Performance regression when rendering at very high resolution #82591
10 Participants
Reference: blender/blender#82591
Graphics card: Radeon RX550/550 Series ATI Technologies Inc. 4.5.14736 Core Profile Context 20.8.3 27.20.12027.1001
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-11-09 14:47, hash:
4f66cf3b8b
Worked: blender-2.90.1-windows64
Time to render:
2.90.1: ~4min
2.92: ~30min
#82591.blend
Added subscriber: @iss
#85308 was marked as duplicate of this issue
#83011 was marked as duplicate of this issue
Performance regression when rendering large filesto Performance regression when rendering at very high resolutionAdded subscriber: @Alaska
I'm personally able to reproduce this issue on Linux with a Ryzen 9 3900X. Testing with old versions of Blender I have on my computer, I can reproduce it even back with Blender version 2.91.0
1b04eb6c44
(2020-10-10 16:05).I'm currently running a bisect to find the culprit commit. I'll comment back when I'm finished.
Added subscriber: @Jeroen-Bakker
Bisecting points to
4212b6528a
CC @Jeroen-Bakker
When cycles is rendering it creates a render result for specific tiles (offset + dimension) to the actual render result. It calls the
rect
on the RenderPass. This will sync a tile to blender. and call theRE_engine_end_result
; what will sync the tile result back to the full image (`render_result_merge).The render API has an option to only update a section of the display based on a given rect. The display update is set to
image_rect_update
when rendering. This function taggs the image with aIMA_GPU_REFRESH
and marks theGPUTexture
of the image as obsolete.The next time the
GPUTexture
is used/requested a newGPUTexture
is created. During this creation process the image is scaled to match the size of theGPUTexture
. If the image does not fit on the GPU it is scaled down.We could add partial updates of GPUTextures so only the new data needs to be scaled (
IMA_GPU_PARTIAL_REFRESH
). the rects that needs to be refreshed could be hold in a list on theImBuf
.NOTE:
can be promoted toIMA_GPU_REFRESH
.There is already a function that can update a part of a GPU texture
IMB_update_gpu_texture_sub
. But there is room for improvement here. as it usesimb_gpu_get_data
that still converts and scales the full image.Proposed solution
to be able to update a part of the source image. Currently it copies the full source image to a defined part on the GPUTexture.** Create
imb_gpu_get_sub_data
that is similar toimb_gpu_get_data
but doesn't convert/scale the full image. Use this function in.IMA_GPU_PARTIAL_REFRESH
** change
image_rect_update
to useIMA_GPU_PARTIAL_REFRESH
Added subscriber: @brecht
That sounds good to me. It may be possible to reuse the existing code for texture painting that does partial updates of scaled and unscaled textures.
Yes
gpu_texture_update_from_ibuf
handles this for texture painting. During development we should consider to merge the two implementationsAdded subscriber: @fclem
Sounds good to me too. Although, this would not help when using progressive refine. But I think this is an edge case as it's not used often.
Added subscribers: @Slowwkidd, @lichtwerk, @YAFU, @rjg
Just to leave a comment to be sure, I encountered the same problem in 2.91 with a resolution of 1754x2481, not "very high", so I guess the bug regards also smaller resolutions than the one in the first report.
@Jeroen-Bakker Shouldn't this be considered a high priority? It considerably increases the render times for renders around 2K resolution, which is a quite common scale for renders, and it's currently present in 2.91.
Added subscriber: @Raimund58
Added subscriber: @silex
After https://developer.blender.org/rB2e1498ff16198742ba543004fd9c2c49083a6095 patch I'm no longer experiencing crashes with rendering which is nice.
I've done some tests on current build hash
010f44b855
branch master.The bigger the render image size the bigger the performance hit.
rendering image size / average CPU usage
3000x3000 / ~98%
6000x6000 / ~ 90%
9000x9000 / ~ 70%
12000x12000 / ~ 2%
Cycles CPU rendering, tile size 32px. No adaptive sampling or denoising.
@silex have you tried after applying the patch of this task?
This issue was referenced by
4f9e21bdc9
Thank you!
After quick test the CPU looks fully utilised in all above scenarios.
As for exact performance numbers I'll need to check out. Nevertheless most regression seems to be gone.
I've run some tests and it seems that regression is happening in hybrid CPU+GPU rendering also.
Unfortunately I cannot pinpoint exact scene config for solid example.
Default cube renders without regression, but on production scenes with heavy geometry with displacement, volumes and lots of lights (both emissive mesh and standard) I have dips to 0% CPU utilisation.
CPU-only rendering regression is fixed.
Additionaly the tile size is wrong. In properties tile size is set to 32 px, and during rendering tile is around 14x14 px:
Added subscriber: @Luan-Rodrigues
