Grease pencil : masked layers bring their mask dependencies in in their own view layer #88202
5 Participants
Reference: blender/blender#88202
Operating system: Linux-5.4.0-58-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.32.03
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
The layers that have masks active bring their "mask dependencies" with them in the render view layer, where we want only whats in the layer.
In provided example file, hit render image then check the compositing nodes.
The shadow layer is on it's own on the
shadow
view_layer, so we expect to get only this layer content without any other appearing (and preferably unmasked).But the
color
layer also appear on it.In some cases, I suppose user you would want it to be masked (meaning, mask "applyed"). BUT, in a production logic, it's way better to have just the plain, unmasked, layer content (just hiding other layer at view_layer render time) to be able to tweak things in internal/external compositor afterwards.
In any case, user never want to see strokes of layers that aren't on the view layer, as it does now.
Blend:
view_layer_masking_issue.blend
Issue
expected result
Added subscriber: @Pullup
Added subscriber: @filedescriptor
I can confirm this issue in the latest 3.0.0 Alpha.
Added subscriber: @iss
I would say that this works as documented - see https://docs.blender.org/manual/en/dev/grease_pencil/properties/masks.html
For comment that suggests layers to be rendered without masks, this would imply that compositing would be done as final stage of rendering and not part of layer itself. Looking at code it seems that part of layer drawing is applied mask. So to me this raher sounds like feature request.
This worked as @Pullup expects in 2.82 though.
@iss Not sure what explains the results seen in the report in the documentation you linked?
In
BKE_gpencil_visible_stroke_iter
after checking if a viewlayer is used, we include mask layers deliberately (even if they shouldn't be, since they are a different layer). The comment states:Which is correct, the renderer will try to mask the layer using the mask, which it can't find if it is skipped - and then crash. But this means we render the mask, even if it is not part of the layer. IMO this should not be the case.
It says
If you want to make a full transparent masking you will have to set the mask layer(s) opacity to 0.
which implies that mask becomes part of layer, that uses this mask.In any case I would deffer this to developers that know how this should work at this point.
@iss I see what you are saying now. I think this is still an issue because you cannot render that layer if it's used as a mask and you have to turn the opacity off. But then it's also debatable if we consider this a bug or not.
Added subscriber: @antoniov
We are assuming here the Samuel request is the way to go....and I'm not sure...maybe for some users it's the way to go, but for others no and they expect to filter only the main layer and consider masking list as attributes of the current layer.
Edit: But I'm not against the change...just want to be sure we do the right one.
The described expected behavior differs from patch. By expected behavior I understand render primitive shapes and let compositor take over actual compositing. What can go wrong is that you want to use complex layer with 100 masks applied in total. You don't want to reconstruct that in compositor once again. On the other hand you may want to use some layers in compositor clean without masks, but you don't want to duplicate them and maintain them separately over long time.
So IMO it would be best if you could choose layer behavior for rendering.
I agree with @iss, having the choice would be the best solution since both cases can actually happen.
A user might want to have his multiples masks applied on the layer directly at render, and more advanced users would want to have control over the compositing of the layers.
But in both cases, you just never want to see the "only used for masking" layers (except if they are deliberately added in this view layer), so in this regard the patch is already a blessing :).
Maybe we could add an option to enable new filtering mode and keep both methods:
@antoniov I thought about that too. Maybe a checkbox "Disable Masks in Viewlayer"? And it would be a setting at the layer level? (Grayed-out when Viewlayer is empty)
Yes, by layer and the name is OK...we can change it later.
Ok, I think I can make that work.
Updated the "Fix" to a patch since it adds a new option to the Relations panel in the Layer properties.
Now you can disable the masking for the view layer render.
This issue was referenced by
d5a5575685
Going to mark this as resolved now. The commit
d5a5575685
fixes the problem of the mask showing in the view layer render (2.93). And the patch D11234 will add the option to disable masks in the render entirely (3.0.0).This issue was referenced by
e459a25e6c
