Mantaflow rendering unstable (when using multiple fluid domains) #80154
7 Participants
Reference: blender/blender#80154
Operating system: Ubuntu 18.04
Graphics card: Radeon R9 FURY
Broken: 2.83.5
Worked: none
Mantaflow seems unstable during rendering of 6 simultaneous domains and it relates to the cycles AA samples.
The error it shows:
Render Animation
Added subscriber: @Rabit
Looks like it's happening during animation rendering once per ~150 frames, still trying to figure out the minimal configuration.
Ok, just reproduced the issue on a simple blend file and default blender 2.83.5 . Will reproduce one more time from nothing and will attach the steps to reproduce and the file.
Simple test blend file: mantaflow-render-test.blend
Steps to reproduce:
Render Animation
Added subscriber: @Raimund58
Hello Guys, anyone could reproduce? @Raimund58
Added subscriber: @sebbas
@Rabit Are you able to get a crash with the latest daily build too?
Blender 2.83.5 just crashed for me. Where do I find the logs?
So, I checked recently released 2.90 - even worse it crashed on 2th step "baking" (5th domain bake, 215 frame):
Restarted blender and restarted 5th domain baking, it's going significantly (2-3 times) slower from 4th domain bake - and failed again on 180 frame. So I can't even reproduce the previous 2.83.5 steps.
On 2.83.5 (left domain to right):
Next I switched to 2.90 to render with baked caches from 2.83.5:
So in 2.90 we have another issue with baking the example blend file, as well as with the rendering.
@Raimund58 The logs I posted is right in the stderr/stdout of blender - just check it's system console (on windows) or run it directly from the console.
@Rabit Just had my first crash - it took some time as you mentioned already. Will look into this now.
@Rabit Could you still try and see if you can get a crash with a daily build: https://builder.blender.org/download/
I had my crash with 2.90 too. It would be interesting to know if the issue is present in 2.91 as well.
I just tested the latest blender-2.91.0-ba188e721899-linux64 build:
Warnings during baking:
Baking domains 2nd pass (left to right):
Fresh baked caches render:
So it looks quite the same as for 2.83.5 - but I did not catch the failure during 2 passes of baking as for 2.90 version.
@Rabit Thanks a lot for all the tests! I also got some more crashes in my tests, it looks like this is an issue in general when having multiple domains in the scene.
Investigating this ..
Mantaflow rendering unstableto Mantaflow rendering unstable (when using multiple fluid domains)Just found another thing with baking on 2.90 - if I'm changing the initial fuel level (0-1.3 bezier) for example and not starting from 1.3 - it's dissolving before reaching top of the domain, than it probably will not fail. Not sure how it's related, but maybe it's a workaround for now - just make sure the fire particles not reaching the domain limits.
Added subscriber: @VGSymphony
I still have an issue with baking in 2.92 with multiple domains. Any update on the bug?
Added subscriber: @ankitm
I confirmed a report with same error with simpler steps and reliable crash in #87828 (Mantaflow error when using blender in background mode). There's also an assert hit there.
Keeping this open since steps to redo are very different.
Added subscriber: @evantryan
Mantaflow (fluid simulator) has no active developer at the moment. Moving those bugs as known issues so at least other users can find their issues already reported.
