2.93 ARM64 Beta Crashes from startup on MacOS 11.4 Beta #88212
Closed
opened 2021-05-12 04:04:27 +02:00 by Yuseong Kim · 2 comments
2.93 ARM64 Beta gets crashes on startup on MacOS 11.4 Beta + MacBookPro M1 base model.
Specific build version is current daily build. April, 19-2.93.0-c75b2019e101.
By the way, official build 2.92 works fine.
and here's the full crash log.
Process:               Blender [9332]
Path:                  /Applications/Blender.app/Contents/MacOS/Blender
Identifier:            org.blenderfoundation.blender
Version:               2.93.0 (2.93.0 2021-04-19)
Code Type:             ARM-64 (Native)
Parent Process:        ??? [1]
Responsible:           Blender [9332]
User ID:               501
Date/Time:             2021-05-12 10:50:23.812 +0900
OS Version:            macOS 11.4 (20F5046g)
Report Version:        12
Anonymous UUID:        DC7A5F50-5974-E457-91C2-D11DB53F8EE6
Sleep/Wake UUID:       82DBE68B-D77D-46F5-A871-E712D3DB131E
Time Awake Since Boot: 31000 seconds
Time Since Wake:       2100 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
terminating with uncaught exception of type boost::locale::conv::conversion_error: Conversion failed
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	0x0000000191cf0e48 __pthread_kill + 8
1   libsystem_pthread.dylib       	0x0000000191d2343c pthread_kill + 292
2   libsystem_c.dylib             	0x0000000191c6b4e0 __abort + 116
3   libsystem_c.dylib             	0x0000000191c6b46c abort + 116
4   libc++abi.dylib               	0x0000000191ce1b44 abort_message + 132
5   libc++abi.dylib               	0x0000000191cd2e3c demangling_terminate_handler() + 284
6   libobjc.A.dylib               	0x0000000191bcbca4 _objc_terminate() + 160
7   libc++abi.dylib               	0x0000000191ce0f2c std::__terminate(void (*)()) + 20
8   libc++abi.dylib               	0x0000000191ce3c0c __cxxabiv1::failed_throw(__cxxabiv1::__cxa_exception*) + 36
9   libc++abi.dylib               	0x0000000191ce3bb8 __cxa_throw + 140
10  org.blenderfoundation.blender 	0x000000010912f184 std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > boost::locale::conv::impl::iconverter_base::real_convert<char, char>(char const*, char const*) + 528
11  org.blenderfoundation.blender 	0x000000010912e2e8 boost::locale::conv::impl::convert_between(char const*, char const*, char const*, char const*, boost::locale::conv::method_type) + 144
12  org.blenderfoundation.blender 	0x000000010913897c boost::locale::gnu_gettext::mo_message<char>::load_file(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, int, boost::function<std::__1::vector<char, std::__1::allocator<char> > (std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)> const&) + 1608
13  org.blenderfoundation.blender 	0x00000001091378e4 boost::locale::gnu_gettext::mo_message<char>::mo_message(boost::locale::gnu_gettext::messages_info const&) + 2452
14  org.blenderfoundation.blender 	0x0000000109136edc boost::locale::message_format<char>* boost::locale::gnu_gettext::create_messages_facet<char>(boost::locale::gnu_gettext::messages_info const&) + 36
15  org.blenderfoundation.blender 	0x0000000109161434 boost::locale::impl_posix::posix_localization_backend::install(std::__1::locale const&, unsigned int, unsigned int) + 1684
16  org.blenderfoundation.blender 	0x0000000109133b88 boost::locale::generator::generate(std::__1::locale const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) const + 440
17  org.blenderfoundation.blender 	0x000000010913399c boost::locale::generator::generate(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) const + 68
18  org.blenderfoundation.blender 	0x00000001034f4168 bl_locale_set + 360
19  org.blenderfoundation.blender 	0x0000000102811994 BLT_lang_set + 240
20  org.blenderfoundation.blender 	0x00000001027bef64 WM_init + 224
21  org.blenderfoundation.blender 	0x00000001023c8d74 main + 808
22  libdyld.dylib                 	0x0000000191d41420 start + 4
Thread 1:
0   libsystem_kernel.dylib        	0x0000000191ce8df0 semaphore_wait_trap + 8
1   libdispatch.dylib             	0x0000000191b743f8 _dispatch_sema4_wait + 28
2   libdispatch.dylib             	0x0000000191b74abc _dispatch_semaphore_wait_slow + 132
3   org.blenderfoundation.blender 	0x0000000106f7609c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64
4   org.blenderfoundation.blender 	0x0000000106f74ca4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64
5   libsystem_pthread.dylib       	0x0000000191d23878 _pthread_start + 320
6   libsystem_pthread.dylib       	0x0000000191d1e5e0 thread_start + 8
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
0   libsystem_pthread.dylib       	0x0000000191d1e5cc start_wqthread + 0
Thread 10:
Thread 11:: AMCP Logging Spool
1   com.apple.audio.caulk         	0x0000000199a99934 caulk::mach::semaphore::wait_or_error() + 28
2   com.apple.audio.caulk         	0x0000000199a836e0 caulk::semaphore::timed_wait(double) + 168
3   com.apple.audio.caulk         	0x0000000199a835cc caulk::concurrent::details::worker_thread::run() + 44
4   com.apple.audio.caulk         	0x0000000199a8330c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 96
Thread 12:
0   libsystem_kernel.dylib        	0x0000000191ce8e08 semaphore_timedwait_trap + 8
1   libdispatch.dylib             	0x0000000191b74474 _dispatch_sema4_timedwait + 64
2   libdispatch.dylib             	0x0000000191b74a84 _dispatch_semaphore_wait_slow + 76
3   libdispatch.dylib             	0x0000000191b85430 _dispatch_worker_thread + 304
4   libsystem_pthread.dylib       	0x0000000191d23878 _pthread_start + 320
5   libsystem_pthread.dylib       	0x0000000191d1e5e0 thread_start + 8
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 0 crashed with ARM Thread State (64-bit):
    x0: 0x0000000000000000   x1: 0x0000000000000000   x2: 0x0000000000000000   x3: 0x0000000000000000
    x4: 0x0000000000000000   x5: 0x0000000000989680   x6: 0x0000000000000064   x7: 0x0000000000000300
    x8: 0x4973dfb0b4699048   x9: 0x4973dfb1a5f76d08  x10: 0x00000000000003e8  x11: 0x0000000000000004
   x12: 0x0000000000000000  x13: 0x0000000000000001  x14: 0x0000000000000010  x15: 0x0000000000000000
   x16: 0x0000000000000148  x17: 0x0000000200c1ee90  x18: 0x0000000115b273bc  x19: 0x0000000000000006
   x20: 0x00000001119efd40  x21: 0x0000000000000103  x22: 0x00000001119efe20  x23: 0x0000000149643660
   x24: 0x0000000000000040  x25: 0x000000016dbd3088  x26: 0x0000000000000002  x27: 0x000000000000005c
   x28: 0x0000000000000030   fp: 0x000000016dbd2a90   lr: 0x0000000191d2343c
    sp: 0x000000016dbd2a70   pc: 0x0000000191cf0e48 cpsr: 0x40000000
   far: 0x0000000110fe2684  esr: 0x56000080
Binary Images:
       0x10222c000 -        0x10b3c7fff +org.blenderfoundation.blender (2.93.0 - 2.93.0 2021-04-19) <44CF8416-B071-3102-872D-4111E49341B8> /Applications/Blender.app/Contents/MacOS/Blender
       0x111734000 -        0x111797fff +libomp.dylib (0) <86EC26AD-86C9-39D7-9666-90CC1FFF8605> /Applications/Blender.app/Contents/Resources/lib/libomp.dylib
