OpenVDB files don't appear in Cryptomatte, Object ID or Material ID #86984
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
7 Participants
Reference: blender/blender-manual#86984
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
blender/blender@02948a2cab
Imported OpenVDB volumetrics aren't recognized by Cryptomatte, Object ID or Material ID nodes in the compositor.
Import a VDB file.
Import a second VDB file.
Set a material for each
Give each material a unique ID
Give each VDB a unique pass ID
Enable Cryptomatte Object, Material and Asset passes
Enable Compositing Nodes
Render
Add a Cryptomatte node and hook it up.
Check to see if the Cryptomatte recognizes the VDB files. It does not.
Add an ID Mask node.
Connect the viewer and see if the Object ID or Material ID show up. They do not.
In essence, there is no way to isolate VDB files in post. It seems that the only way to isolate a VDB in your scene is to render it separate from everything else. If you have dozens of volumetric cache files, this become burdensome to set up the render.
Added subscriber: @stevewarner
Added subscriber: @ankitm
Could you add a simple blend file ?
I created one but can't move past "Add a Cryptomatte node and hook it up."
fluid_data_0009.vdb
fluid_data_0001.vdb
T86984_.blend
Added subscriber: @triget
Any news about this feature?
Added subscriber: @OmarEmaraDev
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I can replicate that. But as far as I can tell, Cycles doesn't write such data passes when integrating volumes, this includes cryptomatte and mask IDs, so this may not be a bug.
Tagging a module for a more informed decision from developers.
Added subscriber: @Jeroen-Bakker
To my knowledge this isn't supported. Eevee only supports volumetrics to calculate coverage. Cycles doesn't support volumetrics with cryptomatte. We could elaborate this in the manual.
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
The documentation should be updated as mentioned, but we do not consider this to be a bug in Blender.
You can use other channels for suggestions and feature requests: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
Appreciate the heads up. I'll make the request on the other channel. I think this is an important issue, as the ability to isolate volumetrics in your render passes is critical for VFX.
Added subscriber: @Blendify
Made some documentation changes here: rBM9104
