Cannot import PLY file generated by Rhinos3D 6.0 #78278
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
6 Participants
Reference: blender/blender-addons#78278
Operating system: Ubuntu 18
Graphics card: Integrated Intel
Broken: 2.79b
Blender can not open a PLY file exported from Rhinos 6.0. Here the file: https://github.com/cnr-isti-vclab/meshlab/files/3330082/Box.ply.zip
When run through console, it reports:
I checked with a hex editor, and the end_header line is there. Maybe there is a problem with carriage return vs newline?
Open Blender from a terminal/console. Import into Blender the file linked above. Check the output in the terminal.
Related:
https://github.com/cnr-isti-vclab/meshlab/issues/463
https://github.com/google/draco/issues/613
Added subscriber: @ferdymercury
Added subscriber: @lichtwerk
Will confirm for now, apparently there is an issue with line termination, yes.
Not sure if it is against the specs, but using
line in plyf
[plyf is open(filepath, 'rb')] will not separate lines properly.Tried using
plyf.read().splitlines()
- that separates them properly - but has issues later on.Needs more investigation...
Thanks. In case it helps, Meshlab uses the following chars as possible separators:
" \t\n\r"
a8e87662b6/wrap/ply/plylib.cpp (L987)
Added subscriber: @jesterking
FWIW: current stable version of Rhino is v6 (SR 27 I believe).
Importing the PLY file into Rhino v6, then re-exporting as PLY, then importing in Blender works just fine. Also an export from a clean Rhino file (with just that a box) work just fine.
Even a complex model exported as PLY with Rhino 6 imports fine in Blender (2.83.1)
box_v6.ply
box_from_v3_reexported.ply
Thanks. The files you provided are in ASCII format, whereas the original one is in binary format. Can you see if you can select the export option as binary in 6? Otherwise we do not know if the bug is still there in 6.0. Thanks!
Right, binary format indeed fails.
Upon a bit further inspection it turns out the PLY file you provided is exported with Rhino 6.
So binary PLY also fails in 2.83.1
Added subscriber: @rjg
This comment was removed by @rjg
Cannot import PLY file generated by Rhinos 3.0to Cannot import PLY file generated by Rhinos 6.0Cannot import PLY file generated by Rhinos 6.0to Cannot import PLY file generated by Rhinos3D 6.0Thanks Nathan. Sorry, I had a mind shortcut and transformed Rhinos3D 6.0 to Rhinos 3.0. Indeed, it is Rhinos 6.0 the original file.
Concerning line endings:
https://www.graphics.rwth-aachen.de/media/openmesh_static/Documentations/OpenMesh-5.2-Documentation/a00002.html
https://github.com/PointCloudLibrary/pcl/issues/1256
https://github.com/dranjan/python-plyfile
Added subscriber: @mont29
Boils down to python expecting only
\n
as newline char in binary files... Truing to work around the issue currently, but it's a bit tricky :|Note that it would fail as well with a text version of it if it was not using
\n
as return char.This issue was referenced by
04c0573ee7