       0x111934000 -        0x1119b3fff  dyld (851.27) <339EDF59-EF26-3EEF-8B67-82BE83D98224> /usr/lib/dyld
       0x191a7e000 -        0x191a7ffff  libsystem_blocks.dylib (79) <2CED50D9-55BC-33F8-ADA9-4C630E48C42A> /usr/lib/system/libsystem_blocks.dylib
       0x191a80000 -        0x191ab7fff  libxpc.dylib (2038.100.48) <F304C08D-A098-3C01-B823-437A09B279A2> /usr/lib/system/libxpc.dylib
       0x191ab8000 -        0x191acffff  libsystem_trace.dylib (1277.120.1) <888E6227-F5B6-3FFD-B42E-F3783BAAD74A> /usr/lib/system/libsystem_trace.dylib
       0x191ad0000 -        0x191b43fff  libcorecrypto.dylib (1000.120.1) <DAABADB9-C651-3B63-ABE5-CBE6134AFFEF> /usr/lib/system/libcorecrypto.dylib
       0x191b44000 -        0x191b6ffff  libsystem_malloc.dylib (317.100.9.111.1) <E8EBD657-10CE-368D-BD74-D8C3F07BDC84> /usr/lib/system/libsystem_malloc.dylib
       0x191b70000 -        0x191bb4fff  libdispatch.dylib (1271.120.1) <6EC996CA-9F27-3AD2-936A-793E3753B908> /usr/lib/system/libdispatch.dylib
       0x191bb5000 -        0x191beefff  libobjc.A.dylib (824) <343E8C55-BF34-3567-B795-4D21CB358199> /usr/lib/libobjc.A.dylib
       0x191bef000 -        0x191bf1fff  libsystem_featureflags.dylib (28.60.1) <D8285F60-D29F-3D75-9DAB-8D0430E025C2> /usr/lib/system/libsystem_featureflags.dylib
       0x191bf2000 -        0x191c73fff  libsystem_c.dylib (1439.100.3) <30CBC13C-DD0D-3F0F-8920-B5916BE25B35> /usr/lib/system/libsystem_c.dylib
       0x191c74000 -        0x191ccffff  libc++.1.dylib (905.6) <632294A8-E3B8-3236-9A94-987D6926092C> /usr/lib/libc++.1.dylib
       0x191cd0000 -        0x191ce7fff  libc++abi.dylib (905.6) <8B6F0D27-CE69-34A8-AAE0-11692319C356> /usr/lib/libc++abi.dylib
       0x191ce8000 -        0x191d1bfff  libsystem_kernel.dylib (7195.120.38.111.1) <E924BEF2-0A38-3AEE-8EA9-C21689C4EAC5> /usr/lib/system/libsystem_kernel.dylib
       0x191d1c000 -        0x191d28fff  libsystem_pthread.dylib (454.120.1) <4FC8BC50-13F5-3060-85B7-0EB4780A1743> /usr/lib/system/libsystem_pthread.dylib
       0x191d29000 -        0x191d6afff  libdyld.dylib (851.27) <0BEDEA15-64BB-3F0B-9B30-9120B3AB5073> /usr/lib/system/libdyld.dylib
       0x191d6b000 -        0x191d71fff  libsystem_platform.dylib (254.80.2) <AA657FC3-38C2-3C1B-97C3-30FB26D137A5> /usr/lib/system/libsystem_platform.dylib
       0x191d72000 -        0x191d9dfff  libsystem_info.dylib (542.40.3) <E174A7F8-F02F-3C01-BA3D-1E4C4E76A581> /usr/lib/system/libsystem_info.dylib
       0x191d9e000 -        0x19224cfff  com.apple.CoreFoundation (6.9 - 1776.101) <F195FE40-2A56-3616-AD09-5B2800F8D680> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
       0x19224d000 -        0x192484fff  com.apple.LaunchServices (1122.36 - 1122.36) <C0FB8957-8CAD-3CA0-B1AE-03BA9AB74CD8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
       0x192485000 -        0x19255efff  com.apple.gpusw.MetalTools (1.0 - 1) <97547801-31DE-3530-95FB-81C417A13FA1> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
       0x19255f000 -        0x1927c9fff  libBLAS.dylib (1336.101.1) <6B1D986A-82C8-3A2C-8F7C-E56CC3142502> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
       0x1927ca000 -        0x192814fff  com.apple.Lexicon-framework (1.0 - 86.2) <29806734-1740-387C-B29C-6B318B4E9944> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
       0x192815000 -        0x192878fff  libSparse.dylib (106) <72926215-C598-355F-88C9-4CDDD33BF4B9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
       0x192879000 -        0x192900fff  com.apple.SystemConfiguration (1.20 - 1.20) <4A4B8948-C1C0-3F0A-90F5-D2E299604E11> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
       0x192901000 -        0x192934fff  libCRFSuite.dylib (50) <71114FAA-0C0B-3760-AE5A-F354CAF4D047> /usr/lib/libCRFSuite.dylib
       0x192935000 -        0x192b63fff  libmecabra.dylib (929.9) <89D395B6-586B-30E7-8DEF-1FA106D52267> /usr/lib/libmecabra.dylib
       0x192b64000 -        0x192eeffff  com.apple.Foundation (6.9 - 1776.101) <58F1E2E6-5998-3D3A-BABE-EB1E12306997> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
       0x192ef0000 -        0x192fdffff  com.apple.LanguageModeling (1.0 - 247.3) <7C470214-EA8E-347E-95BC-7DFB5E90F1F0> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
       0x192fe0000 -        0x193102fff  com.apple.CoreDisplay (236.4 - 236.4) <472BE30C-A9CB-3DE6-9B9D-0C9F140494B5> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
       0x193103000 -        0x193366fff  com.apple.audio.AudioToolboxCore (1.0 - 1181.64) <74888403-4690-3F20-94F0-18CC6B7831BC> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
       0x193367000 -        0x193536fff  com.apple.CoreText (677.5.0.3 - 677.5.0.3) <ADA16F61-9DEA-3143-AF37-0CF6A505E51C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
       0x193537000 -        0x193b51fff  com.apple.audio.CoreAudio (5.0 - 5.0) <E23DC572-59CE-3222-B7E6-CA98573CC295> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
       0x193b52000 -        0x193eb5fff  com.apple.security (7.0 - 59754.120.9) <63F64CF4-2AFD-360F-BA35-176615F79D90> /System/Library/Frameworks/Security.framework/Versions/A/Security
       0x193eb6000 -        0x194127fff  libicucore.A.dylib (66112) <8A16DBEE-4A05-3348-B2ED-54617EF58F11> /usr/lib/libicucore.A.dylib
       0x194128000 -        0x194132fff  libsystem_darwin.dylib (1439.100.3) <B4565E40-67C8-373C-80DF-947799DB2776> /usr/lib/system/libsystem_darwin.dylib
       0x194133000 -        0x194426fff  com.apple.CoreServices.CarbonCore (1307.2 - 1307.2) <B4F3D631-0CF3-3911-A068-65907E1276C8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
       0x194427000 -        0x194462fff  com.apple.CoreServicesInternal (476.1.1 - 476.1.1) <1965E61F-ACAC-345E-ABB9-1E2448ED9BD8> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
       0x194463000 -        0x19449efff  com.apple.CSStore (1122.36 - 1122.36) <B3952F41-9A7A-39E5-AAE0-8695C4DFFC94> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
       0x19449f000 -        0x19456afff  com.apple.framework.IOKit (2.0.2 - 1845.120.5) <01D52842-7ADB-345D-B84E-60344FBB6DB3> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
       0x19456b000 -        0x194576fff  libsystem_notify.dylib (279.40.4) <80E87E4F-1567-3F00-BDE7-8273B41CA055> /usr/lib/system/libsystem_notify.dylib
       0x194577000 -        0x1945c4fff  libsandbox.1.dylib (1441.120.3) <416AACAB-855A-36BA-8FC9-525D09CBE905> /usr/lib/libsandbox.1.dylib
       0x1945c5000 -        0x195304fff  com.apple.AppKit (6.9 - 2022.50.104) <17F58B9C-0612-3CB8-B765-B306F06283FE> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
       0x195305000 -        0x19552bfff  com.apple.UIFoundation (1.0 - 728.7) <B3E73C57-A564-3657-A1E1-F1E60894195E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
       0x19552c000 -        0x19553efff  com.apple.UniformTypeIdentifiers (636.9 - 636.9) <3149CCF8-A6BC-37C0-B2F9-A21C1CDF2DA6> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
       0x19553f000 -        0x1956a9fff  com.apple.desktopservices (1.20 - 1346.5.1) <4E96CCCF-C226-3953-9E2F-AA0CDC7A13DC> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
