Moving python-made channels freezes Blender #81628
5 Participants
Reference: blender/blender#81628
Operating system: Linux-4.15.0-45-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.55
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-10-09 21:39, hash:
7ab8d7c939
Broken in Blender 2.83 and 2.79 as well, so it maybe never worked before?
Moving a channel of an animated curve created with Python gets Blender stuck in an infinite loop.
Note that without my changes to the addon, this does not happen.
See this file for comparison - same steps as above, but using the default AnimAll addon, no crash here: anim-move-curve-channel-no-crash.blend
So it's probably related to the names of the keyframe groups?
To help with debugging, Blender gets stuck forever inside
rearrange_action_channels
->join_groups_action_temp
->for (fcu = agrp->channels.first; fcu; fcu = fcu->next)
in fileanim_channels_edit.c
Added subscriber: @RedMser
Added subscriber: @lichtwerk
Can confirm, will check on this.
First note: for some reason the
bActionGroup
s are not in the right order in the failing file.I think what should always be the case is that the last ActionGroup's last FCurve should not have
fcu->next
set (it should be NULL).The preceeding ActionGroups last FCurve
fcu->next
should point to something valid (probably the first FCurve in the nextbActionGroup
)In the borked case of this modified Addon (or just the file that results from it), the first ActionGroup's last FCurve
fcu->next
is already NULL.This confuses code in
split_groups_action_temp
, it then thinks there are channels outside of groups, puts them in a#TempGroup
and things go downhill from here.Needs a bit more investigation if this a possible failure in the Python API or if this fails elsewhere. Stay tuned.
Added subscriber: @dr.sybren
@lichtwerk do you have a simple way of reproducing the issue that doesn't rely on modifying some add-on?
@dr.sybren: I am off today, but this is on my list. I have only reproduced using the method shown here, but I assume this can be reproduced in a simpler way, too.
Will step down to not block others
Changed status from 'Confirmed' to: 'Needs User Info'
Thanks for the report. Unfortunately the scenario described is too time consuming for us to track down, we require the bug reporter to narrow down the problem.
Normally .blend files can be simplified by removing most objects and disabling settings, until the problem reveals itself more clearly.
In this case, please make it possible to reproduce the issue with just a bit of Python code, instead of asking us to change the code of an add-on.
Added subscriber: @pioverfour
I don’t believe modifying AnimAll is necessary. I could reproduce the crash with the following script:
The double mode toggling at the end is necessary for the crash to happen. This is done in AnimAll because some types of keyframes can only be inserted in a specific mode.
The steps to reproduce are thus:
PageUp
This issue was referenced by
8c74c35ecb
