Blender Crashing When Selecting "Pack Islands" #85431
Closed
opened 2021-02-06 18:08:11 +01:00 by Filipe · 7 comments
Operating system: Windows 10
Graphics card: RTX 3060 TI
Broken: 2.91
Description and steps
I was modeling a chest.
Every piece of the chest is a separate object.
I've UV unwrapped every object individually.
On the Layout tab- I select all objects. Then enter object mode. Select everything with the "A" key.
On the UV Editing tab - Select everything again. On UV, select "Average Islands". Then select "Pack Islands".
Blender imediatly closes after following the previous steps.
**System Information** Operating system: Windows 10 Graphics card: RTX 3060 TI **Blender Version** Broken: 2.91 **Description and steps** I was modeling a chest. Every piece of the chest is a separate object. I've UV unwrapped every object individually. On the Layout tab- I select all objects. Then enter object mode. Select everything with the "A" key. On the UV Editing tab - Select everything again. On UV, select "Average Islands". Then select "Pack Islands". Blender imediatly closes after following the previous steps.
Author
Added subscriber: @Praizzy
Member
Added subscriber: @filedescriptor
Member
Member
It would be helpful in this case if you could share a simplified .blend file that will cause a crash on your system. You can attach files by using drag & drop.
I was not able to reproduce this on the latest alpha. See if downloading it from https://builder.blender.org/download/ and then trying again will solve the issue.
It would be helpful in this case if you could share a simplified `.blend` file that will cause a crash on your system. You can attach files by using drag & drop. I was not able to reproduce this on the latest alpha. See if downloading it from https://builder.blender.org/download/ and then trying again will solve the issue.
Member
Added subscriber: @lichtwerk
Member
Member
Also could not reproduce here.
Since the example file has not been provided, we'll have to close:
Also could not reproduce here. Since the example file has not been provided, we'll have to close: No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
Reference: blender/blender#85431
