GPencil's draw tool has its strokes offset after using fill tool #85549
Closed
opened 2021-02-11 13:19:29 +01:00 by Jonathan Mielke · 16 comments
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: 2.93.0 Alpha, branch: master, commit date: 2021-02-10 21:40, hash: 175325ebdb
Worked: 2.93.0 Alpha, branch: master, commit date: 2021-02-08 23:42, hash: eab9165c25
After using the fill tool the grease pencil draw tool doesn't work correctly and draws strokes offset from the cursor.
I suspect the recent new fill features commit is the culprit (1352d81b17)
Note: fill tool also stops working correctly after doing this as well and just fills the entirety of the viewable canvas no matter where strokes are.
  • Use default 2d animation layout (issue persists in other layouts just listing exact steps)
  • draw circle
  • fill circle with fill material using fill tool
  • switch back to draw tool and try to draw line
Also see video
Desktop 2021.02.11 - 04.59.34.01.mp4
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40 **Blender Version** Broken: 2.93.0 Alpha, branch: master, commit date: 2021-02-10 21:40, hash: `175325ebdb` Worked: 2.93.0 Alpha, branch: master, commit date: 2021-02-08 23:42, hash: `eab9165c25` **Short description of error** After using the fill tool the grease pencil draw tool doesn't work correctly and draws strokes offset from the cursor. I suspect the recent new fill features commit is the culprit (1352d81b17) Note: fill tool also stops working correctly after doing this as well and just fills the entirety of the viewable canvas no matter where strokes are. **Exact steps for others to reproduce the error** - Use default 2d animation layout (issue persists in other layouts just listing exact steps) - draw circle - fill circle with fill material using fill tool - switch back to draw tool and try to draw line Also see video [Desktop 2021.02.11 - 04.59.34.01.mp4](https://archive.blender.org/developer/F9791878/Desktop_2021.02.11_-_04.59.34.01.mp4)
Added subscriber: @JSM
Added subscriber: @antoniov
I cannot reproduce it in my Windows system with the last master code.
I cannot reproduce it in my Windows system with the last `master` code.
Antonio Vazquez self-assigned this 2021-02-11 16:11:26 +01:00
Added subscriber: @filedescriptor
@filedescriptor can you reproduce it?
So tried to repo on another computer and couldn't.
Can still reproduce on latest buildbot with original system.
But discovered more weirdness. I only have this issue on one monitor. using either of my 2 other connected monitors and I don't have the issue.
The troublesome monitor is an: ASUS MG278Q running at 1440p 144hz (changing resolution/hz size did not fix bug either)
Will try to narrow down and get it reproducible on other monitors.
So tried to repo on another computer and couldn't. Can still reproduce on latest buildbot with original system. But discovered more weirdness. I only have this issue on one monitor. using either of my 2 other connected monitors and I don't have the issue. The troublesome monitor is an: ASUS MG278Q running at 1440p 144hz (changing resolution/hz size did not fix bug either) Will try to narrow down and get it reproducible on other monitors.
Annnnd Figured out what the difference between the monitors. The Windows scale and layout settings was set over 100% at 150% on my one monitor.
So to reproduce set monitor scaling at or above 150 % in windows display settings.
Then do original steps described in initial report.
Annnnd Figured out what the difference between the monitors. The Windows scale and layout settings was set over 100% at 150% on my one monitor. ![settings.jpg](https://archive.blender.org/developer/F9793835/settings.jpg) So to reproduce set monitor scaling at or above 150 % in windows display settings. Then do original steps described in initial report.
Member
Closed as duplicate of #85476
I'm now not sure it's the same bug as the #85476: Multi-monitor window scale problem.
When running at at default 100% windows scale and with a single monitor I'm having offset issues like before on the latest buildbot (version: 2.93.0 Alpha, branch: master, commit date: 2021-02-20 05:19, hash: 37e6a1995a).
The only thing that's different is that I set the blender preferences > interface > Display> Resolution Scale to 1.2 or above in blender user preferences. And using the windows compatibility option, override High DPI Scaling behavior, is no longer fixing it.
Tested on a second system as well.
Operating system: Windows-10 64 Bits
Graphics card: Radeon RX 580 Series ATI Technologies Inc. 4.5.13596 Core Profile Context 20.10.35.02 27.20.1034.6
I'm now not sure it's the same bug as the #85476: Multi-monitor window scale problem. When running at at default 100% windows scale and with a single monitor I'm having offset issues like before on the latest buildbot (version: 2.93.0 Alpha, branch: master, commit date: 2021-02-20 05:19, hash: `37e6a1995a`). The only thing that's different is that I set the blender preferences > interface > Display> Resolution Scale to 1.2 or above in blender user preferences. And using the windows compatibility option, override High DPI Scaling behavior, is no longer fixing it. Tested on a second system as well. Operating system: Windows-10 64 Bits Graphics card: Radeon RX 580 Series ATI Technologies Inc. 4.5.13596 Core Profile Context 20.10.35.02 27.20.1034.6
Changed status from 'Duplicate' to: 'Confirmed'
Yes, actually is not supported to use a resolution different of 1.0. The problem is not only in Fill.
Added subscribers: @HooglyBoogly, @JulianEisel
@HooglyBoogly @JulianEisel I have tested and this bug is not in 2.83. I have not changed anything in the code related to this area, so do you know what can be the problem? Maybe some UI change?
EDIT: I tested and the problem drawing stroke was gone, and now is only fill, so I need investigate because this can be a problem in gpencil code.
@HooglyBoogly @JulianEisel I have tested and this bug is not in 2.83. I have not changed anything in the code related to this area, so do you know what can be the problem? Maybe some UI change? EDIT: I tested and the problem drawing stroke was gone, and now is only fill, so I need investigate because this can be a problem in gpencil code.
This issue was referenced by 1ec626f4bd
This issue was referenced by 1ec626f4bd06e830edc13a8a6986eec2885499dd
Thomas Dinges added this to the 2.93 LTS milestone 2023-02-07 18:46:34 +01:00
Reference: blender/blender#85549
