Mantaflow error when using blender in background mode #87828
Closed
opened 2021-04-26 14:21:18 +02:00 by Robin Schyboll · 9 comments
Operating system: Linux-5.11.16-arch1-1-x86_64-with-arch-RebornOS-release 64 Bits
Graphics card: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 465.24.02
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: 02948a2cab, also broken ce64cfd6ed
When running blender in background mode, or as a python module, and opening a .blend file through a python script with a Mantaflow simulation, it throws the following error:
terminate called after throwing an instance of 'Manta::Error'
  what():  can't clean grid cache, some grids are still in use
Error raised in extern/mantaflow/preprocessed/fluidsolver.cpp:33
T87828_assertandexception.txt
  • Create a default scene with a quick smoke example, and save it to a .blend file
  • Create a python script with the following content:
import bpy
bpy.ops.wm.open_mainfile(filepath=".blend file path")
  • Launch blender with the following command:
blender -b --python script.py
Similar issues
I encountered issues with similar errors, but i submitted a new one because of a different way of triggering that error:
#87021 (Program Close after free data liquid simulation)
#80154 (Mantaflow rendering unstable (when using multiple fluid domains))
#87975 (Mantaflow simulation stops and crashes at the end of the bake (or when closing blender): The CG solver diverged, residual norm > 1e30, stopping.)
slightly old one blender/blender-addons#75889 (Mantaflow problem when baking via Python API)
Additional information
I did encounter another error, when using blender as a python module, which may or may not be related to this issue, i can't tell really.
After building blender and installing it as a module to my python venv, when launching the same script as before, i get the same error when exiting the script.
But when loading the file, i get another error:
  File "<string>", line 107, in <module>
AttributeError: 'LevelsetGrid' object has no attribute 'setConst'
  File "<string>", line 1, in <module>
  File "<string>", line 130, in smoke_load_data_1
NameError: name 'fluid_data_dict_final_s1' is not defined
TypeError: 'NoneType' object is not callable
I can't really tell, if i'm doing something wrong, or if it is some kind of bug, but when using blender as a python module, i cannot render any fluid sims, they just disappear in the render output.
I found that someone had a similar issue on devtalk, but the topic was not continued:
Devtalk: 15460
When using blender normally in background mode, i am able to render it, but still, the error exists in both cases, the second one only when using as a python module, can't really tell if they are related.
**System Information** Operating system: Linux-5.11.16-arch1-1-x86_64-with-arch-RebornOS-release 64 Bits Graphics card: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 465.24.02 **Blender Version** Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: `02948a2cab`, also broken ce64cfd6ed **Short description of error** When running blender in background mode, or as a python module, and opening a .blend file through a python script with a Mantaflow simulation, it throws the following error: ``` terminate called after throwing an instance of 'Manta::Error' what(): can't clean grid cache, some grids are still in use Error raised in extern/mantaflow/preprocessed/fluidsolver.cpp:33 ``` [T87828_assertandexception.txt](https://archive.blender.org/developer/F10194218/T87828_assertandexception.txt) **Exact steps for others to reproduce the error** - Create a default scene with a quick smoke example, and save it to a .blend file - Create a python script with the following content: ``` import bpy bpy.ops.wm.open_mainfile(filepath=".blend file path") ``` - Launch blender with the following command: ``` blender -b --python script.py ``` **Similar issues** I encountered issues with similar errors, but i submitted a new one because of a different way of triggering that error: #87021 (Program Close after free data liquid simulation) #80154 (Mantaflow rendering unstable (when using multiple fluid domains)) #87975 (Mantaflow simulation stops and crashes at the end of the bake (or when closing blender): The CG solver diverged, residual norm > 1e30, stopping.) slightly old one blender/blender-addons#75889 (Mantaflow problem when baking via Python API) **Additional information** I did encounter another error, when using blender as a python module, which may or may not be related to this issue, i can't tell really. After building blender and installing it as a module to my python venv, when launching the same script as before, i get the same error when exiting the script. But when loading the file, i get another error: ``` Traceback (most recent call last): File "<string>", line 107, in <module> AttributeError: 'LevelsetGrid' object has no attribute 'setConst' Traceback (most recent call last): File "<string>", line 1, in <module> File "<string>", line 130, in smoke_load_data_1 NameError: name 'fluid_data_dict_final_s1' is not defined Traceback (most recent call last): File "<string>", line 1, in <module> TypeError: 'NoneType' object is not callable ``` I can't really tell, if i'm doing something wrong, or if it is some kind of bug, but when using blender as a python module, i cannot render any fluid sims, they just disappear in the render output. I found that someone had a similar issue on devtalk, but the topic was not continued: [Devtalk: 15460 ](https://devtalk.blender.org/t/python-module-bpy-mantaflow-issues-after-successful-build/15460) When using blender normally in background mode, i am able to render it, but still, the error exists in both cases, the second one only when using as a python module, can't really tell if they are related.
Author
Added subscriber: @hoodrobinrs
Member
Member
Added subscriber: @ankitm
Member
Before I got the 'Manta::Error', there was an assert (stack in F10194218) so after disabling WITH_ASSERT_ABORT, the issue can be redone.
Before I got the `'Manta::Error'`, there was an assert (stack in [F10194218](https://archive.blender.org/developer/F10194218/T87828_assertandexception.txt)) so after disabling `WITH_ASSERT_ABORT`, the issue can be redone.
Mantaflow (fluid simulator) has no active developer at the moment. Moving those reports as known issues so at least other users can find their issues already reported.
Member
Added subscriber: @SonnyCampbell_Unity
Member
I believe this issue will be fixed by https://developer.blender.org/T98427 which is currently waiting for review
Member
Sonny Campbell self-assigned this 2022-06-24 16:14:23 +02:00
Member
This issue should be resolved in master by https://developer.blender.org/D15269
Reference: blender/blender#87828
