Crash when using a workspace/layout data path in a driver. #83411
Closed
opened 2020-12-04 22:25:22 +01:00 by Thierry Lefrancois · 14 comments
Graphics card: Intel(R) HD Graphics 4600 Intel 4.3.0 - Build 10.18.14.5117
Broken: version:
  • 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: 0f45cab862
  • 2.92.0, 2020-12-04
    Worked: 2.83.9
Crash when using a driver with Workspace as ID type and Layout as ID.
Simplified steps:
  • Download the attached file.
  • In the Workspace Properties, copy the data path to the custom property.
  • Switch to the Object Properties and edit the driver.
  • Paste the data path.
#83411.blend
#83411.crash.txt
2.91.0
  • In the Workspace Properties create a custom property
  • Copy the data path of this custom property
  • Select the cube, add driver on any channel (location, rotation, scale)
  • Change the transform channel type of the variable to //Single Property/.
  • Set the ID type to Workspace and the ID to Layout
  • Paste the data path of the custom property into the field
    Blender should crash.
2.92.0 - Starting from the default startup file:
Have a good day, amazing work!
**System Information** Operating system: Windows-7-6.1.7601-SP1 64 Bits Graphics card: Intel(R) HD Graphics 4600 Intel 4.3.0 - Build 10.18.14.5117 **Blender Version** Broken: version: - 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: `0f45cab862` - 2.92.0, 2020-12-04 Worked: 2.83.9 **Short description of error** Crash when using a driver with *Workspace* as ID type and *Layout* as ID. **Exact steps for others to reproduce the error** Simplified steps: - Download the attached file. - In the *Workspace Properties*, copy the data path to the custom property. - Switch to the *Object Properties* and edit the driver. - Paste the data path. [#83411.blend](https://archive.blender.org/developer/F9533788/T83411.blend) [#83411.crash.txt](https://archive.blender.org/developer/F9533787/T83411.crash.txt) ---- 2.91.0 - In the *Workspace Properties* create a custom property - Copy the data path of this custom property - Select the cube, add driver on any channel (location, rotation, scale) - Change the transform channel type of the variable to //Single Property/. - Set the ID type to *Workspace* and the ID to *Layout* - Paste the data path of the custom property into the field Blender should crash. 2.92.0 - Starting from the default startup file: - Select the cube, add driver on any channel (location, rotation, scale) - Change the transform channel type of the variable to //Single Property/. # Set the ID type to *Workspace* and the ID to *Layout* Blender should crash. Have a good day, amazing work!
Added subscriber: @thierry1222
Robert Guetzkow changed title from Crash when pasting a workspace/layout data path into a driver. to Crash when using a workspace/layout data path in a driver. 2020-12-04 23:34:13 +01:00
Added subscriber: @Sergey
Added subscriber: @rjg
I can confirm this crash in Blender 2.91.0 and 2.92.0. Blender 2.83.9 appears to be working fine.
2.91.0
library_foreach_ID_link(Main * bmain, ID * id_owner, ID * id, int(*)(LibraryIDLinkCallbackData *) callback, void * user_data, int flag, LibraryForeachIDData * inherit_data) Line 268	C
BKE_library_foreach_ID_link(Main * bmain, ID * id, int(*)(LibraryIDLinkCallbackData *) callback, void * user_data, int flag) Line 293	C
blender::deg::deg_expand_copy_on_write_datablock(const blender::deg::Depsgraph * depsgraph, const blender::deg::IDNode * id_node, blender::deg::DepsgraphNodeBuilder * node_builder, bool create_placeholders) Line 926	C++
blender::deg::deg_update_copy_on_write_datablock(const blender::deg::Depsgraph * depsgraph, const blender::deg::IDNode * id_node) Line 954	C++
blender::deg::deg_evaluate_copy_on_write(Depsgraph * graph, const blender::deg::IDNode * id_node) Line 1089	C++
 	[External Code]
blender::deg::`anonymous namespace'::deg_task_run_func(TaskPool * pool, void * taskdata) Line 128	C++
 	[External Code]
tbb::interface7::internal::isolate_impl<void,void <Lambdafunktion>(void) const>(const Task::()::__l2::void <Lambdafunktion>(void) & f) Line 160	C++
Task::operator()() Line 122	C++
tbb::internal::function_task<Task>::execute() Line 1049	C++
 	[External Code]
tbb::internal::task_group_base::wait() Line 168	C++
blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph * graph) Line 392	C++
BKE_scene_graph_update_for_newframe(Depsgraph * depsgraph) Line 1606	C
wm_event_do_notifiers(bContext * C) Line 498	C
WM_main(bContext * C) Line 482	C
main(int argc, const unsigned char * * UNUSED_argv_c) Line 524	C
 	[External Code]
2.92.0
blender::deg::DepsgraphNodeBuilder::build_id(ID * id) Line 479	C++
blender::deg::DepsgraphNodeBuilder::build_driver_variables(ID * id, FCurve * fcurve) Line 1005	C++
blender::deg::DepsgraphNodeBuilder::build_driver(ID * id, FCurve * fcurve, int driver_index) Line 994	C++
blender::deg::DepsgraphNodeBuilder::build_animdata(ID * id) Line 934	C++
blender::deg::DepsgraphNodeBuilder::build_object(int base_index, Object * object, blender::deg::eDepsNode_LinkedState_Type linked_state, bool is_visible) Line 646	C++
