Improve: Curve Mesh discontinuity with varying point radii #86389
Reference: blender/blender#86389
I'm creating an animated ribbon gradient for my logo using splines and generated geometry. The ribbon is tapered at the ends by making the radii at the endpoints smaller to achieve the look; but I've ran into and issue with the generated mesh.
Issue
When creating a mesh from a curve using the geometry options, with varying point radii, the generated mesh becomes discontinuous at the point regions.
Steps to Reproduce
Increase the U resolution from the Bezier Curve Data panel to see the effects at an extreme.
Possible Solution:
Have an option under the geometry section of the curve data properties that when active, will produce a mesh tangent to the curve handles. Or even an option to blend between the two states to get the desired output.
See attached images:
curve-mesh-discontinuity-proposed-improvement.blend
Updated: I'm not sure if discontinuity is the best word to use as all discrete meshes are discontinuous but I think you'll see the issue. If you look at the close up. the top vertex is higher than it ideally should be. The adjacent edge should either be horizontal or sloping upwards from left to right.
Added subscriber: @JamellMoore
Added subscriber: @ankitm
Could you add the exact steps to create the curve and the meshes ?
Also, do you intend to add a patch, and are waiting for input from modeling team ?
I did have a brief look at the code at the time of original submission and was intended to experiment to see if this could be improved ,but unfortunately I haven't had the time to look into any further.
My original idea wouldn't work but I do believe that the continuity could be improved by introducing some kind of easing to the mesh radius around the points.
I highly doubt that I'm going to be able to pursue this any time soon so feel free to close the task.
Added subscriber: @lichtwerk
You can already use a different interpolation method than
Linear
[which is the default I believe] for Radius and Tilt.in the Properties Editor:
#86389.webm
Dont think there is a bug here [or even a patch to submit], everything working as expected here.
Will close, but feel free to comment again if issues persist.
Thanks for taking the time to point out the interpolation settings Philipp. I'm not sure how I missed those. That's what I was looking to implement but it's already be done, so yeah issue solved.
