2 objects with identical coordinate numbers appearing in completely different places #84147
7 Participants
Reference: blender/blender#84147
Operating system: win 10 pro
Graphics card: r9 360
Broken: 2.7-2.9+
Worked: Never
infinite ammounts of objects sharing excatly the same coordinates, but not one of those objects is located in the coordinates.
Spawn a cube. Move it 10 meters on X axis. Dublicate the object as many times as you wish.
Make another object to be used as parent. Move the parent to random location, then add first cube, move parent to random location, add second cube, and so on and on, till you have all the objects sharing excatly the same coordinates, they all will be 10 meters away from something, not sure what, but they will be.
Blender doesnt show local positions or global positions, but whatever the garbage it shows is, its broken and unusable.
If you think its usable, without any modifications, tell me local or global location to cube.013. Or any useful information about the cube 013's location. The parent, which is sphere is located at (6.29178 m, -1.46316 m,-2.92347 m)
bug.blend
Added subscriber: @DageLV
Added subscriber: @CreatorSiSo
The objects are not 10 meters away from something they just stay in the same relation to the parent object.
I dont really understand your problem it would be nice if you could try and explain how you think that parenting works.
And the location of cube.013 is X=4.08938 m Y=-6.3372 m Z=-5.76471 m (Go to object mode>select cube.013>press[shift+s]>cursor to selected (or press- [x])>press- [x]>View>3D Cursor or edit mode>press[shift+a]>press- [x]>Item>Median)
Added subscriber: @jenkm
But the UI shows
10m 0 0
, maybe this is the complaint?Added subscriber: @robbott
I'd say it's a known issue / feature / bug. See https://docs.blender.org/manual/en/dev/scene_layout/object/editing/parent.html?highlight=parent%20inverse#parent-inverse
And for more context: https://devtalk.blender.org/t/reevaluating-worldspace-and-localspace-treatment-need-some-dev-triage/9665
no. The parent object is sphere. and all 19 cubes are in excatly to the same relation. 10 meters away from something. im not sure what, from world center? From the sphere? i dont know.
Open 3ds max, open unity, open any other program which involves transforms. if you have sphere 3m on X axis , a child cube 10 meters away from sphere, the transform will say its 10 meters away or 13, based on if it uses local or transforms. In blender it says once upon a time this object was positioned in the world axis 10 meters away from center of the world. Now its somewhere unknown.
Thats not a solution tho. Its just going around the issue. If i were to do this, each time i wanted to check if my wheel is located excatly the distance i need it to be located and had to do this, i should make a youtube tutorial for myself to follow to.
Unless you have a conversion formula which doesnt involve having a time machine which i could just quickly snap in, get the current actual coordinates of the object?
yes it is. The inacuracity of the ui. It makes no sense. It shows where the object was before parenting, not where it is located according to parented object or on world axis, and it doesnt even have the option to switch to it, so sometimes ill see that all the models are where i need them to, then make a change and the objects will be moved by small amount because blender doesnt keep the location of objects by default, if the movement is small enough, like 0.1 meters, i wont know it maybe till days later.
yes, it is old, but there is no way to fix it, for the user.
i cant immagine how blender came to this, did they gave the software to testers and most of them just said "Well, its good, but you know when you parent an object which isnt at 0,0,0 location? Yeah. About that. We dont really care, i dont think anyone cares where the object is now, but what we care for is where the object was before parenting, and yes, once you unparent, the object should snap to its original place by default"
Well then i would say its not a bug but a missing feature and if u want it in blender either go and like the proposal on rightclickselect or code it yourself and submit it. ;)
its a bug tho.
No because the feature is simply not implemented.
Added subscriber: @EAW
This might fall under #80490 (Child Object jumps away with changing the parent bone) which has been labeled a design task to implement the showing of the inverse parent matrix in the UI.
Yeah I guess we can close this task as a duplicate then right?
Removed subscriber: @jenkm
Added subscriber: @dr.sybren
@CreatorSiSo I am going to wait until I get @dr.sybren’s feedback on renaming #80490 and updating its description, or instead the possibility of creating a new specifically named design task that both this and that report can be merged into.
As #80490 is currently named and described, I think merging this task might lead to the specific issue this report describes getting lost/overlooked.
@dr.sybren thoughts on what you would like done?
Added subscriber: @Bodi
Please be a bit more respectful in your wording.
I agree that the "parent inverse" matrix has some usability issues, mostly because it's so invisible in the UI. This is indeed a known problem. I've tried to document the workings of this matrix, and the reason why it exists in the first place, in the manual.
Just press {key Ctrl A} to select all objects, press {key Alt P} to get the "unparent" menu, then choose "Clear Parent Inverse". Or go to the menu item Object → Parent → Clear Parent Inverse. There you have all your cubes at the same location, (10, 0, 0) relative to the parent.
Closing this as invalid, as the report doesn't describe a bug in Blender.
