideasman42, @lichtwerk
Member
Member
I think this is a general issue with Redo/Adjust Last Operation (but this could very well be a design limitation atm):
A similar issue also came up in #73302, see, my reply there #73302#856078
The Adjust Last Operation panel stays as long as you dont execute another operator. Change visibility for other objects via outliner [or basically any setting in the property editor] is not an operator (if it was another operator, the panel would close), so this panel stays open. Doing adjustments in this panel then will hop back in the undo stack, so changes done to settings after the operator execution get wiped again.
Not sure if this can easily be done, but I would propose to just close the Adjust Last Operation panel upon unrelated [non-operator] property changes, which should get rid of this confusion.
I assume this is not a bug, but maybe something the User Interface team can comment upon [or close if this is not considered to be changed anytime soon]?
Will update the tilte to reflect my findings.
CC @JulianEisel
CC @ideasman42
CC @WilliamReynish
I think this is a general issue with Redo/Adjust Last Operation (but this could very well be a design limitation atm): A similar issue also came up in #73302, see, my reply there #73302#856078 The Adjust Last Operation panel stays as long as you dont execute another **operator**. Change visibility for other objects via outliner [or basically any setting in the property editor] is not an **operator** (if it was another **operator**, the panel would close), so this panel stays open. Doing adjustments in this panel then will hop back in the undo stack, so changes done to settings after the operator execution get wiped again. Not sure if this can easily be done, but I would propose to just close the Adjust Last Operation panel upon unrelated [non-operator] property changes, which should get rid of this confusion. I *assume* this is not a bug, but maybe something the User Interface team can comment upon [or close if this is not considered to be changed anytime soon]? Will update the tilte to reflect my findings. CC @JulianEisel CC @ideasman42 CC @WilliamReynish
Philipp Oeser changed title from Scene`s state resets during changing property for new object to Operator Redo/Adjust Last Operation: panel stays open, changes to unrelated properties (done after operator execution) will get undone when changing properties in the panel again 2020-06-24 11:40:26 +02:00
Member
This is indeed a design limitation/issue, not a bug.
We could clear the undo registry when doing the undo push for a button, removing the panel:
diff --git a/source/blender/editors/interface/interface_handlers.c b/source/blender/editors/interface/interface_handlers.c
index 3f3f0513184..305bcd1eb0f 100644
    - a/source/blender/editors/interface/interface_handlers.c
+++ b/source/blender/editors/interface/interface_handlers.c
@@ -946,6 +946,7 @@ static void ui_apply_but_funcs_after(bContext *C)
ui_afterfunc_update_preferences_dirty(&after);
if (after.undostr[0]) {
+      WM_operator_stack_clear(CTX_wm_manager(C));
 ED_undo_push(C, after.undostr);
diff --git a/source/blender/editors/interface/interface_region_hud.c b/source/blender/editors/interface/interface_region_hud.c
index 1f8af7b9e6e..c02047fef94 100644
    - a/source/blender/editors/interface/interface_region_hud.c
+++ b/source/blender/editors/interface/interface_region_hud.c
@@ -231,11 +231,27 @@ static void hud_region_draw(const bContext *C, ARegion *region)
+static void hud_region_listener(wmWindow *UNUSED(win),
+                                ScrArea *UNUSED(area),
+                                ARegion *region,
+                                wmNotifier *wmn,
+                                const Scene *UNUSED(scene))
+  switch (wmn->category) {
+    case NC_WM:
+      if (wmn->data == ND_HISTORY) {
+        ED_region_tag_redraw(region);
+      break;
 ARegionType *ED_area_type_hud(int space_type)
ARegionType *art = MEM_callocN(sizeof(ARegionType), func);
art->regionid = RGN_TYPE_HUD;
art->keymapflag = ED_KEYMAP_UI | ED_KEYMAP_VIEW2D;
+  art->listener = hud_region_listener;
art->layout = hud_region_layout;
art->draw = hud_region_draw;
art->init = hud_region_init;
This is quite a design change though, not sure if it's a good idea.