       0x195976000 -        0x1960b7fff  libnetwork.dylib (2288.120.5) <22F5C582-BD00-3297-AF4D-8FA7185E0FBC> /usr/lib/libnetwork.dylib
       0x1960b8000 -        0x196540fff  com.apple.CFNetwork (1240.0.1 - 1240.0.1) <4C06A841-97B1-3B46-B376-03E383709D61> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
       0x196541000 -        0x196550fff  libsystem_networkextension.dylib (1295.120.5) <BB5691DB-71A5-3EE9-98F3-9FED1072CBD0> /usr/lib/system/libsystem_networkextension.dylib
       0x196551000 -        0x196552fff  libenergytrace.dylib (22.100.1) <DD882EE3-2743-3E93-8F0B-909EF31A20EA> /usr/lib/libenergytrace.dylib
       0x196553000 -        0x1965a5fff  libMobileGestalt.dylib (978.120.1) <D13EA97B-C4F2-3499-BF4D-B2DB43DEE75E> /usr/lib/libMobileGestalt.dylib
       0x1965a6000 -        0x1965bdfff  libsystem_asl.dylib (385) <97FF7122-7363-3A4A-ACA1-D187F59B9017> /usr/lib/system/libsystem_asl.dylib
       0x1965be000 -        0x1965d7fff  com.apple.TCC (1.0 - 1) <131655EA-7559-3795-91F4-B55CF6720C48> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
       0x1965d8000 -        0x196942fff  com.apple.SkyLight (1.600.0 - 586) <61850B0C-7A24-3F87-A8AD-23CF55B0C74A> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
       0x196943000 -        0x196f30fff  com.apple.CoreGraphics (2.0 - 1463.14.2) <46E3D40A-B5A7-391B-8EED-64D6938F78A4> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
       0x196f31000 -        0x197026fff  com.apple.ColorSync (4.13.0 - 3473.4.3) <E14A5DA5-486D-3D42-A1D4-8FB76BC6E1C0> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
       0x197027000 -        0x197082fff  com.apple.HIServices (1.22 - 715) <BAED71F0-107D-3674-AC30-E7FD0E0DBDA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
       0x1973dc000 -        0x197784fff  com.apple.CoreData (120 - 1048) <0E3F15FB-2089-30A9-8630-86C8C6F4490D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
       0x197785000 -        0x19779bfff  com.apple.ProtocolBuffer (1 - 285.24.10.20.1) <826FBECC-F1FF-38FF-9DFD-1FBC85EB6D54> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
       0x19779c000 -        0x197939fff  libsqlite3.dylib (321.3) <AFACE79D-E5C7-33A2-8426-D936D49E3742> /usr/lib/libsqlite3.dylib
       0x19793a000 -        0x1979aefff  com.apple.Accounts (113 - 113) <F74FABDD-7EB7-3AF8-A26F-DD06F946B9BA> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
       0x1979af000 -        0x1979c5fff  com.apple.commonutilities (8.0 - 900) <AAECA736-B6D4-3E4B-B8C1-6E47D2E955CA> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
       0x1979c6000 -        0x197a48fff  com.apple.BaseBoard (526 - 526) <FF05EA0F-7BB9-328E-AF95-B5A8298DE161> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
       0x197a49000 -        0x197a96fff  com.apple.RunningBoardServices (1.0 - 505.100.8) <75E9AEEE-7FC6-33B1-8A34-ED163C064772> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
       0x197a97000 -        0x197b0afff  com.apple.AE (918.6 - 918.6) <2844474D-715D-3B8F-9BD7-483A0EEDBAB5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
       0x197b0b000 -        0x197b12fff  libdns_services.dylib (1310.120.1) <253B2038-3433-39EE-AFF2-F37CA582C550> /usr/lib/libdns_services.dylib
       0x197b13000 -        0x197b1afff  libsystem_symptoms.dylib (1431.100.22) <9D2D8857-D485-3F64-89EF-460CE7906297> /usr/lib/system/libsystem_symptoms.dylib
       0x197b1b000 -        0x197c71fff  com.apple.Network (1.0 - 1) <F1D4F682-4747-3691-A778-1BF9C00DC0CB> /System/Library/Frameworks/Network.framework/Versions/A/Network
       0x197c72000 -        0x197ca4fff  com.apple.analyticsd (1.0 - 1) <BF8C553C-BD73-3431-935D-B817C5DD5F73> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
       0x197ca5000 -        0x197ca7fff  libDiagnosticMessagesClient.dylib (112) <8CA1B745-17A3-3B36-85F1-48496702DFA7> /usr/lib/libDiagnosticMessagesClient.dylib
       0x197ca8000 -        0x197cf3fff  com.apple.spotlight.metadata.utilities (1.0 - 2150.17) <0CD94349-7C55-314D-AD50-8F7202382572> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
       0x197cf4000 -        0x197d8dfff  com.apple.Metadata (10.7.0 - 2150.17) <B5FC0247-9AA3-3DC9-BFD3-B46702458352> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
       0x197d8e000 -        0x197d94fff  com.apple.DiskArbitration (2.7 - 2.7) <20DC2DEB-8A8D-3572-8700-73FD3AFA2CB4> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
       0x197d95000 -        0x19809ffff  com.apple.vImage (8.1 - 544.4) <BA20545D-127A-33D3-8281-D13231C004BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
       0x1980a0000 -        0x19835cfff  com.apple.QuartzCore (1.11 - 927.18) <8BFE5237-8D23-390C-9BC9-FF0F8E106287> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
       0x19835d000 -        0x19839efff  libFontRegistry.dylib (309) <F8BE546F-7E42-3479-A7FA-372180DD5D23> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
       0x19839f000 -        0x1984b6fff  com.apple.coreui (2.1 - 692.1) <C01BBA9A-5297-3CE1-ABB9-81CB9B35F642> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
       0x198597000 -        0x1985a1fff  com.apple.PerformanceAnalysis (1.278.3 - 278.3) <0B218980-1B58-3819-9A53-74AFF5C0DB82> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
       0x1985a2000 -        0x1985affff  com.apple.OpenDirectory (11.4 - 230.40.1) <7251BC87-CA5A-3F45-AF0A-F30FDF9779E2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
       0x1985b0000 -        0x1985cffff  com.apple.CFOpenDirectory (11.4 - 230.40.1) <B4E46055-1C85-3B92-8BEA-CC759D820311> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
       0x1985d0000 -        0x1985d8fff  com.apple.CoreServices.FSEvents (1290.120.1 - 1290.120.1) <1F9993CA-44F9-30DD-AA7F-B4A30FE609E5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
       0x1985d9000 -        0x1985fcfff  com.apple.coreservices.SharedFileList (144 - 144) <04F87F10-14CD-3B47-91D2-5A7CFCB04043> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
       0x1985fd000 -        0x1985fffff  libapp_launch_measurement.dylib (14.1) <D30606D2-3CCC-38A8-B278-9E2F0BED8462> /usr/lib/libapp_launch_measurement.dylib
       0x198600000 -        0x198642fff  com.apple.CoreAutoLayout (1.0 - 21.10.1) <D4A2F546-0925-3CF4-AA91-2BE9C03C87C1> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
       0x198643000 -        0x19872ffff  libxml2.2.dylib (34.9) <F955296B-26F6-34DE-B679-204DF088FF1A> /usr/lib/libxml2.2.dylib
       0x198730000 -        0x198783fff  com.apple.CoreVideo (1.8 - 414.7) <53004F84-EBA2-306D-9827-7FE3EA67081F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
       0x198784000 -        0x198786fff  com.apple.loginsupport (1.0 - 1) <9C398F00-056D-3D13-B84F-575D317A3C84> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
       0x1987ae000 -        0x1987ccfff  com.apple.UserManagement (1.0 - 1) <528AC561-7760-3526-88B0-B65BCA3EB4F4> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
