Blender freezing in the Viewport edit mode for couple of seconds when selecting faces / edges / vertices or entering edit mode #80632
Reference: blender/blender#80632
Operating system: Windows 10 (Bootcamp on MacBook Pro 15 - 2015)
Graphics card: AMD Radeon R9 M370X with latest drivers
Using external display with non-hdpi resolution
Broken: v2.83.5
When modeling in a viewport, Blender freezes for couple of seconds before it starts running smoothly again. This happens very often when trying to select vertices / edges / face or when switching between edit and object mode.
I recorded a video showing the issue. In order to avoid any interference on the computer I used my phone. It is not loud enough but at 0:01 I left-lick to select the face. Between 0:01 and 0:04 the viewport view is completely frozen and only at 0:04 it unfreezes again. However all inputs are registered during that freeze time so if I click again or use some shortcut, the changes will also appear after the view unfreezes.
viewportfreeze.m4v
Added subscriber: @MirekDusin
Blander freezing in Viewport edit mode for couple of seconds when selecting faces / edges / vertices or entering edit modeto Blender freezing in the Viewport edit mode for couple of seconds when selecting faces / edges / vertices or entering edit modeAdded subscriber: @iss
Please download latest build from https://builder.blender.org/download/ and check if this is still an issue.
If I understand this correctly, there is no crash, only UI stops responding for few seconds?
Hello, seems like the latest version have the same problem.
And yes, only the UI freezes, otherwise the Blender is stable, does not crash.
Does this happen if you click on File > Defaults > Load Factory Settings, load file and perform test?
Ok, so it seems there might be some problem in the file I´m working with. With the default settings there was no UI freeze. I'm trying to figure out what would cause it. The file however was started around the time when 2.8 Blender was launched, so I wonder if that alone can be the cause.
Can you upload startup file so we can have a look?
Factory settings also disables all non-default addons, I would suspect issue would be there.
Oh, sorry if I explained it wrong. I meant that the startup file worked without any UI freezing, but the original file I was working on had that freezing happening. Here is the original file.
FurnitureWorkshop_v28.blend
I don't have any problems with that file.
I still need to know answer to: Does this happen if you click on File > Defaults > Load Factory Settings, load file and perform test?
So there will be no addons running, also don't run any scripts when checking this.
I loaded the Factory Setting and seems like it did not change anything. The UI still freezes in the file.
Not sure what could cause such lag. I guess this would be reproducible on similar setup to yours, but it would probably help to simplify example file by removing objects and all other elements (even custom workspaces and similar data) that does not cause the bug.
Added subscriber: @ankitm
Please try to narrow down the cause by removing items as long as you keep getting the lag.
Added subscriber: @lichtwerk
