It's almost Impossiable to Download Blender manual #87882
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#87882
Pagename:
index
Blender Version:
2.92
Documentation Language:
en
Permanent link
When I download the blender doc file in epub format it download some megabyte and then failed. I have 10mbps connection and I never able to download the blender manual. So I requested that make manual download pause/resume-able.
Pls allow Accept-Ranges: bytes on response header of manual download.
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Added subscriber: @devbapidey
How does 'resume download' work?
Added subscriber: @dmcgrath
Removed subscriber: @devbapidey
We should be supporting range already (we don't actively prevent it). I can pause and resume the epub download in Chrome just fine here while throttling the download to 3G speeds, as well:
If I interrupt the download and cause a network error, I can resume it as well in chrome:
Added subscribers: @devbapidey, @ankitm
As a workaround, use
wget -c "https://docs.blender.org/manual/en/2.92/blender_manual_epub.zip"
if available on your OS.@dmcgrath both Safari and Firefox on macOS fail to resume download from the stopping point.
Brave (chromium fork) however does resume.
Changed status from 'Needs Developer To Reproduce' to: 'Needs Triage'
Added subscriber: @Blendify
I can confirm that also, chrome works but firefox doesn't
firefox not work, I use wget -c.
Since we support Accept-Ranges, perhaps this should be closed?
Although I am curious as to why Firefox doesn't work, but Chrome and and wget do. I did find a post that might help.
I also noticed that pause/resume fails on Firefox:
Maybe also take a look at: https://support.mozilla.org/bm/questions/1220917
Yes I will close this, I don't think there is anything more we can do from our side.
If relevant: downloads that Safari can resume show
foo MB of bar MB downloaded
, but for the manual, it showsfoo MB of ? downloaded
.Can you show the headers you received (F12?) for that URL so that I can compare to ours?
Collected from Brave and FF because couldn't find that in Safari.
Brave:
FF:
I see you have a
as well.My tests, as per: https://linux.goeszen.com/apache-and-byte-ranges-for-resumable-downloads.html
I also think we should close this. With a note on doc( if possible ) that 'Firefox download not resume able'.
This is Response Headers of my firefox browser.
I am not really sure about it. But I think Transfer-Encoding might cause problem as Content-Length is omitted ( more info on here ).
Seems that we were zipping a zip file, which starts sending the content before knowing the size, thus was chunked.
I disabled gzip for .zip files which seems to work properly in Firefox now.
Thanks for the report!