       0x199964000 -        0x199975fff  libsystem_containermanager.dylib (318.100.4) <7776B275-9187-3A56-9645-DDE4A33B36CD> /usr/lib/system/libsystem_containermanager.dylib
       0x199976000 -        0x199987fff  com.apple.IOSurface (290.7 - 290.7) <2F8F5618-2A0D-36D0-B4D5-D1AB5D687767> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
       0x199988000 -        0x199991fff  com.apple.IOAccelerator (442.9 - 442.9) <1BCBD1DD-E800-3693-A144-1A33989ADC3B> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
       0x199992000 -        0x199a80fff  com.apple.Metal (244.201 - 244.201) <E766B61F-2FD6-387F-A847-1DD57B2370BD> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
       0x199a81000 -        0x199aa0fff  com.apple.audio.caulk (1.0 - 70) <CBE64C48-D736-34D3-B9D3-43977A8A3D51> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
       0x199aa1000 -        0x199c42fff  com.apple.CoreMedia (1.0 - 2775.15.4.1) <AF279EE9-48EC-3FFD-A78F-752E51A8ADBE> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
       0x199c43000 -        0x199d9bfff  libFontParser.dylib (305.5.0.1) <B0B1A5D6-03C1-339F-A0A6-C74F27ADBC3D> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
       0x199d9c000 -        0x19a0a6fff  com.apple.HIToolbox (2.1.1 - 1061.9) <9A6334A3-85B6-32C9-A95C-C5886F2EE693> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
       0x19a0a7000 -        0x19a0befff  com.apple.framework.DFRFoundation (1.0 - 266) <D9D4654C-632C-3C71-BE4E-B038B25E2A4D> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
       0x19a0bf000 -        0x19a0c2fff  com.apple.dt.XCTTargetBootstrap (1.0 - 18119.1) <DB60E75E-6850-3ECD-9EC0-24A24813AC7E> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
       0x19a0c3000 -        0x19a0edfff  com.apple.CoreSVG (1.0 - 149) <ADF4E449-7DB3-3C65-B193-8D31F0DB5453> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
       0x19a0ee000 -        0x19a30cfff  com.apple.ImageIO (3.3.0 - 2130.4.7) <F46E2C32-72D0-36A2-A3C8-8FC6DD0CA0BC> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
       0x19a30d000 -        0x19a625fff  com.apple.CoreImage (16.3.0 - 1140.2) <2531067C-0F46-3889-8A0A-418814F7B812> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
       0x19a626000 -        0x19a68afff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <F462C547-D6B5-3799-931C-DE51D3511B99> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
       0x19a68b000 -        0x19a68ffff  libsystem_configuration.dylib (1109.101.1) <2D50FBA0-08BA-31AC-92C4-E111BB220475> /usr/lib/system/libsystem_configuration.dylib
       0x19a690000 -        0x19a694fff  libsystem_sandbox.dylib (1441.120.3) <BF2795D6-97AA-353F-82B9-267E28502DDF> /usr/lib/system/libsystem_sandbox.dylib
       0x19a695000 -        0x19a696fff  com.apple.AggregateDictionary (1.0 - 1) <294D63BA-ACB8-33C1-BF39-9BB5EE4DE584> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
       0x19a697000 -        0x19a69afff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <4277E12B-2951-37B7-89D7-10FE21AFC2E5> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
       0x19a69b000 -        0x19a69cfff  liblangid.dylib (136) <37805A64-058A-3C58-920A-0456DC6E2451> /usr/lib/liblangid.dylib
       0x19a69d000 -        0x19a72afff  com.apple.CoreNLP (1.0 - 245.2) <75FB6912-1FD7-31BA-AF40-0DB7776E7396> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
       0x19a72b000 -        0x19a732fff  com.apple.LinguisticData (1.0 - 399) <872CBE77-1589-3684-8F1A-651EDF89BE0C> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
       0x19a733000 -        0x19abf1fff  libBNNS.dylib (288.100.5) <FD95EC2C-3F2A-308F-80EC-B4D9137F9E86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
       0x19abf2000 -        0x19aca0fff  libvDSP.dylib (760.100.3) <983DDC6D-7901-3D2A-8340-FF3DF4364403> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
       0x19aca1000 -        0x19acb3fff  com.apple.CoreEmoji (1.0 - 128.4) <DC1509BE-5096-3B24-811A-315DFB3DDD11> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
       0x19acb4000 -        0x19acbefff  com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <B435EF85-F00B-3F3E-BF66-A819316439B8> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer
       0x19acbf000 -        0x19ad87fff  com.apple.framework.CoreWLAN (16.0 - 1657) <BFB53BD7-AFD3-37E0-865B-CAA1AD2D5897> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
       0x19ad88000 -        0x19af89fff  com.apple.CoreUtils (6.6 - 660.36) <AE0D1FDD-33B5-3932-B24C-F0DB1181309A> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
       0x19af8a000 -        0x19afacfff  com.apple.MobileKeyBag (2.0 - 1.0) <1C93B19E-0075-3EE0-A7C5-3C5DF8EE5F6B> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
       0x19afad000 -        0x19afbcfff  com.apple.AssertionServices (1.0 - 505.100.8) <624803BB-8C1F-3D66-B9A8-0018BA6028D0> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
       0x19afbd000 -        0x19b040fff  com.apple.securityfoundation (6.0 - 55240.40.4) <4340FBBF-8DCD-34EB-A7FD-6F69A82DD43F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
       0x19b041000 -        0x19b04afff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <555EBF71-04FE-37CE-8DD4-384F31A39C66> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
       0x19b04b000 -        0x19b050fff  com.apple.xpc.ServiceManagement (1.0 - 1) <E0A73971-E48E-3C7A-BF46-9BF6B1F0E054> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
       0x19b051000 -        0x19b053fff  libquarantine.dylib (119.40.2) <09225928-ADCF-3C9F-B718-5B72FCA9645A> /usr/lib/system/libquarantine.dylib
       0x19b054000 -        0x19b063fff  libCheckFix.dylib (31) <E6DF86BC-8069-3F8E-A46A-0E062BE8B938> /usr/lib/libCheckFix.dylib
       0x19b064000 -        0x19b07afff  libcoretls.dylib (169.100.1) <EF5F4EBC-CF05-3863-AF01-9DA3E6006CC3> /usr/lib/libcoretls.dylib
       0x19b07b000 -        0x19b08bfff  libbsm.0.dylib (68.40.1) <05E20C6D-9980-3642-BD03-0600E7078D16> /usr/lib/libbsm.0.dylib
       0x19b08c000 -        0x19b0d1fff  libmecab.dylib (929.9) <33DD036D-696C-37CC-8E37-EA1F09F2EF46> /usr/lib/libmecab.dylib
       0x19b0d2000 -        0x19b0d6fff  libgermantok.dylib (24) <3EE0C77B-F5E0-337C-BE6C-B10BF012E861> /usr/lib/libgermantok.dylib
       0x19b0d7000 -        0x19b0ebfff  libLinearAlgebra.dylib (1336.101.1) <FE897FBD-1016-317E-BD30-83B0C5C712EA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
       0x19b0ec000 -        0x19b2effff  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <8D332E8E-02FD-3584-B8D0-6A38972E2853> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
       0x19b2f0000 -        0x19b339fff  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <F92FEB6C-41C8-3219-9D40-315299EAA51A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
       0x19b33a000 -        0x19b48cfff  com.apple.MLCompute (1.0 - 1) <F3510480-5C81-3603-A80B-EACB0F56F269> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute
