Crash when going to Properties Editor object properties with Custom Property containing nested dictionary [named "asset_data"] #84091
6 Participants
Reference: blender/blender#84091
Operating system: Linux-4.15.0-126-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: Radeon RX Vega (VEGA10, DRM 3.23.0, 4.15.0-126-generic, LLVM 10.0.0) X.Org 4.6 (Core Profile) Mesa 20.0.8
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-22 20:58, hash:
8d3d4c8840
Worked: 2.90 seems to work fine.
Caused by
b71eb3a105
Crash when selecting object properties tab. This started happening when I added (as append) some assets from BlenderKit. I have no idea which BlenderKit asset broke the file. I was just messing around testing some stuff.
Open the file with UI. Select object properties. Crash.
See attached file, I think I was able to delete all nonsense like textures or my custom library stuff from it.
CrashFile2.blend
Added subscriber: @CarlG
Added subscribers: @VilemDuha, @EAW
I can confirm.
@VilemDuha Here is my stack trace: CrashFile2.crash.txt
Tested using: version: 2.92.0 Alpha, branch: master, commit date: 2020-12-24 19:11, hash:
af316d2761
, type: Releasebuild date: 2020-12-24, 22:31:17
OS: Windows-10-10.0.19041.630-SP0 64 Bits
GPU: GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
CPU: i7-950 @3.07 GHz SSE2 SSE3 SSE41
RAM: 8.00 GB
Confirmed also here, I did investigate. Not really caused by the addon, but by a nested dictionary in a custom property - a thing that is working fine in previous versions.
Crash your blender instantly with running this with an object selected and then switching to object properties:
The reason why object properties is probably very clear too, that's where blender displays custom properties in a panel
Just a guess: removing the ability for custom properties to contain quotes from Blender’s python API seems like a likely candidate as the cause of this issue.
ceba6b2c21
Added subscriber: @lichtwerk
Will check
Crash when going to object properties with BlenderKit asset.to Crash when going to Properties Editor object properties with Custom Property containing nested dictionarySetting to High prio since it is a crash regression and we have bisected to the culprit commit.
Added subscribers: @JulianEisel, @mont29
For some reason, I cannot reproduce from scratch using the script @VilemDuha provided.
Anyways, opening that file, I assume blender gets confused with the Custom Property
asset_data
:rna_idp_path
,RNA_struct_find_property
will find a property matching "asset_data" (but it is not the Custom Property, but the new one introduced inb71eb3a105
)ID_asset_data_get
, but of course that will return bogus (because we are not actually dealing with the expected "internal" asset_data, but a Custom Property...)I havent checked code further, it would be kind of surprising if Custom Properties are as fragile as not being allowed to be named equally to existing datablock properties.
@JulianEisel, @mont29 might know more already?
Crash when going to Properties Editor object properties with Custom Property containing nested dictionaryto Crash when going to Properties Editor object properties with Custom Property containing nested dictionary [named "asset_data"]Didn't think it could be the name. Did one more test - when I assign as 'asset_data' I get a crash.
However, when I first assign the same dict as a different property name ('test'), go to object properties (where it correctly draws) I can actually afterward assign also 'asset_data' without a crash.
This works only when I first go to object properties between the assignments. If I assign both props one after another I get the crash.
Added subscriber: @ideasman42
In
d1cedf53fa
@ideasman42 revertedcbae82ba96
giving the following reasons:@ideasman42, given the above list and the 8 commits on Dec 9-10 to rnaaccess.c, I figure you might best know more about why this issue is occurring and how to answer @lichtwerk's
questionstatement above:I had the same issue, thanks for the clarifications @lichtwerk and @VilemDuha!
This issue was referenced by
ad63d2f60e
Oh, cool, and thanks. Seems to have been fixed in 2020-12-28 21:34 version (Linux).
