Library overrides - modifiers #79635
Closed
opened 2020-08-08 07:08:44 +02:00 by Facundo · 8 comments
Graphics card: GeForce GTX 960M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
system-info.txt
Broken: version: 2.90.0 Beta, branch: master, commit date: 2020-08-02 18:54, hash: 0264f53e30
There are some actions you can do with modifiers from a linked file (with library override), which maybe they shouldn't be allowed. There is also a crash.
  • Open up Blender, take for example the default cube and add a mirror modifier.
  • Save the file to disk.
  • Create a new file and remove the default cube.
  • Go to File->Link, select the saved file, and choose the collection of the cube.
  • Make it into Library Override (Object->Relations->Make library override)
  • Select the cube of the linked file, and in the properties panel go to the Modifiers Tab.
  • You'll see the mirror modifier, the X button in the UI is disabled (cannot be removed), but you can actually remove it by pressing Delete or X keys on the keyboard.
  • If you hover the mouse over the modifier, and press Ctrl+A (shortcut for applying), Blender crashes.
  • If you add more modifiers, you can move the mirror modifier (which was added in the original file) up and down, but you cannot move it to First or Last in the stack from the UI menu (I don't know if it should be allowed to move it).
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 960M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87 [system-info.txt](https://archive.blender.org/developer/F8757967/system-info.txt) ![Captura.PNG](https://archive.blender.org/developer/F8757968/Captura.PNG) **Blender Version** Broken: version: 2.90.0 Beta, branch: master, commit date: 2020-08-02 18:54, hash: `0264f53e30` Worked: (newest version of Blender that worked as expected) **Short description of error** There are some actions you can do with modifiers from a linked file (with library override), which maybe they shouldn't be allowed. There is also a crash. **Exact steps for others to reproduce the error** - Open up Blender, take for example the default cube and add a mirror modifier. - Save the file to disk. - Create a new file and remove the default cube. - Go to File->Link, select the saved file, and choose the collection of the cube. - Make it into Library Override (Object->Relations->Make library override) - Select the cube of the linked file, and in the properties panel go to the Modifiers Tab. - You'll see the mirror modifier, the X button in the UI is disabled (cannot be removed), but you can actually remove it by pressing Delete or X keys on the keyboard. - If you hover the mouse over the modifier, and press Ctrl+A (shortcut for applying), Blender crashes. - If you add more modifiers, you can move the mirror modifier (which was added in the original file) up and down, but you cannot move it to First or Last in the stack from the UI menu (I don't know if it should be allowed to move it).
Author
Added subscriber: @Facu
Added subscriber: @mano-wii
I confirm the crash and the possibility to delete the modifier using shortcuts.
Added subscriber: @mont29
Bastien Montagne self-assigned this 2020-08-11 19:02:37 +02:00
None of those shortcuts should be active (operator poll functions should prevent them to run...) only valid operations are adding new modifiers, and moving them around.
I will consider this one as fixed for now, at least as best as possible. Note that one cannot move around any modifier in liboverride object now, but this is a limitation with current system that needs design and refactor work, and is therefore outside of the scope of a bug report. See #79735 (Enhance ways of accessing active modifier for poll functions of operators)
Thomas Dinges added this to the 2.90 milestone 2023-02-08 16:25:41 +01:00
Reference: blender/blender#79635