       0x19b48d000 -        0x19b4bbfff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <5522AC5A-1841-3B86-9584-BFFF1A27F512> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
       0x19b4bc000 -        0x19b50efff  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <A38A23EF-BD5F-3D81-B6A9-A1D351EE67FE> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
       0x19b50f000 -        0x19b596fff  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <87C47D66-F126-3F93-95BC-7CA8C34B3547> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage
       0x19b597000 -        0x19b5a6fff  com.apple.AppleFSCompression (125 - 1.0) <47040CE1-7106-37F2-83D4-0A75069EA57D> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
       0x19b5a7000 -        0x19b5b3fff  libbz2.1.0.dylib (44) <18F31C75-AA8C-3A81-9B07-02BA08A8C013> /usr/lib/libbz2.1.0.dylib
       0x19b5b4000 -        0x19b5b8fff  libsystem_coreservices.dylib (127.1) <7A2AAE08-E6D8-3717-869C-F1A2480A6FB4> /usr/lib/system/libsystem_coreservices.dylib
       0x19b5b9000 -        0x19b5e9fff  com.apple.CoreServices.OSServices (1122.36 - 1122.36) <0D7E80C6-A517-396D-BEA3-7688A78B3292> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
       0x19b5ea000 -        0x19b6fafff  com.apple.AuthKit (1.0 - 1) <3652B326-A1D9-3DCF-97F3-BA5FC2E7FCE6> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
       0x19b79e000 -        0x19b7affff  libz.1.dylib (76) <45DD96E4-F382-3E35-9A82-F9E26452F25D> /usr/lib/libz.1.dylib
       0x19b7b0000 -        0x19b7ddfff  libsystem_m.dylib (3186.100.3) <F5408287-14C3-35E1-A515-FD3F2DF0E31C> /usr/lib/system/libsystem_m.dylib
       0x19b7de000 -        0x19b7defff  libcharset.1.dylib (59) <1A50A6C2-55C9-3A9E-8230-2D839B6A2004> /usr/lib/libcharset.1.dylib
       0x19b7df000 -        0x19b7e4fff  libmacho.dylib (980) <8E20D029-EE0B-3C6D-8818-0F9D6FE14B72> /usr/lib/system/libmacho.dylib
       0x19b7e5000 -        0x19b7fcfff  libkxld.dylib (7195.120.38.111.1) <9378AA97-F2E6-3248-88B9-040D286EF7CB> /usr/lib/system/libkxld.dylib
       0x19b7fd000 -        0x19b80afff  libcommonCrypto.dylib (60178.120.3) <BA4F0410-543D-3A2F-BA99-C903AA027F96> /usr/lib/system/libcommonCrypto.dylib
       0x19b80b000 -        0x19b815fff  libunwind.dylib (201) <5784C399-94C7-319B-8B15-ACB748905285> /usr/lib/system/libunwind.dylib
       0x19b816000 -        0x19b81dfff  liboah.dylib (203.43) <05C0F891-2202-3AD8-9B71-A40BE2B1D85B> /usr/lib/liboah.dylib
       0x19b81e000 -        0x19b826fff  libcopyfile.dylib (173.40.2) <D474EABA-D3D0-31D3-86F1-5A72CFC3C0CC> /usr/lib/system/libcopyfile.dylib
       0x19b827000 -        0x19b82afff  libcompiler_rt.dylib (102.2) <60B2CCEC-E018-3F76-83B7-4EE08CB46665> /usr/lib/system/libcompiler_rt.dylib
       0x19b82b000 -        0x19b82dfff  libsystem_collections.dylib (1439.100.3) <98C45455-3D00-3BAA-B2F2-CA416CF1A4A2> /usr/lib/system/libsystem_collections.dylib
       0x19b82e000 -        0x19b830fff  libsystem_secinit.dylib (87.60.1) <1D5CCC13-FCF3-340C-8159-947759BE25B7> /usr/lib/system/libsystem_secinit.dylib
       0x19b831000 -        0x19b833fff  libremovefile.dylib (49.120.1) <CC7F49F8-C835-3105-9D89-B4BEDD6A2D6D> /usr/lib/system/libremovefile.dylib
       0x19b834000 -        0x19b834fff  libkeymgr.dylib (31) <3A9E84C3-E3F0-3CA7-9E69-3EE9D86C66EB> /usr/lib/system/libkeymgr.dylib
       0x19b835000 -        0x19b83dfff  libsystem_dnssd.dylib (1310.120.1) <FE4501F4-60F6-3A24-B521-0E1A97016D03> /usr/lib/system/libsystem_dnssd.dylib
       0x19b83e000 -        0x19b843fff  libcache.dylib (83) <4ECB7CD0-2974-3514-9B79-77A4D7EB8D66> /usr/lib/system/libcache.dylib
       0x19b844000 -        0x19b845fff  libSystem.B.dylib (1292.120.1) <7F7F586D-ED67-3443-B4CF-FD2DC1081ADE> /usr/lib/libSystem.B.dylib
       0x19b846000 -        0x19b849fff  libfakelink.dylib (3) <BD571918-C83A-38DD-954B-6446022B6BFE> /usr/lib/libfakelink.dylib
       0x19b84a000 -        0x19b84afff  com.apple.SoftLinking (1.0 - 1) <F1020F09-E873-3EF4-814B-058390FF5BD4> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking
       0x19b84b000 -        0x19b886fff  libpcap.A.dylib (98.100.3) <52955C6B-6C4E-3B89-9DDA-71380BA49885> /usr/lib/libpcap.A.dylib
       0x19b887000 -        0x19b97cfff  libiconv.2.dylib (59) <AB245F1B-B394-3351-811D-2716EC5ABF8C> /usr/lib/libiconv.2.dylib
       0x19b97d000 -        0x19b98ffff  libcmph.dylib (8) <72EC5116-0051-305C-9340-08555980FD7C> /usr/lib/libcmph.dylib
       0x19b990000 -        0x19ba00fff  libarchive.2.dylib (83.100.2) <B0BF9AE7-6C7C-32E4-BDCA-13A957266FF1> /usr/lib/libarchive.2.dylib
       0x19ba01000 -        0x19ba71fff  com.apple.SearchKit (1.4.1 - 1.4.1) <F2018FD6-E9E0-3C24-9F89-2F30DCB012ED> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
       0x19ba72000 -        0x19ba73fff  libThaiTokenizer.dylib (3) <2BC62E9E-421D-384A-8282-9DC4574E5681> /usr/lib/libThaiTokenizer.dylib
       0x19ba74000 -        0x19ba98fff  com.apple.applesauce (1.0 - 16.28) <D1BF4285-6820-3497-810F-342D16E864BB> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
       0x19ba99000 -        0x19baaffff  libapple_nghttp2.dylib (1.41) <2AF641D7-C381-36FC-935B-FC7EB3E8C302> /usr/lib/libapple_nghttp2.dylib
       0x19bab0000 -        0x19bac2fff  libSparseBLAS.dylib (1336.101.1) <99CEB929-C133-3034-8EDC-1C6C54D5086D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
       0x19bac3000 -        0x19bac4fff  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <293D171F-4E22-3F72-A978-B8972933A5CF> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
       0x19bac5000 -        0x19bac9fff  libpam.2.dylib (28.40.1) <8F1D1E88-3DB0-3657-90F6-FE0D1E20787B> /usr/lib/libpam.2.dylib
       0x19baca000 -        0x19bae8fff  libcompression.dylib (96.120.1) <4EECD5F9-58DF-3D30-9ED1-31289B605FF7> /usr/lib/libcompression.dylib
       0x19bae9000 -        0x19baedfff  libQuadrature.dylib (7) <756B04FC-6930-3AFC-8BF3-D1982B74A338> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
       0x19baee000 -        0x19bfaafff  libLAPACK.dylib (1336.101.1) <47BFD025-75E3-30BE-8364-A8FB4ED3C885> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
       0x19bfab000 -        0x19bffdfff  com.apple.DictionaryServices (1.2 - 341) <961BF6C7-705F-3467-AB91-9B425472E182> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
       0x19bffe000 -        0x19c016fff  liblzma.5.dylib (16) <3DC963E2-4103-3D49-BC0C-336320841B0F> /usr/lib/liblzma.5.dylib
       0x19c017000 -        0x19c018fff  libcoretls_cfhelpers.dylib (169.100.1) <5B928E1E-3477-3FA0-984E-ED2E1C558AB4> /usr/lib/libcoretls_cfhelpers.dylib
       0x19c019000 -        0x19c0fdfff  com.apple.APFS (1677.120.1 - 1677.120.1) <CCD98309-34D5-3337-9A43-4B0D79286965> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
       0x19c0fe000 -        0x19c10bfff  libxar.1.dylib (452) <2F55A8FC-2507-3238-8B19-33A73500BB26> /usr/lib/libxar.1.dylib
       0x19c10c000 -        0x19c10ffff  libutil.dylib (58.40.2) <6022B0A3-10A5-3366-B8A6-3944895804DB> /usr/lib/libutil.dylib
       0x19c110000 -        0x19c139fff  libxslt.1.dylib (17.4) <E22CAC49-EB61-383D-ABF0-BAD6D2BE6573> /usr/lib/libxslt.1.dylib
