collapse at the moment of opening the file #86518
Reference: blender/blender#86518
Operating system: 3.5 GHz 4-core Intel Core i5 processor 40 GB 2400 MHz DDR4
Graphics card: Radeon Pro 575 4 ГБ
Version 2.92.0 (2.92.0 2021-02-25)
crash when I open a file
the file did not open for me. i used this help
https://developer.blender.org/T86300#1128503
After rebuilding I am working in Scene. 001 I saved this project under a different name and continued working. Blender crashed several times and today I again cannot open the project !!!! I try to open the scene 001 through append, but the blender collapses. I'm in a panic and I'm disappointed.
icons1.blend
Added subscriber: @Dmitry13
Added subscriber: @filedescriptor
The steps I gave in that report won't fix the file. The steps allow you to Append the file into the default startup file, then the script tries to fix the corrupted meshes in "Scene.001". You would have to then save out the data yourself.
If the scene you append is not called
Scene
then you don't want to use that script. This one is a bit more generalized:Let me know if this works.
Added subscriber: @lichtwerk
Since not much time has passed since the last corruption, this might be a chance to try to figure out what might be the cause.
@Dmitry13 : can you describe what you have done with
Cylinder.003
?What I mean is: what modeling tools do you use? Extrude Manifold? please try to remember each tool used here.
The object has not been imported, right? If it was: which importer/format?
It is also interesting which tool options you used, for example, was this turned ON?
Did you use modifiers (and applied them)? which ones?
I have simple shapes, I make icons. the problem was that I copied an object from another project to a new project that "broke". This item has not been checked.
Now I have restored everything manually and will continue to be attentive. Thank!
This means {key Ctrl C} in one instance of blender and {key Ctrl V} in another instance of blender, right?
Were these the same versions of blender? Both 2.92? If not: which versions were involved?
Could you share the .blend file were you pasted from? which object?
This information would really help quite a lot, thx in advance!
YES!
safe.blend
I copied this object.
icons1.blend
problem file
all problems with one version 2.92?
Cannot spot issue when copy-pasting.
So we are still hunting the cause of the corruption.
Now the most interesting part would be to figure out:
(btw. if you having problems with appending scenes that have corruptions, then you might try a fresh 2.93 build from https://builder.blender.org/download/, this has a fix for #85947 (objects from appended scenes are added to current scene as well (if they are directly under the Scene Collection in the source file)) and thus will not pull your corrupted mesh into your current scene -- which in turn would crash)
I didn’t use any add-ons in icon design. I don't have anything from third-party plugins. I recently started to study the blender and use exclusively all the native tools for changing the geometry.
But the problem I had only when I copied.
By the way, in the scene with the safe, I later made corrections and ungrouped the elements. Sorry, I forgot completely =)
I'll try a new build. Thank!
Thx getting back.
OK, good to know
do you simply mean in terms of collections? parenting? or is separating meshes involved? likeMesh
>Separate
>Selection
/Material
/Loose Parts
?I don't understand what is happening at all = (
The file that I restored manually (((( does not open again and the blender collapses
backicon.blend
command+j I combine the shapes like this
and I separate it like this, I go into the edit mod, select what I need to separate and press P → Selection
and the new assembly crashes when trying to open the file
opened with a script. did not find any damaged mesh.
OK, I have the feeling we are getting closer.
Trying to reproduce this (still cant):
Which parts were joined, and then which parts were separated?
(in
backicon.blend
theCube.006
mesh is now corrupted)and here it is again! )))) I worked, went to have lunch, but I tried to do something as the program crashed (it always happens) and I can no longer open the file.
I separated the door at the safe. The doors had hinges, a lock and a steering wheel
icons.blend
icons.blend1
здесь коллекция INVEST приводит к сбою программы. все в этой коллекции сделано с нуля! Я ничего не копировал. Это конечно очень печально! Сожалею, что начал изучать блендер ... Худший опыт в моей жизни!
This comment was removed by @Dmitry13
sad to hear, I will try to investigate more on this separating issue (but still wasnt able to reproduce)
Blender also collapses after a long inactivity and the project that was opened can be damaged after the collapse. This is not the first time this has happened to me.
incredible horror and not a program !!! crashes and destroys individual meshes inside. SUCKS !!!
https://take.ms/YyMO4 I have no words! there are no words!!!! this is the most disgusting thing that can only be
Still trying to help.
(think we could tone down the language though, no? swearing is not how we talk to each other around here...)
regarding https://www.dropbox.com/s/z4qqynlexjjemb3/Blender%202021-03-16%2017-37-31.png:
Terribly sorry, but since we cannot really put together a recipe for reproduction steps, this will have to be archived for now.
