Wintab crash on window close. #85799
6 Participants
Reference: blender/blender#85799
Operating system: Windows 10
Graphics card: Nvidia Quadro P5000
Broken: 2.91.2
Worked: N/A
OBJ Importer crashes while attempting to import OBJ file.
Steps to reproduce:
Actual Behavior:
Blender crashes.
Expected Behavior:
The OBJ file is imported successfully.
testPM3D_Sphere3D1.zip
Added subscriber: @mendezcode
#86039 was marked as duplicate of this issue
Added subscriber: @StephenSwaney
Imports fine here. Linux 2.92.0 RC and 2.91.2
I suspect a local problem.
Any interesting error messages?
Seems like it's something with my system... You know what... I should've provided you with more debugging info, my bad.
Here's what I get when I run it from the console:
Update: I have installed the latest GPU drivers, but it seems this is related to the tablet drivers (based on searches for wintab32.dll)... I do use a tablet screen, so I think this may have something to do with Wacom's drivers or something...
Sooo.... I was able to fix it! This actually is not a localized problem but it does seem like a bug.
I was able to import fine after setting the Tablet API to "Windows Ink" on Preferences > Input.
That being said, this doesn't seem to be a bug with the OBJ importer per se, but this highlights another possible bug which involves Blender crashing when using "WinTab" as tablet API for some reason.
In any case, I'm glad it's solved, thanks again!
Added subscribers: @PrototypeNM1, @ankitm
CC @PrototypeNM1
Changed status from 'Resolved' to: 'Confirmed'
What's happening here is that while the window is being destroyed, it closes the Wintab context via WTClose. The Wintab library must be calling one of the Win32 functions which allows callbacks to the Windows event loop to run, which calls an event which uses Wintab after it's closed and while Ghost's window is half torn down.The solution here is to not trust Wintab when tearing down the window to not reenter, and close before the GHOST_WindowWin32's destructor. Reopening as this is a legitimate issue.Edit: The issue is reentrancy while GHOST_WindowWin32 is being torn down, but it's not Wintab that triggers it, Wintab being passed a closed context is just the last step. Looks like it's the call to DestroyWindow from the stack trace.
Edit2: Without logging with the specific device, it could be quite difficult to narrow down the exact cause. E.g. it could be that the Wintab library is not handling multiple contexts for a single process correctly and thus closing the wrong one, or reentrancy is causing a half-destroyed window with closed Wintab context to crash.
Added subscribers: @kamiyu1031, @rjg
OBJ Importer Crashto Wintab crash on window close.@mendezcode @kamiyu1031 Could you recreate the crash in this build, copy the content of blender_debug_output.txt to this link, and link the result here?
Changed status from 'Confirmed' to: 'Needs User Info'
@PrototypeNM1 Tested and crash persists, here's the paste: https://developer.blender.org/P2009
Could you upload
C:\Users\mdz\AppData\Local\Temp\blender.crash.txt
?Changed status from 'Needs Triage' to: 'Needs User Info'
@mendezcode Could you confirm is the issue is still present in current daily builds ? There were a lot of recent changes with how Wintab opened and closed in Blender which should resolve any issues.
@PrototypeNM1 tested and the issue is no longer present, it has been fixed.
Changed status from 'Needs User Info' to: 'Resolved'
