Entry AREA_PLANE
is not a valid property for map_mode
in class bpy.types.BrushTextureSlot(TextureSlot)
#86986
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#86986
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.09
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-03-26 21:30, hash:
blender/blender@9b87d3f029
Worked: Same happens at least as far as 2.91.0. Tested on 2.92.0 as well, same result.
Entry
AREA_PLANE
is not a valid property formap_mode
in classbpy.types.BrushTextureSlot(TextureSlot)
bpy.data.brushes- [x].texture_slot.map_mode = 'AREA_PLANE'
TypeError: bpy_struct: item.attr = val: enum "AREA_PLANE" not found in ('VIEW_PLANE', 'TILED', '3D', 'RANDOM', 'STENCIL')
, even though the documentation states that map_mode should beenum in [‘VIEW_PLANE’, ‘AREA_PLANE’, ‘TILED’, ‘3D’, ‘RANDOM’, ‘STENCIL’], default ‘TILED’
Added subscriber: @Naoki
Added subscriber: @filedescriptor
It seems as though the problem is that the
EnumProperty
map_mode
usesrna_enum_brush_texture_slot_map_all_mode_items
which is defined as:but if the active paintmode is not
PAINT_MODE_SCULPT
then it usesrna_enum_brush_texture_slot_map_texture_mode_items
which is defined as:(notice
AREA_PLANE
is not defined). So my take from this is that it is most likely not a bug, but not documented correctly (probably due to the documentation being mostly auto-generated).Changed status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @ideasman42
Closing, since there are many enum's that have values that change depending on other settings.
The documentation to address this would likely need to be general since this happens in many places.