       0x19c13a000 -        0x19c144fff  libChineseTokenizer.dylib (37.1) <42F2E42A-F75B-359A-AC42-52B3923FCBE9> /usr/lib/libChineseTokenizer.dylib
       0x19c145000 -        0x19c1b4fff  libvMisc.dylib (760.100.3) <4FAA7747-C1DF-3FB3-B988-E88A096E293A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
       0x19c1b5000 -        0x19c246fff  libate.dylib (3.0.6) <1C02469A-9BA5-3292-9904-19A8FF69CF18> /usr/lib/libate.dylib
       0x19c247000 -        0x19c24efff  libIOReport.dylib (64.100.1) <2E8B790E-36BD-3835-A825-D74A7555FBF6> /usr/lib/libIOReport.dylib
       0x19c34a000 -        0x19c351fff  libMatch.1.dylib (38) <705C61A3-49D4-38FF-A258-65B50F386167> /usr/lib/libMatch.1.dylib
       0x19c352000 -        0x19c3d5fff  libCoreStorage.dylib (554) <F14C43A5-6291-3B1D-8347-B3136B3E6640> /usr/lib/libCoreStorage.dylib
       0x19c3d6000 -        0x19c421fff  com.apple.AppleVAFramework (6.1.3 - 6.1.3) <40FDE32D-B4C8-3BCE-A549-5C040514FE02> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
       0x19c422000 -        0x19c43bfff  libexpat.1.dylib (26) <28B05BDE-E3A6-377E-86FD-763C83D5466A> /usr/lib/libexpat.1.dylib
       0x19c43c000 -        0x19c444fff  libheimdal-asn1.dylib (597.120.2) <9B69F08F-8FB7-3926-AB13-E31C2872BB94> /usr/lib/libheimdal-asn1.dylib
       0x19c445000 -        0x19c457fff  com.apple.IconFoundation (479.4 - 479.4) <7CD3E563-4780-3453-850F-1A929CC851BE> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation
       0x19c458000 -        0x19c4bbfff  com.apple.IconServices (479.4 - 479.4) <0EA391FC-873D-341A-B44D-4C21664673E1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
       0x19c4bc000 -        0x19c591fff  com.apple.MediaExperience (1.0 - 1) <827EEC52-6FAD-3ECE-85DB-B1DD7D3D433E> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
       0x19c592000 -        0x19c5b8fff  com.apple.persistentconnection (1.0 - 1.0) <CFAE4FDF-6A00-3B48-B443-25448414991B> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
       0x19c5b9000 -        0x19c5c6fff  com.apple.GraphVisualizer (1.0 - 100.1) <FEE3573E-ECD6-3191-9E14-0E7436E7733D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
       0x19c5c7000 -        0x19c9d9fff  com.apple.vision.FaceCore (4.3.2 - 4.3.2) <BD15FDE7-E3FE-331A-991E-334030F4EAB5> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
       0x19c9da000 -        0x19ca19fff  com.apple.OTSVG (1.0 - 677.5.0.3) <4B9A7199-C6C4-393F-8D58-52577A788734> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
       0x19ca1a000 -        0x19ca21fff  com.apple.xpc.AppServerSupport (1.0 - 2038.100.48) <AC37C623-37B4-39AE-B7A0-EC30F9BCEB49> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport
       0x19ca22000 -        0x19ca30fff  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <52CD4656-D608-31DC-BC1C-D68EB4690A64> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
       0x19ca31000 -        0x19ca37fff  libspindump.dylib (295.2) <3B5C46FD-C908-3F1F-80F0-24418BC50DE0> /usr/lib/libspindump.dylib
       0x19ca38000 -        0x19caedfff  com.apple.Heimdal (4.0 - 2.0) <FAA19FC1-3C27-353B-AA50-B4D6250DD0A6> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
       0x19cc82000 -        0x19ccbcfff  com.apple.bom (14.0 - 235) <B0F7555C-9577-3656-B13D-7F337B970915> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
       0x19ccbd000 -        0x19cd00fff  com.apple.AppleJPEG (1.0 - 1) <5091006F-495E-3C1C-998D-64CF46074D49> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
       0x19cd01000 -        0x19cde2fff  libJP2.dylib (2130.4.7) <EA73CB27-2669-3FB0-975F-A9109E1766E0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
       0x19cde3000 -        0x19cde6fff  com.apple.WatchdogClient.framework (1.0 - 98.120.2) <E7114014-A41F-3B24-B923-7CFD12CE895D> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
       0x19cde7000 -        0x19ce1ffff  com.apple.MultitouchSupport.framework (4440.3 - 4440.3) <C09CAE5B-1F73-310F-B37D-E943EDA1EEF9> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
       0x19ce20000 -        0x19cfaefff  com.apple.VideoToolbox (1.0 - 2775.15.4.1) <C984E94A-D14E-3045-ABA6-6696CF00E0B5> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
       0x19cfaf000 -        0x19cfe1fff  libAudioToolboxUtility.dylib (1181.64) <F186CED9-B346-3C4A-BD5B-59069D3B0B41> /usr/lib/libAudioToolboxUtility.dylib
       0x19cfe2000 -        0x19d008fff  libPng.dylib (2130.4.7) <4C94F6D7-CCBD-3DCE-BD6B-78D4CD0FF7B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
       0x19d009000 -        0x19d065fff  libTIFF.dylib (2130.4.7) <0CC98D62-BCE7-3910-8118-C2122B8FFEB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
       0x19d066000 -        0x19d084fff  com.apple.IOPresentment (58 - 37) <41646B8C-5FFF-392D-A60C-A01FA23C0E96> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
       0x19d085000 -        0x19d089fff  com.apple.GPUWrangler (6.3.2 - 6.3.2) <0E736E0A-6020-3C5D-88E4-F2B5AB6CD9BE> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
       0x19d08a000 -        0x19d08cfff  libRadiance.dylib (2130.4.7) <828A6BB6-8611-3906-A80F-7A024F55D909> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
       0x19d08d000 -        0x19d092fff  com.apple.DSExternalDisplay (3.1 - 380) <5F874722-25A9-37FB-B573-7C24B74E8CA5> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
       0x19d093000 -        0x19d0b3fff  libJPEG.dylib (2130.4.7) <B1400053-AAA8-3F42-9458-1AA173505DE4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
       0x19d0b4000 -        0x19d0e3fff  com.apple.ATSUI (1.0 - 1) <785A8C9A-031E-326C-AE71-3569EB15A801> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
       0x19d0e4000 -        0x19d0e8fff  libGIF.dylib (2130.4.7) <C7111C48-2269-32D4-B194-3A4F66254865> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
       0x19d0e9000 -        0x19d0f2fff  com.apple.CMCaptureCore (1.0 - 82.4) <513AC7FE-BBCC-399A-8609-E6C39846554E> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore
       0x19d0f3000 -        0x19d13afff  com.apple.print.framework.PrintCore (16.1 - 531.1) <0E8B2ECC-230B-35C1-B639-3E0858C6261D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
       0x19d13b000 -        0x19d1eefff  com.apple.TextureIO (3.10.9 - 3.10.9) <528408FA-869B-3068-88F9-3800CB00CF67> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
       0x19d1ef000 -        0x19d1f7fff  com.apple.InternationalSupport (1.0 - 61.1) <2C2B8BC3-8569-323B-A27A-9593C3A21927> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
       0x19d1f8000 -        0x19d26cfff  com.apple.datadetectorscore (8.0 - 674) <D55F4857-7BE1-3FFC-9FF6-3F3AE7305883> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
       0x19d26d000 -        0x19d2ccfff  com.apple.UserActivity (439 - 439) <405F3A85-927F-3E68-A9CE-D79420E91EB1> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity
       0x19e3c5000 -        0x19e3fafff  libSessionUtility.dylib (76.69) <222B42E6-6CCE-3F68-AB20-3B184A302740> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib
