Lock Interface toggle will not toggle #85244
8 Participants
Reference: blender/blender#85244
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 2.92.0 Beta, branch: master, commit date: 2021-01-30 20:50, hash:
40061911d2
Lock Interface option is randomly toggled on and getting locked and cannot be toggled off. This occurs in the newest 2.92 Beta, but I have experienced it in 2.90, 2.80-.82.
No known steps. Literally just happens at random in my experience. The issue transfers with .blend files. I have tried appending scenes into new .blend files and the issue comes with it.
Provided a .blend where the option will not toggle off.
Lock Interface Bug.blend
Added subscriber: @vfxninjaeditor
Lock Interface toggle is will not toggleto Lock Interface toggle will not toggleAdded subscriber: @FloridaJo
Just an FYI:
I was able to unlock on my machine, 1-30 build.
OSX High Sierra.
Added subscriber: @lichtwerk
Works here as well
@vfxninjaeditor : just to make sure:
Please try with File → Defaults → Load Factory Settings to see if you still can reproduce this issue.
Added subscriber: @johannes.wilde
I have the same problem in some scenes with latest builds of 2.92 and 2.93. On latest 2.91 however everything works fine
PopOS 20.10
With the latest Builds and resetting to Factory Defaults it works for me now.
Added subscriber: @slowburn
Looks like this is caused by a corrupted userpref.blend file in *AppData\Roaming\Blender Foundation\Blender\2.93\config*. Doing a factory reset fixes the issue but after a few days it appeared again for me, so it would be great to have a proper fix, because resetting and reconfiguring everything from scratch is quite a lot of work. Wouldn't want to do it every time. Please look into the file, maybe you'll find the cause of this bug. Note that simply opening this file doesn't cause setting to lock up, you have to put it into *Blender\2.xx\config* directory. Another strange thing is that Blender 2.91 seems immune to this bug. If I replace the original userpref file in 2.91 directory with corrupted one, the Lock Interface setting doesn't get stuck, whereas for 2.92 and 2.93 it does.
userpref(corrupted).blend
Still cannot reproduce with the (corrupted?) userpref.blend [but of course I dont have all the Addons installed that the userpref wants to load...]
Could you check one more time:
thx in advance.
No, I cannot reproduce this issue with 3.0 build. But recently I had a similar problem where Lock Interface would turn on whenever I did a render. I could still uncheck it, but it was really annoying to toggle it all the time. So I deleted 3.0 folder in AppData to get a fresh start, therefore I don't have all add-ons installed. I'll try to reinstall them gradually and watch if Lock Interface starts acting up again.
Added subscriber: @PMA33
Hello, I have had the same issue here (3 Alpha), reverting to default interface solved the problem, but ... I have already reset the interface to default some days ago (for a crashing problem #91676) so the issue should not have appeared in my case.
I saw the same problem on 2.93, restoring the default interface once again solved it and restoring the saved preferences restored also the issue... you can see that on this poor video, preference windows is not visible, I am loading the default preferences and then my custom one 2021-09-26 12-32-54.mkv.
I reinstalled all the add-ons I use without problem for the moment.
Hi, may be something interesting here 2021-09-26 18-50-44.mkv
The lodify add-on seem to be the culprit ...
Updating the add-on solve the problem, for me.
heu .... not totally, the locking option is re-checked after each render .... and stay in its last state when the add-on is disabled....
After some research this issue was described in Github but there is few information about its resolution ...
For reference, the github issue is https://github.com/DB3D/Lodify/issues/1
Can everyone confirm this is the culprit?
Can confirm! Turning off Lodify just solved the issue for me.
Yea, for me as well. Although I could only reproduce the issue in 3.0 if I loaded earlier userpref file that was corrupted. So just enabling the addon might not cause the problem right away, making it harder to detect.
Dont have the Addon installed, but apparently LODify needs this to be ON
https://github.com/DB3D/Lodify/blob/master/Lodify.py#L1058
There is a setting for this "mandatory interface render lock", you might be able to turn this OFF? (and only turn it ON when realy using the LODify features?)
In any case, this is something that is caused by an external Addon, nothing to be done from the Blender side.
Will close, thx reporting (and investigating!) everyone.
Added subscriber: @dodododorian
Hello I'm the creator of Lodify
I'm sorry for the trouble caused here
It is clearly stated in the documentation (devtalk) of this plugin that the locking interface toggle is mandatory in order to work, this plugin will change the mesh data while cycles might be calculating, and that can/will cause crashes.
"render.interface_lock will be enabled with this addon, this can be disable in the options (but expect some crashes if removed)"
This shall be fixed once lodify will do the mesh data switching with the help of Geometry node
It's okay, man. You were trying to solve a problem that shouldn't be there in the first place, we appreciate the effort.
Although that warning was really easy to miss amongst all the text. It would be best to also add a warning to the addon description inside of blender for things like that.
