Add Primitive tool initial snap does not work with custom keymap #86888
Reference: blender/blender#86888
Graphics card: GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.92.0, branch: master (modified), commit date: 2021-02-24 16:25, hash:
02948a2cab
When using custom keymap, it is impossible to snap using Add Primitive tool at the start of primitive creation. This is not an issue of the customized keymap due to following reasons:
1, The Tweak Left Any action is properly defined in the Add Primitive tool context, so it should always override any bindings above in the hierarchy. It is also set up identically to the default keymap:
2,
Even after manually disabling all the Tweak Left Any bindings above in the 3D view hierarchy, the snapping still doesn't work.
Apparently, somewhere, something in the Add Primitive tool is hardcoded to only work with they default keymap layout.
1, In a Blender installation with default settings, import this keymap: SimpleKeymap.py
2, Enter Add Primitive (Cube) tool
3, Hold down Ctrl key and hover around the default cube
Result: Snap circle doesn't show, indicating initial snapping does not work. This happens despite the fact that the Add Primitive Tool context keymap is set up identically to the default, stock one:
Expected: Snap circle shows, indicating snapping works.
Added subscriber: @Rawalanche
Added subscriber: @filedescriptor
I took a look at this, but don't fully understand what is going on. In my testing, I couldn't change the default keymap at all. Changing the snap on/off to another key would still toggle with Left Ctrl. But looking at the code, everything seemed fine to me. I will come back to this again later.
Added subscriber: @mano-wii
Well, this setting changes the value of
gizmo_tweak
in "Generic Gizmo" (which is used by some gizmo):So with the new confirmation,
Ctrl + click
does not activate the tool operator, so there is no reason to show the gizmo since it has no more effect.Can you tell me where I can find the Generic Gizmo section in the brutally bloated keymap list? I can only find it using search, but it's impossible to find the actual category it resides in through the user interface.
Even after disabling all the generic gizmo related bindings the snap still does not work, so please reopen this task and verify that removing the binding actually solves the bug:
Blender's default keymap has generic gizmo also bound on left mouse and the primitive tool snap works there, so it's definitely not the root cause of the issue:
Activate Any, so it doesn't matter if a modifier (Ctrl, Alt, Shift ...) is pressed or not. So the gizmo can be activated with click and any key modifier.
Disabling is worse.
Hi,
you still have not answered my question about where can I find the "Generic GIzmo" category within the UI tree:
Also, this is probably still a bug because this was not updated for existing keymap user has migrated from previous Blender version. There is no reason that should not happen.
So ultimately this ends up with a buggy situation where the existing keymaps are corrupted, and the user can not easily find a solution to the problem through the user interface.
I understand that the keymap system needs many improvements.
But not finding a keymap and losing settings when importing old keymaps are different problems and therefore must be reported separately.
I'm not sure about the other one, but not finding a keymap has already been reported in #84510 (Keymap manager - Missing entries for node tools).