This is indeed a design limitation/issue, not a bug. We *could* clear the undo registry when doing the undo push for a button, removing the panel: ``` lines=10 diff --git a/source/blender/editors/interface/interface_handlers.c b/source/blender/editors/interface/interface_handlers.c index 3f3f0513184..305bcd1eb0f 100644 - a/source/blender/editors/interface/interface_handlers.c +++ b/source/blender/editors/interface/interface_handlers.c @@ -946,6 +946,7 @@ static void ui_apply_but_funcs_after(bContext *C) ``` ui_afterfunc_update_preferences_dirty(&after); ``` ``` if (after.undostr[0]) { ``` + WM_operator_stack_clear(CTX_wm_manager(C)); ``` ED_undo_push(C, after.undostr); } } ``` diff --git a/source/blender/editors/interface/interface_region_hud.c b/source/blender/editors/interface/interface_region_hud.c index 1f8af7b9e6e..c02047fef94 100644 - a/source/blender/editors/interface/interface_region_hud.c +++ b/source/blender/editors/interface/interface_region_hud.c @@ -231,11 +231,27 @@ static void hud_region_draw(const bContext *C, ARegion *region) ``` } ``` } +static void hud_region_listener(wmWindow *UNUSED(win), + ScrArea *UNUSED(area), + ARegion *region, + wmNotifier *wmn, + const Scene *UNUSED(scene)) +{ + switch (wmn->category) { + case NC_WM: + if (wmn->data == ND_HISTORY) { + ED_region_tag_redraw(region); + } + break; + } +} + ARegionType *ED_area_type_hud(int space_type) { ``` ARegionType *art = MEM_callocN(sizeof(ARegionType), __func__); art->regionid = RGN_TYPE_HUD; art->keymapflag = ED_KEYMAP_UI | ED_KEYMAP_VIEW2D; ``` + art->listener = hud_region_listener; ``` art->layout = hud_region_layout; art->draw = hud_region_draw; art->init = hud_region_init; ``` ``` This is quite a design change though, not sure if it's a good idea.
Member
Added subscribers: @gadic, @demmordor, @iss, @SonicBlue, @ZedDB
Julian Eisel changed title from Operator Redo/Adjust Last Operation: panel stays open, changes to unrelated properties (done after operator execution) will get undone when changing properties in the panel again to Adjust Last Operation: Changes in Outliner are reverted back automatically 2020-06-26 18:48:16 +02:00
Member
Added subscriber: @user1
Philipp Oeser changed title from Adjust Last Operation: Changes in Outliner are reverted back automatically to Adjust Last Operation: Other changes outside that panel are reverted back automatically 2020-09-11 18:21:50 +02:00
Member
Added subscriber: @3di
Added subscriber: @LostSense
Added subscriber: @JerBot
Member
Added subscriber: @Benni334
Added subscriber: @SergeyIvanov
Member
To be clear what I explained above would mean that after changing the object visibility, or any other (non-UI) setting, the Adjust Last Operation panel would disappear.
So it makes something impossible that was sort of possible before (editing operator properties after changing object visibility, or render settings or such), but it would behave unexpected and apparently broken. Users may not even notice that their changes were undone. I find that quite bad.
So maybe we should do what I suggested for 3.0. Curious what others think, e.g. what do you think @ideasman42?
To be clear what I explained above would mean that after changing the object visibility, or any other (non-UI) setting, the *Adjust Last Operation* panel would disappear. So it makes something impossible that was sort of possible before (editing operator properties after changing object visibility, or render settings or such), but it would behave unexpected and apparently broken. Users may not even notice that their changes were undone. I find that quite bad. So maybe we should do what I suggested for 3.0. Curious what others think, e.g. what do you think @ideasman42?
Member
Added subscriber: @ephraimpauli
Member
Added subscriber: @Geposs
Added subscribers: @XDroid-3, @mano-wii, @PratikPB2123
Member
Added subscriber: @blenderrocket
Member
This looks identical to #96006 (The Replacement of Outliner Histories on use of Redo panel)
Can me merge these reports in either way?
This looks identical to #96006 (The Replacement of Outliner Histories on use of Redo panel) Can me merge these reports in either way?
Member
would merge into this one
> In #78171#1440351, @PratikPB2123 wrote: > This looks identical to #96006 (The Replacement of Outliner Histories on use of Redo panel) > Can me merge these reports in either way? would merge into this one
Member
Added subscriber: @toki46-3
Member
Added subscriber: @Luciano
Member
Added subscriber: @gfxcoder
Philipp Oeser removed the
label 2023-02-10 09:24:22 +01:00
9 Participants
Reference: blender/blender#78171