       0x19e3fb000 -        0x19e508fff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <4676580D-38F3-35A0-8AD6-995FC8C33769> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
       0x19e509000 -        0x19e570fff  com.apple.audio.AudioSession (1.0 - 76.69) <E6A64A92-1C8A-3E12-8858-64BEC69E4586> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession
       0x19e571000 -        0x19e583fff  libAudioStatistics.dylib (27.64) <B8132A53-47F7-3AFB-AA68-F273799856A7> /usr/lib/libAudioStatistics.dylib
       0x19e584000 -        0x19e597fff  com.apple.speech.synthesis.framework (9.0.64 - 9.0.64) <A42FE559-1364-30FE-A673-A16B6EB900A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
       0x19e598000 -        0x19e606fff  com.apple.ApplicationServices.ATS (377 - 516) <23783698-397E-34CC-9F52-F9652E28AA27> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
       0x19e607000 -        0x19e61ffff  libresolv.9.dylib (68) <1E8126CB-911D-31F9-A103-002553CDB0FE> /usr/lib/libresolv.9.dylib
       0x19e74c000 -        0x19e82bfff  libSMC.dylib (20) <15B0366D-FFCD-3576-93B5-FEB652812B92> /usr/lib/libSMC.dylib
       0x19e82c000 -        0x19e889fff  libcups.2.dylib (494.1) <8B22B88C-DD0C-3482-8413-1B84D2399A78> /usr/lib/libcups.2.dylib
       0x19e88a000 -        0x19e89dfff  com.apple.LangAnalysis (1.7.0 - 254) <B15D7F8D-689C-3030-B335-974503B9869A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
       0x19e89e000 -        0x19e8aafff  com.apple.NetAuth (6.2 - 6.2) <D483D1A2-4435-3543-AA50-D65FA0C999DD> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
       0x19e8ab000 -        0x19e8b2fff  com.apple.ColorSyncLegacy (4.13.0 - 1) <FFE793E7-A8EA-3A49-8288-DBFE2CCEDD8D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
       0x19e8b3000 -        0x19e8befff  com.apple.QD (4.0 - 416) <412A2EF3-042A-338B-9340-1426098A5462> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
       0x19e8bf000 -        0x19eeaffff  com.apple.audio.AudioResourceArbitration (1.0 - 1) <DB9897F3-9302-3417-9D3D-18CDD2FA3431> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
       0x19eeb0000 -        0x19eebbfff  com.apple.perfdata (1.0 - 67.40.1) <0B3751C5-7F5B-3599-8245-8ABBC83B14F6> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
       0x19eebc000 -        0x19eec9fff  libperfcheck.dylib (41) <E0F21E0A-3D49-3965-AD80-24E21CBF9D1F> /usr/lib/libperfcheck.dylib
       0x19eeca000 -        0x19eedafff  com.apple.Kerberos (3.0 - 1) <719C9664-CBB8-3880-8244-FC432F819267> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
       0x19eedb000 -        0x19ef22fff  com.apple.GSS (4.0 - 2.0) <6DE570C1-5883-3AAC-A2BE-C6EADE643B7C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
       0x19ef23000 -        0x19ef32fff  com.apple.CommonAuth (4.0 - 2.0) <084F6AB9-317C-3BED-8096-033B4AD89F4E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
       0x19ef86000 -        0x19efa3fff  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <3C06DB73-1B86-36C0-BE35-536790EB44EC> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
       0x19efa4000 -        0x19efacfff  com.apple.CorePhoneNumbers (1.0 - 1) <BB191DDA-D03B-3A0C-8F62-AC3D82942A74> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
       0x19f0f8000 -        0x19f0f8fff  liblaunch.dylib (2038.100.48) <DF8E3F7B-AF35-391A-BF64-080236A90CAF> /usr/lib/system/liblaunch.dylib
       0x19f8a7000 -        0x19f9e3fff  com.apple.Sharing (1620 - 1620) <32AA747C-8806-36E8-BE93-13C7C79C93E7> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
       0x19f9e4000 -        0x19facefff  com.apple.Bluetooth (8.0.5 - 8.0.5d3) <08B22D07-D6F4-360F-B8FA-21005A56B4F7> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
       0x19fae7000 -        0x19fb3ffff  com.apple.ProtectedCloudStorage (1.0 - 1) <E0F4E066-5B2B-3DE3-88F8-196A25B7E416> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
       0x1a1333000 -        0x1a135afff  com.apple.RemoteViewServices (2.0 - 163) <2CD5F397-A4D0-3A88-9DB9-8FFB7C40878D> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
       0x1a135b000 -        0x1a136afff  com.apple.SpeechRecognitionCore (6.1.23 - 6.1.23) <DCC312CE-8AC8-351B-9ABA-0CFD1586FA02> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
       0x1a136b000 -        0x1a1372fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <3F5F16E6-61A3-33C9-9604-9B86A5343D00> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
       0x1a15a1000 -        0x1a15a1fff  libsystem_product_info_filter.dylib (8.40.1) <D7907F14-A973-36D2-8565-4E4655EC44E2> /usr/lib/system/libsystem_product_info_filter.dylib
       0x1a1674000 -        0x1a1674fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <31320A8A-4011-3A35-9960-3C22B56578D1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
       0x1a1696000 -        0x1a1696fff  com.apple.CoreServices (1122.36 - 1122.36) <AB0BA3BB-BAAB-3161-A3DD-301537FA9C8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
       0x1a1852000 -        0x1a1852fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <71EB3025-AFEA-3D12-8403-18A582480B45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
       0x1a20af000 -        0x1a210afff  com.apple.CoreBluetooth (1.0 - 1) <B8721393-648B-30E6-BDA1-06ABF1B883B8> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
       0x1a210b000 -        0x1a2115fff  com.apple.SymptomDiagnosticReporter (1.0 - 79.120.1) <61B02625-779B-3AB7-96F3-F4108EA490CB> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
       0x1a212a000 -        0x1a2135fff  com.apple.AppleIDAuthSupport (1.0 - 1) <A7518B2F-E662-3F07-BA7B-61BBA70573BA> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
       0x1a2136000 -        0x1a21eafff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <CF92C988-0364-3538-8EEB-50E768E0C941> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
       0x1a21eb000 -        0x1a221efff  com.apple.MediaKit (16 - 927.40.2) <C4891330-2CE9-37B8-9254-469E2E6AEDC1> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
       0x1a221f000 -        0x1a22fffff  com.apple.DiskManagement (14.0 - 1733.100.4) <D55B3144-84CF-3192-A1BA-9E0BE1E5D16B> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
       0x1a2340000 -        0x1a2496fff  com.apple.FileProvider (348.5.2 - 348.5.2) <C08E6657-396D-3D1A-B1F7-E5A5FECB33B8> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
       0x1a2497000 -        0x1a24b9fff  com.apple.GenerationalStorage (2.0 - 323) <67CAFC6C-6C05-3AC2-B51F-A0235E1F802F> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
       0x1a2e70000 -        0x1a2eaafff  com.apple.DebugSymbols (195.1 - 195.1) <C2BE0C8B-D71C-3012-A996-9236EE9671FB> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
       0x1a2eab000 -        0x1a2f5cfff  com.apple.CoreSymbolication (12.5 - 64544.69.1) <A8DDC912-FEC9-34B5-8F18-0B54FD62CED8> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