blender::deg::DepsgraphNodeBuilder::build_view_layer(Scene * scene, ViewLayer * view_layer, blender::deg::eDepsNode_LinkedState_Type linked_state) Line 117	C++
blender::deg::ViewLayerBuilderPipeline::build_nodes(blender::deg::DepsgraphNodeBuilder & node_builder) Line 36	C++
blender::deg::AbstractBuilderPipeline::build_step_nodes() Line 77	C++
blender::deg::AbstractBuilderPipeline::build() Line 56	C++
DEG_graph_build_from_view_layer(Depsgraph * graph) Line 229	C++
DEG_graph_relations_update(Depsgraph * graph) Line 282	C++
BKE_scene_graph_update_for_newframe(Depsgraph * depsgraph) Line 2660	C
ED_update_for_newframe(Main * bmain, Depsgraph * depsgraph) Line 1583	C
wm_event_do_notifiers(bContext * C) Line 509	C
WM_main(bContext * C) Line 641	C
main(int argc, const unsigned char * * UNUSED_argv_c) Line 526	C
I can confirm this crash in Blender 2.91.0 and 2.92.0. Blender 2.83.9 appears to be working fine. 2.91.0 ```lines library_foreach_ID_link(Main * bmain, ID * id_owner, ID * id, int(*)(LibraryIDLinkCallbackData *) callback, void * user_data, int flag, LibraryForeachIDData * inherit_data) Line 268 C BKE_library_foreach_ID_link(Main * bmain, ID * id, int(*)(LibraryIDLinkCallbackData *) callback, void * user_data, int flag) Line 293 C blender::deg::deg_expand_copy_on_write_datablock(const blender::deg::Depsgraph * depsgraph, const blender::deg::IDNode * id_node, blender::deg::DepsgraphNodeBuilder * node_builder, bool create_placeholders) Line 926 C++ blender::deg::deg_update_copy_on_write_datablock(const blender::deg::Depsgraph * depsgraph, const blender::deg::IDNode * id_node) Line 954 C++ blender::deg::deg_evaluate_copy_on_write(Depsgraph * graph, const blender::deg::IDNode * id_node) Line 1089 C++ [External Code] blender::deg::`anonymous namespace'::deg_task_run_func(TaskPool * pool, void * taskdata) Line 128 C++ [External Code] tbb::interface7::internal::isolate_impl<void,void <Lambdafunktion>(void) const>(const Task::()::__l2::void <Lambdafunktion>(void) & f) Line 160 C++ Task::operator()() Line 122 C++ tbb::internal::function_task<Task>::execute() Line 1049 C++ [External Code] tbb::internal::task_group_base::wait() Line 168 C++ blender::deg::deg_evaluate_on_refresh(blender::deg::Depsgraph * graph) Line 392 C++ BKE_scene_graph_update_for_newframe(Depsgraph * depsgraph) Line 1606 C wm_event_do_notifiers(bContext * C) Line 498 C WM_main(bContext * C) Line 482 C main(int argc, const unsigned char * * UNUSED_argv_c) Line 524 C [External Code] ``` 2.92.0 ```lines blender::deg::DepsgraphNodeBuilder::build_id(ID * id) Line 479 C++ blender::deg::DepsgraphNodeBuilder::build_driver_variables(ID * id, FCurve * fcurve) Line 1005 C++ blender::deg::DepsgraphNodeBuilder::build_driver(ID * id, FCurve * fcurve, int driver_index) Line 994 C++ blender::deg::DepsgraphNodeBuilder::build_animdata(ID * id) Line 934 C++ blender::deg::DepsgraphNodeBuilder::build_object(int base_index, Object * object, blender::deg::eDepsNode_LinkedState_Type linked_state, bool is_visible) Line 646 C++ blender::deg::DepsgraphNodeBuilder::build_view_layer(Scene * scene, ViewLayer * view_layer, blender::deg::eDepsNode_LinkedState_Type linked_state) Line 117 C++ blender::deg::ViewLayerBuilderPipeline::build_nodes(blender::deg::DepsgraphNodeBuilder & node_builder) Line 36 C++ blender::deg::AbstractBuilderPipeline::build_step_nodes() Line 77 C++ blender::deg::AbstractBuilderPipeline::build() Line 56 C++ DEG_graph_build_from_view_layer(Depsgraph * graph) Line 229 C++ DEG_graph_relations_update(Depsgraph * graph) Line 282 C++ BKE_scene_graph_update_for_newframe(Depsgraph * depsgraph) Line 2660 C ED_update_for_newframe(Main * bmain, Depsgraph * depsgraph) Line 1583 C wm_event_do_notifiers(bContext * C) Line 509 C WM_main(bContext * C) Line 641 C main(int argc, const unsigned char * * UNUSED_argv_c) Line 526 C ```
@rjg, is this a crash or assert failure? If it's a crash, can you share .blend file with minimum steps needed to crash?
@Sergey It crashes in release builds and triggers an assert in debug builds. In Blender 2.92 it's an assert in void DepsgraphNodeBuilder::build_id(ID *id) because it reaches the default case. The description has been updated with a simple example project.
@Sergey It crashes in release builds and triggers an assert in debug builds. In Blender 2.92 it's an assert in `void DepsgraphNodeBuilder::build_id(ID *id)` because it reaches the `default` case. The description has been updated with a simple example project.
This issue was referenced by 876fd40643
This issue was referenced by 876fd40643dfa7b206edabbde30809e6e48e583b
This issue was referenced by 0f95f51361
This issue was referenced by 0f95f51361d73fbd8ba8d80b3b65da930dcf3b20
Sergey Sharybin self-assigned this 2021-01-13 12:14:33 +01:00
This issue was referenced by cd24712c2c
This issue was referenced by cd24712c2c51ab753369f7cae8c43c38115bd59f
Changed status from 'Resolved' to: 'Confirmed'
Re-opening, caused issue which affects more users.
5 Participants
Reference: blender/blender#83411
