Blender Crashes repeatedly when modifying particle system #86283
Reference: blender/blender#86283
Operating system: Darwin-19.6.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.18
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
Worked: this was happening on 2.91.x and I downloaded the newest version to see if the issue was resolved. I occasionally get farther through the troubleshooting steps below, but functionally cannot use this scene.
Blender Crashes completely. This has happened when adding a particle system to a plane, modifying an existing particle system on the same plane, or modifying the second particle system if I manage to get through the process of adding it without a crash.
The crash has happened repeatedly and incredibly consistently, though sometimes happens earlier in the steps and sometimes later.
at no point has my computer's ram been more than 20-30gb out of 64 used. rarely if ever have the fans been on to indicate that the machine was working hard. the file is quite small (~1mb) and while there may be some optimizing, much larger files (~200mb) are running perfectly using similar particle systems and shaders.
Added subscriber: @ryryryan
peaceful-scene.blend
2021-03-04-Started-naming-second-particle-system-on-a-plane-2.txt
2021-03-04-crashed-attempting-to-grab-particle-in-system.txt
2021-03-04-crash-attempting-to-edit-clumping-ratio.txt
2021-03-04-Started-naming-second-particle-system-on-a-plane.txt
2021-03-04-crash-attempting-to-add-particle-system-to-a-plane.txt
attached are copied and pasted crash reports from macOS, several on blender 1.91.x and several on 1.92 and a copy of the file described in the troubleshooting steps.
Added subscriber: @filedescriptor
I was not able to reproduce this on 2.93 nor 2.92.0 on Linux.
Looking at the crash logs, it seems that the error is related to viewport EEVEE rendering. Try switching to cycles and see if the issue persists to narrow down the problem.
Another thing I noticed is that in your file there is a driver with an invalid expression:
Maybe that could be the issue (less likely). But try removing that driver and see if it helps.
Added subscriber: @lichtwerk
