Sound track in NLA editor doesn't mute at the end of the NLA strip #84944
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
7 Participants
Reference: blender/blender-manual#84944
Graphics card: GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.92.0 Beta, branch: master, commit date: 2021-01-17 10:36, hash:
blender/blender@2ee2f87f29
The sound plays over the end of the NlaTrack : Nla strip edited to end at frame X the sound is still playing after X (because the sound clip is longer)
The mute track property can't be animated and there is no point for the end of the nla strip since it only uses the start frame.
In video sequencer you are able to change the end of the sound clip, but not in NLA
as a plus the default Sound track NLA Strip doesn't show the correct duration of the imported soundclip.
add a speaker object
select a sound clip
in the NLA editor the default soundtrack NLA strip is not adapted to the duration of the imported soundclip
if you add a soundclip the new NLA strip has the correct size/ duration
if you change the end frame of the NLA strip it doesn't affect in anyway the soundclip duration
Added subscriber: @in10siv
Added subscriber: @mano-wii
I can confirm that the length of the strip does not appear to influence the duration of the sound.
Apparently the only thing that matters is where it starts.
The manual also says nothing about the duration of the sound:
https://docs.blender.org/manual/en/latest/editors/nla/strips.html#sound-clip-strips
So this seems to be a known issue.
But I'm not familiar with that area to know if it's a bug or known issue.
Added subscriber: @wbmoss_dev
This adds support for sound strip types but not actually playing sounds.
This adds support for them to play sound based on the strip's start frame.
It doesn't look like a bug. It looks like sound strips are intended to only specify the start frame. I haven't found anything that suggests the strip's duration is supposed to do anything.
I see, so that is the only thing it does, but i still feel that this is an issue of inconsistency in the first place.
Added subscribers: @neXyon, @dr.sybren, @lichtwerk
Lets confirm it for now though (it could still be closed as a Known Issue).
Not quite sure who could do the decision here though?
CC @dr.sybren
CC @neXyon
Correct, the NLA strip is only there to signal the start of the playback of the sound. I remember when I implemented this: I wanted a user interface similar to the dope sheet, where you could simply set key frames in which the sound starts to play, but that was not possible. Instead I used the NLA editor, where the strips have lengths... So this was actually a conscious decision to have this behaviour!
"Fixing" the issue would be as simple as changing the two
FLT_MAX
insound.c
to(double)strip->end / FPS
. That could certainly be done, but might break existing files, where people use the NLA strips just for positioning the start of the playback. Also, this UI would then still be inconsistent with the VSE, since you cannot edit the start of the clip. Any extension or scaling at the beginning will basically end up moving the start of the sound to a different frame and lengthening/shortening the end instead of changing where in the sound file the sound starts to play back.So in sum, it's a UI issue and I just had another idea on how to fix it: we could remove speakers and make it possible in the sequence editor to link a sound sequence to a 3D object (like an empty) or keep the speakers and allow linking only to those. Then we can do the corresponding editing in the sequencer. :)
PS: the default NLA strip doesn't have the correct length because it is added before the sound is added, so we don't even know yet, what the length of the sound is. If we keep the old behaviour that the NLA strips only set the start of the sound, it might actually be better to always just use the default length of 10 frames for the strip in order not to cause additional confusion, that the sound should stop at the end of the strip.
I love the idea to link a sound clip to a 3D object in the Sequencer, but i would not remove the speaker since you have more control over the cone of volume/orientation.
Keeping the Speaker and linking sound clips from the sequencer will make it better since you could add different sounds to a single Speaker(with the properties that you have set from the begging). I would remove the pitch and volume from the speaker object since you have them already in the sequencer(specific for each sound clip).
If we keep the NLA strip, at least an update of the first Strip after the sound is added would be better, at least for a visual representation, even if it doesn't change with the pitch (this behavior is the same in the sequencer).
Proposal for the linking menu
In that case, let's see this as an issue in the documentation. IMO such behaviours should be documented well. @neXyon do you feel up to updating some docs?
I'm all for making the speaker objects more reliable/useful. That's not something to do in a bug report though ;-)
Well, the question here is whether this should be fixed actually. As I wrote previously, it's quite easy to fix and with some file version magic it should also be possible to make old files work properly as well. It's more a UI vs previous/current behavior question. Who could best decide on this? I can then either update the docs or implement the behavior.
Personally I would prefer to add this feature.
The length of the NLA strip in this case is useless and can confuse rather than help.
If this length is to be put to some use, muting the sound seems to be a good option.
If possible, to avoid breaking existing files, we could add versioning and increase the length of the NLA strip in these cases.
Added subscriber: @BClark
"If this length is to be put to some use, muting the sound seems to be a good option."
Agree
Totally agree, as long as it doesn't put the Speaker Object on mute.
