Blender crashes/closes when clicking a workspace tab (that is in fullscreen in a second window) #78688
Closed
opened 2020-07-06 21:28:44 +02:00 by Sebastien Larocque · 6 comments
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92
Broken: version: 2.83.1, branch: master, commit date: 2020-06-25 09:47, hash: 8289fc688b
Blender crashes/closes when clicking the “Modeling” tab.
This bug is very particular and you really need to use the attached project to be able to reproduce it.
  • Open the attached Blender project file “Bug_BlenderClosesSuddenly_TwoWindows.blend”
  • There will be two windows. This project has the main window (with the “Shading” tab active) opened on the main monitor and a second window opened on a second monitor extended to the right.
  • Click the “Modeling” tab. At this point, all Blender windows disappear.
This project used to have a few of objects with shaders and a shader for the World. Everything worked correctly for many days until today. I cleaned all the unnecessary objects to isolate the bug.
One symptom about the problem is if you close the secondary window and you click the “Modeling” tab, the content of the “Modeling” tab becomes whatever is present in the secondary window. Blender does not crash in that case.
That happened a few times in the past. It is not the first time I encounter a situation where Blender closes suddenly, but I could not know why and I was not able to reproduce the problem. Blender has already closed suddenly when doing something in version 2.83 and probably other versions since 2.8.
Edit: Sorry, I made a mistake when adding a comment to my report. Just keep in mind that there is probably something corrupted into the UI. Opening the project by unchecking “Load UI” clears all these problems.
**System Information** Operating system: Windows-10-10.0.18362-SP0 64 Bits Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92 **Blender Version** Broken: version: 2.83.1, branch: master, commit date: 2020-06-25 09:47, hash: `8289fc688b` **Short description of error** Blender crashes/closes when clicking the “Modeling” tab. **Exact steps for others to reproduce the error** This bug is very particular and you really need to use the attached project to be able to reproduce it. * Open the attached Blender project file “Bug_BlenderClosesSuddenly_TwoWindows.blend” * There will be two windows. This project has the main window (with the “Shading” tab active) opened on the main monitor and a second window opened on a second monitor extended to the right. * Click the “Modeling” tab. At this point, all Blender windows disappear. This project used to have a few of objects with shaders and a shader for the World. Everything worked correctly for many days until today. I cleaned all the unnecessary objects to isolate the bug. One symptom about the problem is if you close the secondary window and you click the “Modeling” tab, the content of the “Modeling” tab becomes whatever is present in the secondary window. Blender does not crash in that case. That happened a few times in the past. It is not the first time I encounter a situation where Blender closes suddenly, but I could not know why and I was not able to reproduce the problem. Blender has already closed suddenly when doing something in version 2.83 and probably other versions since 2.8. Edit: Sorry, I made a mistake when adding a comment to my report. Just keep in mind that there is probably something corrupted into the UI. Opening the project by unchecking “Load UI” clears all these problems. [Bug_BlenderClosesSuddenly_TwoWindows.blend](https://archive.blender.org/developer/F8670622/Bug_BlenderClosesSuddenly_TwoWindows.blend)
Added subscriber: @SebBlender
Member
Added subscribers: @JulianEisel, @lichtwerk
Member
Member
Can confirm, crashes because the second window is in fullscreen - was in Modeling previously as well - (crash does not happen when you leave fullscreen in the second window prior to switching to Modeling workspace in the first window)
Blender cannot find the layout and wants to print a screen name for a screen that is not there (screen_change_prepare returns NULL)...
1  __strlen_avx2                                         0x7ffff041d557
2  __vfprintf_internal                                   0x7ffff03289ee
3  buffered_vfprintf                                     0x7ffff0329a2c
4  __vfprintf_internal                                   0x7ffff0326a94
5  printf                                                0x7ffff031343f
6  BKE_workspace_layout_find      workspace.c       305  0x31f9798
7  ED_workspace_change            workspace_edit.c  158  0x3a2d506
8  WM_window_set_active_workspace wm_window.c       2426 0x3363983
9  wm_event_do_notifiers          wm_event_system.c 431  0x332c425
10 WM_main                        wm.c              478  0x3327e49
11 main                           creator.c         532  0x2eea41e
Crash can be prevented by the following (but switching to Modeling workspace still doesnt work then)
P1508: T78688_snippet
diff --git a/source/blender/blenkernel/intern/workspace.c b/source/blender/blenkernel/intern/workspace.c
index 4625fd76293..82cdc5abd84 100644
--- a/source/blender/blenkernel/intern/workspace.c
+++ b/source/blender/blenkernel/intern/workspace.c
@@ -307,7 +307,7 @@ WorkSpaceLayout *BKE_workspace_layout_find(const WorkSpace *workspace, const bSc
       "This should not happen!\n",
       __func__,
       workspace->id.name + 2,
-      screen->id.name + 2);
+      screen ? screen->id.name + 2 : "Unknown");
   return NULL;
CC @JulianEisel
Can confirm, crashes because the second window is in fullscreen - was in `Modeling` previously as well - (crash does not happen when you leave fullscreen in the second window prior to switching to `Modeling` workspace in the first window) Blender cannot find the layout and wants to print a screen name for a screen that is not there (`screen_change_prepare` returns NULL)... ``` 1 __strlen_avx2 0x7ffff041d557 2 __vfprintf_internal 0x7ffff03289ee 3 buffered_vfprintf 0x7ffff0329a2c 4 __vfprintf_internal 0x7ffff0326a94 5 printf 0x7ffff031343f 6 BKE_workspace_layout_find workspace.c 305 0x31f9798 7 ED_workspace_change workspace_edit.c 158 0x3a2d506 8 WM_window_set_active_workspace wm_window.c 2426 0x3363983 9 wm_event_do_notifiers wm_event_system.c 431 0x332c425 10 WM_main wm.c 478 0x3327e49 11 main creator.c 532 0x2eea41e ``` Crash can be prevented by the following (but switching to `Modeling` workspace still doesnt work then) [P1508: T78688_snippet](https://archive.blender.org/developer/P1508.txt) ``` diff --git a/source/blender/blenkernel/intern/workspace.c b/source/blender/blenkernel/intern/workspace.c index 4625fd76293..82cdc5abd84 100644 --- a/source/blender/blenkernel/intern/workspace.c +++ b/source/blender/blenkernel/intern/workspace.c @@ -307,7 +307,7 @@ WorkSpaceLayout *BKE_workspace_layout_find(const WorkSpace *workspace, const bSc "This should not happen!\n", __func__, workspace->id.name + 2, - screen->id.name + 2); + screen ? screen->id.name + 2 : "Unknown"); return NULL; } ``` CC @JulianEisel
Philipp Oeser changed title from Blender crashes/closes when clicking the “Modeling” tab to Blender crashes/closes when clicking a workspace tab (that is in fullscreen in a second window) 2020-07-07 12:09:08 +02:00
This issue was referenced by 304767dcd3
This issue was referenced by 304767dcd3459d222d8c6011e913840df74a6cd5
Member
Julian Eisel self-assigned this 2020-08-04 20:12:31 +02:00
Reference: blender/blender#78688
