Auto Keying with "Only Active Keying Set" creates keyframes it shouldn't #88066
Reference: blender/blender#88066
Graphics card: Radeon RX 580 Series ATI Technologies Inc. 4.5.13596 Core Profile Context 20.10.35.02 27.20.1034.6
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-04-02 21:26, hash:
321eef6a0c
Worked: (unknown)
If you have Auto Keying enabled with "Only Active Keying Set", Blender creates keyframes for properties that aren't in the keying set, and creates keyframes for properties in the set when changing properties that aren't.
Added subscriber: @Matthew-Hinson
In general, I also find it a bit strange that while predefined keying sets create keyframes for the selected objects, custom keying sets create keyframes for specific objects regardless of what's selected. Would it make sense to allow custom keying set properties that have no target object and consist only of a data path (which then gets resolved at keyframe creation time based on whatever is selected)? If yes, I could create a separate ticket for that.
Added subscriber: @lichtwerk
This seems to be a limitation of custom KeyingSets in blender atm.
https://docs.blender.org/manual/en/latest/animation/keyframes/keying_sets.html
These custom KeyingSets are always absolute, meaning you have to specify an individual ID (in you case the ID Type is of type Object, so you would have to pick a specific object for this to work)
This has been reported before, see #86961 (A bug in a scene. "i" does not work for creating keyframes)
While I also think this is pretty limiting (what you suggest makes total sense in my opinion), it would not be considered a bug atm.
For the rest, I can confirm all of it
Added subscriber: @dr.sybren
This I cannot reproduce in the 3.0 release branch (
68e86c4816
). For me it doesn't create the keyframes for the shape key Value or for the Range Min property.This is the file I use for testing, which has a cube, with shapekeys (Basis + Key 1), auto-keying enabled, current frame set to 10, but nothing keyed just yet.
#88066-auto-keying-only-active.blend
This I cannot reproduce; just like above, this doesn't create a key for me.
This I can reproduce. Autokeying is implemented in a bit of a weird way, and "run autokeying now" is something that needs to be explicitly called. The transform tools are the ones that do this call, which is why moving the cube causes the creation of the key (just like you'd get when pressing {key I} in the viewport).
Autokeying works even without changing the target properties. For example, disable the "Only Active Keying Set" option again so that it's free to key whatever. Then press {key G} to start translating the cube, and without moving the mouse (so without changing any of the cube's transform properties), press {key Enter} to confirm this "no-op transformation". This will create transformation keys, even though the values haven't changed.
This is for the same reason. The transform tool runs the "autokey now" code, which can succesfully create a key for the property in the keying set.
I understand this is confusing -- it confuses me as well. Autokeying is a limited feature, that was intended mostly for animating objects & poses, so it's mostly integrated just with the transform tools. This is something to improve, but as far as I can see it's working as designed (just in a rather limited way). This is not something that's easily solved, as it really needs a redesign of the autokeying system. Because of this, I'll close this report. I do reference it from my Weak Areas of the Animation System wiki page, as I don't want this to be forgotten.
