Armature bone constraints not working #84884
Closed
opened 2021-01-20 05:26:57 +01:00 by Larry Nestor · 5 comments
Operating system: Linux-5.4.0-62-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: AMD VERDE (DRM 2.50.0, 5.4.0-62-generic, LLVM 11.0.0) X.Org 4.5 (Core Profile) Mesa 20.2.6
Broken: version: 2.92.0 Beta, branch: master, commit date: 2021-01-16 19:09, hash: 6fb7d0f559
create an armature, parented a mesh to the armature. Add object constraint -> armature not constrained
Start with general startup.
Ctrl+a add a armature
Select cube first, then bone. Ctrl+p to parent cube to Bone
Ctrl+tab change to pose mode. Cube follows bone, as it should, in any direction with bone selected and g for grab.
In pose mode, select Object constraint properties
Add Object constraint > Limit Location
Change to Local Space
Check y minimum, change value to -1m
Check y maximum change to 1m
Back in 3D viewport, select bone (already selected), press g to grab, bone and cube move without any constraint
**System Information** Operating system: Linux-5.4.0-62-generic-x86_64-with-debian-bullseye-sid 64 Bits Graphics card: AMD VERDE (DRM 2.50.0, 5.4.0-62-generic, LLVM 11.0.0) X.Org 4.5 (Core Profile) Mesa 20.2.6 **Blender Version** Broken: version: 2.92.0 Beta, branch: master, commit date: 2021-01-16 19:09, hash: `6fb7d0f559` Worked: (newest version of Blender that worked as expected) **Short description of error** create an armature, parented a mesh to the armature. Add object constraint -> armature not constrained **Exact steps for others to reproduce the error** Start with general startup. Ctrl+a add a armature Select cube first, then bone. Ctrl+p to parent cube to Bone Ctrl+tab change to pose mode. Cube follows bone, as it should, in any direction with bone selected and g for grab. In pose mode, select Object constraint properties Add Object constraint > Limit Location Change to Local Space Check y minimum, change value to -1m Check y maximum change to 1m Back in 3D viewport, select bone (already selected), press g to grab, bone and cube move without any constraint [Based on the default startup or an attached .blend file (as simple as possible)]
Author
Added subscriber: @LarryN
Author
I had a problem with beta Blender2.92.0. One is that the object outline isn't working. The second is that armature Limit Location Constraint for a bone/armature isn't working
testBoneConstraint.blend
I had a problem with beta Blender2.92.0. One is that the object outline isn't working. The second is that armature Limit Location Constraint for a bone/armature isn't working [testBoneConstraint.blend](https://archive.blender.org/developer/F9588767/testBoneConstraint.blend) [testBoneConstraint.blend](https://archive.blender.org/developer/F9588768/testBoneConstraint.blend)
Member
Added subscriber: @filedescriptor
Member
Member
From what it looks like in your file you set the modifier on the armature not the bone. The bone will be tinted green when constrained. This is not a bug. Closing.
From what it looks like in your file you set the modifier on the **armature** not the **bone**. The bone will be tinted green when constrained. This is not a bug. Closing. ![image.png](https://archive.blender.org/developer/F9589042/image.png) ![image.png](https://archive.blender.org/developer/F9589034/image.png)
2 Participants
Reference: blender/blender#84884
