Spline IK joint_bindings
parameter is broken #83164
Reference: blender/blender#83164
Operating system: Linux-5.4.0-48-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.80.02
Broken: version: 2.92.0 Alpha, branch: master
Worked: (Seems to work in 2.79, is broken in 2.90.1. I assume 2.80 is where it broke)
The Spline IK constraint has a parameter,
joint_bindings
that tells the constraint where along the curve to place the joints.However, this parameter is undefined or at least empty until the user applies the pose.
If the user attempts to access the parameter before the pose is applied, there will be an
IndexError
. (Alternatively, the parameter can be set from Python and it will then behave normally).If the user makes Blender re-calculate these bindings (by changing the chain_length parameter through the constraint for example), and attempts to assign or read the property by index, there will be a Crash To Desktop.
(I've never heard of anyone using this feature. The manual doesn't even say how; I'm only using it because I am trying to fix a bug in Spline IK and it was useful for testing an idea.)
C.active_pose_bone.constraints- [x].joint_bindings- [x]
(Note that the result is an empty tuple - Bug! If you query the first index, there will be an index error).Ctrl
-A
"Apply Pose as Rest Pose".C.active_pose_bone.constraints- [x].joint_bindings- [x]
. It will produce correct results (in my example, it should be [1.0, 0.0]).Steps for Crash To Desktop
chain length
back and forth.C.active_pose_bone.constraints- [x].joint_bindings[0]
(An aside: it would be nice to change this property to be reversed in order, it's annoying to
list(reverse(new_bindings))
when setting it!)Thanks 😃
bug_start.blend
Added subscriber: @Josephbburg
Added subscriber: @mano-wii
Thanks for the report. I can confirm.
Thanks for confirming -- I might fix this one in the process of fixing #81704, since I have to touch the joint binding code to fix that one, too. I'll try to remember to poke if it's out of my depth.
This issue was referenced by
dbdf22786d
ee486aa5ce
6c326ba0a2
