Particle system and drivers #79771
Reference: blender/blender#79771
Operating system: Windows 10 version 10.0.19041
Graphics card: NVIDIA GeForce RTX 2080
2.83.2
When use a driver in a particle system the particle system doesn't react to driver value change
Look at the attached example.
animation drivers.blend
Added subscriber: @3D_modelling
Added subscriber: @dr.sybren
Changed status from 'Confirmed' to: 'Needs User Info'
@3D_modelling Could you please spend some time trimming down the example file? There are multiple objects that may or may not influence the result, there are multiple particle systems, and all of that is probably just noise.
I've tried to reproduce the issue with a smaller file, but there the particle system responds just fine to a driver. I tried with a file created in 2.79 as well as the current development version (master branch @
948e080fc5
).minimal-example-279.blend
created-in-current-master.blend
@dr.sybren Thank you for the investigation.
Here my test in a blank file:
https://youtu.be/FQGD0ropJmY
Result file is attached. I use 2.83.2 on Windows 10
particle system and driver.blend
Added subscriber: @Nikolaysungreen
There is no problem with the first pass. On the first pass, the particle system reacts to driver changes. But on the first pass of the animation, a cache is formed, which is not updated later if the driver changes.
Ah, so the problem is not as described (driver not working), but the problem is that the cache system is caching too much?
The particle system's cache is only invalidated on manual changes, and not on changes of the driver's value -- Blender doesn't see the difference between "a driver changing value" and "a driver changing value but to a different value than it was the last time it played that frame".
The particle simulation system is marked "End of Life". This means that recently-introduced bugs may be fixed, but apart from that no changes are made.
