Camera turns in oposite direction to track target with track to and copy rotation constraint #83159
Reference: blender/blender#83159
Operating system: Linux
Graphics card: Intel Haswell
Broken: 2.92
Worked: Never (2.80+)
Camera turns in oposite direction to track target with track to and copy rotation constraint.
2020-11-28_21-40-21.mov
interpolation-bug.blend
Open attached file, compare camera tracking between frames 309 and 310.
Added subscriber: @Wovchick
Unauthorized camera(object) rotation with interpolation frames by X axis locationto Unauthorized camera(object) rotation when using interpolation frames by X axis with constraint track toUnauthorized camera(object) rotation when using interpolation frames by X axis with constraint track toto Unauthorized camera(object) rotation when making interpolation frames by X axis with constraint track toUnauthorized camera(object) rotation when making interpolation frames by X axis with constraint track toto Unauthorized camera(object) rotation when interpolation frames by X axis with constraint track toUnauthorized camera(object) rotation when interpolation frames by X axis with constraint track toto Unauthorized turn to 180 degrees Camera when interpolation frames by X axis with constraint track toAdded subscriber: @iss
This works correctly when I use copy location on camera instead of parenting. I am not quite sure what "interpolation frames by X axis" means - is it keyframe interpolation?
This looks like bug to me though.
Between keyframes the Blender generating (interpolating) frames and make it incorrect as I seems, the Camera between keyframes sharp rotate to 180 degrees, that it not must be because constraint Track to setted there.
Unauthorized turn to 180 degrees Camera when interpolation frames by X axis with constraint track toto Camera turns in oposite direction to track target with track to and copy rotation constraintAdded subscriber: @dr.sybren
The problem is that, with Euler angles, there are multiple ways in which to reach the same orientation. This means that the Track To constraint has multiple solutions to pick from, and not all of them may be compatible with the world rotation of the Copy Rotation target (in this case, the boat).
A Locked Track constraint will work better in this case (see the attached file). #83159-interpolation-bug.blend
I don't think this is a bug in Blender, but rather a downside of using Euler angles & matrices for the constraint system.
I understand! Thank You!
