Blue on cropped part of image when Sequencer color space is Linear #85003
Reference: blender/blender#85003
Operating system: Darwin-19.6.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.18
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-01-22 18:30, hash:
aaa1d58054
Broken: version: 2.92.0 Beta, branch: master, commit date: 2021-01-15 20:18, hash:
957de39191
Worked: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash:
0f45cab862
When using the Linear color space for the sequencer, a cyan blue color appears where the cropped part of the image should be. It appears best when placed over a white color strip. I'm not sure if it works on all images.
Setting Color>Saturation != 1 makes the cropped area turn black.
Changing Color>Multiply doesn't affect it.
I don't know if this is due to misuse of color spaces.
Here is how I made the example file:
Note default Sequencer color space is sRGB.
In the example file I also cropped the color strip to show that the blue only appears where the color generator strip is.
Based on attached .blend file.
blue_cropped_on_alpha_over.blend
Added subscriber: @ckerr
Added subscriber: @iss
Can you provide image file?
What are steps with provided .blend file? I assume I should start from step 9?
Here's the image unpacked from the .blend.
I have tested a few different images and it's not obviously linked to the image.
Yes for the attached file, start from 9.
I just confirmed by re-downloading it - the problem shows up in the preview right away when I open the .blend file.
I can't reproduce this issue. Based on description I would assume it can be duplicate of #82094 as convert to float should change strip colorspace to linear.
Can youy check without changing colorspace in rendering panel and just using convert to float option on strip?
Using the 'Convert to float' option on either/both strips doesn't reproduce the problem in this task.
(Commented on #82094 too; I couldn't reproduce that)
Can you see this blue area even if you render the image? Can you save rendered image and check saved image?
Can you sample area in preview by clicking onto area with mouse? Does tool also report blue color?
The render looks normal, even on saved image.
Rendering even makes the sequencer preview window look normal until I change the frame. (Caching maybe?)
If I import the saved image back into Blender as an image strip, it looks fine unless I start cropping it.
Good idea.
White area shows as expected:
R:1.00000 G:1.00000 B:1.00000 A:1.0000 | CM R:1.0000 G:1.0000 B:1.0000 [white patch] H:0.0000 S:0.0000 V:1.0000 L:1.0000
Blue area shows negative values in the red channel:
R:-1407600499915438018491580416.00000 G:1.00000 B:1.00000 A:1.0000 | CM R:-0.1250 G:1.0000 B:1.0000 [blue patch] H:0.5000 S:1.1250 V:1.0000 L:0.7608
Sorry for late answer, I have lost this report. Adding BF-Blender tag so it's in my workboard.
Other than that, Still can't reproduce this issue, But I have noticed R channel having value of -0.000 with Linear colorspace. So there is probably something to this.
@ckerr since this issue doesn't exist during render, can you check if this issue still exists when you switch User Preferences > Viewport > Textures > Image Display Method to GLSL or 2D Texture?
@iss I found that both GLSL and 2D Texture had no change in behavior.
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-04-09 05:00, hash:
3f91591c1d
Thanks for update.
I wanted to continue investigation, but now I can't reproduce even negative value in R channel.
No issue on another machine as well.
Issues like this may be caused by imprecise math being done on GPU, so you may try using different GPU driver or even software based openGL emulation to check whether this would resolve the issue. I would expect this to be case only with GLSL though, but I don't have deep knowledge how these methods work internally.
Other than that I am out of ideas.
Added subscriber: @OmarEmaraDev
Can you try capturing an API trace of the frame where the issue happen and attach it here? You should remove all other frames if possible. See https://apitrace.github.io/ for instructions.
I can no longer reproduce the original bug. (Note this test was on 2.93.0 release)
Operating system: macOS-10.15.7-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.22
Works: version: 3.0.1, branch: master, commit date: 2022-01-25 17:19, hash:
dc2d180181
Works: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
However, there is another problem. I'm not sure if this problem existed when I made the first report, but it seems related.
If I set the "Display Channels" to "Color" instead of "Color and Alpha", places with background showing through look green.
This has a bigger impact when using the Display Mode to view anything besides "Image Preview", such as "Chroma Vectorscope".
Broken: version: 3.0.1, branch: master, commit date: 2022-01-25 17:19, hash:
dc2d180181
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
It would be best if you open a separate report for other issues. Since you can't replicate the original issue, we will archive this for now.
