2.83 shader editor mouse wheel zoom performance regression #78495
Reference: blender/blender#78495
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 451.48
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash:
211b6c29f7
Worked: 2.82 and earlier
In 2.83, there is unsettling, noticeable input lag when zooming in and out in shader editor using mouse wheel. When zooming using hotkey combination (smoothly) there is no difference, but when zooming using mouse wheel, the difference is noticeable. The lag is not present there in 2.82 and earlier.
Result: Zooming in and out in shader editor in 2.83 has noticeable lag/delay.
Expected: Zooming in and out in shader editor performs as well as it did in 2.82 and earlier.
Here is link to a video recorded at 240FPS and encoded at 60FPS (25% speed):
https://www.youtube.com/watch?v=clXM-gPvgvk
It's clearly visible that the zooming framerate is much worse in 2.83 in the identical scene. What's interesting is that it applies only to mouse wheel initiated zoom specifically.
Added subscriber: @Rawalanche
Added subscriber: @iss
I can not reproduce this issue.
Does this happen with default file and when you click on File > Defaults > Load Factory Settings?
Yes, it does. Are you testing on Windows or Linux? Also, keep in mind the video is slowed down from 240 to 60FPS, so you won't actually see as much difference, but you can feel it if you keep zooming in and out using mouse wheel only rapidly.
I am quite sure that if you are on Windows, you are able to reproduce it but you aren't sensitive enough to lag to be able to tell. Regardless, it appears the mouse wheel zooming framerate is at least half of what it used to be in 2.82 (with factory default settings). So some profiling is in order.
I suggest you try to launch both at once, and place the windows next to each other like on the video. It's easier to feel/stop if you can switch between them rapidly and compare immediately.
I am testing on windows, and I can not feel any difference.
That is exactly what I did
Does this happen when you hold down ctrl + middle mouse button and move mouse up and down in shader editor?
To be sure we compare same scenario as you report, please specify what software you used to record video at what settings, and upload example .blend file with ideally visibly bad performance.
What's actually needed here is for someone to profile the execution time of the function responsible for zooming in shader editor using mouse wheel in both 2.82 and 2.83, and then compare the resulting execution times. Then I am pretty sure 2.83 will be less than half of 2.82.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
No difference there in my case unfortunately.
0586-0770.mp4
Does this happen if you collapse all other editors?
Actually I can see the difference even here! I assume 2.83 is on the right, as that one is visibly more choppy. You are just not zooming in and out fast enough. It needs to be really rapid to spot the lag. Meaning the the mouse wheel should make at least 10 "increment clicks" per second for it to be really visible (Of course assuming you are recording at high framerate and encoding the video slowed down so you can really see it).
But even on this video, you can see that the left one, 2.82 does about 2x more redraws than 2.83.
EDIT: Here is a realtime video of roughly how fast I was zooming in and out in that video I then slowed down to 25%:
2020-07-07 08-48-59.mp4
I can feel the lag even in real time, but when it comes to actual visibility, without holding mouse in your hand (so you can actually show it to others), then the video needs to be slowed down. But you can feel it in real time if you zoom in and out rapidly enough. It feels kinda like "mouse smoothing" that used to be an option in really old FPS shooter games.
I slowed down my footage to 24fps instead 60 so it is slower.
Even if I tested this with precisely timed mouse events and discovered 2ms slowdown for zoom, I wouldn't assumed this is a bug. Before this could be even investigated we first need developer that can reproduce regression at least similar to what you report.
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Any news? Does this issue remain in 3.3 bets?: https://builder.blender.org/download/daily