       0x1a3e48000 -        0x1a3ea7fff  com.apple.framework.Apple80211 (17.0 - 1728) <A43BEA13-584F-37DF-B65C-09A7A9F2EC56> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
       0x1a3ea8000 -        0x1a3fd3fff  com.apple.CoreWiFi (3.0 - 341) <E8F92CEF-6DD8-3C1F-9D5E-EACA1DB12910> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
       0x1a42ac000 -        0x1a42affff  com.apple.help (1.3.8 - 71) <3DBF2D52-ABDD-3C4F-8C37-CF83D3B358E0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
       0x1a42b0000 -        0x1a42b7fff  com.apple.EFILogin (2.0 - 2) <06DF3E40-AF44-3166-8B6E-70AF19F7C287> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
       0x1a42b8000 -        0x1a42c3fff  libcsfde.dylib (554) <83676304-860B-3549-BA97-CEF4038A5D89> /usr/lib/libcsfde.dylib
       0x1a44f6000 -        0x1a44f6fff  com.apple.ApplicationServices (48 - 50) <E2DEB08B-6BA2-3E10-AAD7-D6591D314CC2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
       0x1a47e6000 -        0x1a47e6fff  libHeimdalProxy.dylib (79) <6BF8928C-CF16-3268-943D-685C2E2E0221> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
       0x1a488d000 -        0x1a488dfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <9509047A-2346-3D7A-8CC7-905F251C815B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
       0x1a51fb000 -        0x1a5201fff  com.apple.ASEProcessing (1.26.0 - 1.26.0) <53DEC230-187C-3F4B-8444-D3218C4A9774> /System/Library/PrivateFrameworks/ASEProcessing.framework/Versions/A/ASEProcessing
       0x1a6178000 -        0x1a617bfff  com.apple.Cocoa (6.11 - 23) <0F705E7C-094F-3DCD-9844-28C317968DA7> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
       0x1a66a7000 -        0x1a66aafff  com.apple.IOSurfaceAccelerator (1.0.0 - 1.0.0) <0ED40CA5-4630-30C1-8269-760F07254019> /System/Library/PrivateFrameworks/IOSurfaceAccelerator.framework/Versions/A/IOSurfaceAccelerator
       0x1a76ff000 -        0x1a7726fff  com.apple.openscripting (1.7 - 190) <2581CA4F-1078-373A-AEC9-A37BB6AB1C7A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
       0x1a7727000 -        0x1a772afff  com.apple.securityhi (9.0 - 55008) <8600AC67-C075-3589-9133-0FF756478C02> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
       0x1a772b000 -        0x1a772efff  com.apple.ink.framework (10.15 - 227) <D6511362-CB24-3D1A-90DA-3B328AA4B8B0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
       0x1a772f000 -        0x1a7732fff  com.apple.CommonPanels (1.2.6 - 101) <4A1FA67E-4465-3526-8B51-B27E2D75C7D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
       0x1a7733000 -        0x1a773afff  com.apple.ImageCapture (1711.5.1 - 1711.5.1) <3A2FA348-7788-3CCE-9D8D-38082EF36290> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
       0x1ada2c000 -        0x1ada2ffff  com.apple.print.framework.Print (15 - 271) <608B63C4-B09D-3AB7-9FBA-E8D19B327883> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
       0x1ada30000 -        0x1ada33fff  com.apple.Carbon (160 - 164) <201024F3-8E53-389C-941D-252ADD8A6837> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
       0x1adcfa000 -        0x1add16fff  com.apple.private.SystemPolicy (1.0 - 1) <A34EC131-895E-399F-A364-0D4D733468BE> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy
       0x1ae681000 -        0x1ae693fff  libmis.dylib (274.120.2) <2929DB14-04E5-3850-A2BC-4D5BD87AC39A> /usr/lib/libmis.dylib
       0x1b204a000 -        0x1b2063fff  libCGInterfaces.dylib (544.4) <88487307-BD9D-3504-A10D-5432E3C4CAE4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
       0x1c5c8b000 -        0x1c5c8efff  com.apple.ForceFeedback (1.0.6 - 1.0.6) <01FD8CDE-62B1-376A-B264-731D90EC87F3> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback
       0x1cdc27000 -        0x1cdc4cfff  libKoreanConverter.dylib (90) <B2018C0B-666B-3023-B163-86A20FF32963> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
       0x1d42d1000 -        0x1d42d7fff  libCoreFSCache.dylib (200.8) <52F5662B-95C9-336F-831A-19DB2F71083C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
       0x1d42d8000 -        0x1d42ddfff  libCoreVMClient.dylib (200.8) <FC5A0CC0-8A28-3BC7-9D05-6017C0EC6A74> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
       0x1d42de000 -        0x1d42edfff  com.apple.opengl (18.5.8 - 18.5.8) <A22D5F11-17FF-31E9-84DA-54D03277A207> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
       0x1d42ee000 -        0x1d42f0fff  libCVMSPluginSupport.dylib (18.5.8) <5F3A8682-E665-3FC7-891D-50EA51F4739A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
       0x1d42f1000 -        0x1d42f9fff  libGFXShared.dylib (18.5.8) <2C0617B2-21F0-3D68-A614-76D6CED049B6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
       0x1d42fa000 -        0x1d4332fff  libGLImage.dylib (18.5.8) <BC775E59-040A-354D-BE44-D67EBCB50054> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
       0x1d4333000 -        0x1d436bfff  libGLU.dylib (18.5.8) <FCBA1FF8-DA58-3590-A85F-C12C89C6DFF1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
       0x1d44d9000 -        0x1d44e3fff  libGL.dylib (18.5.8) <AAC1D423-753E-302E-9905-41B7C5000D83> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
       0x1d4677000 -        0x1d46d6fff  com.apple.opencl (4.5 - 4.5) <93299FE3-0BF7-36B5-9501-08EEC05AD3A2> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
       0x1d5e6b000 -        0x1d5e8efff  com.apple.audio.OpenAL (1.8 - 1.8) <DF6C2066-65C9-35E6-919F-2702227D4088> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=860.4M resident=0K(0%) swapped_out_or_unallocated=860.4M(100%)
Writable regions: Total=612.2M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=612.2M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Activity Tracing                   256K        1
CG backing stores                 3840K        6
CoreGraphics                        16K        1
CoreUI image data                  160K        1
Kernel Alloc Once                   32K        1
MALLOC                           200.9M       33
MALLOC guard page                   64K        3
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
STACK GUARD                        272K       17
Stack                             9728K       17
VM_ALLOCATE                        1.0G       12
__AUTH                             586K      132
__AUTH_CONST                      8617K      279
__DATA                            51.5M      269
__DATA_CONST                      15.2M      278
__DATA_DIRTY                       598K       98
__FONT_DATA                          4K        1
__LINKEDIT                       536.1M        5
__OBJC_CONST                      1155K      110
__OBJC_RO                         75.0M        1
__OBJC_RW                         2576K        1
__TEXT                           324.3M      296
__UNICODE                          588K        1
mapped file                       72.3M       13
shared memory                      912K       15
TOTAL                              2.6G     1592
TOTAL, minus reserved VM space     2.3G     1592
Model: MacBookPro17,1, BootROM 6723.120.33.0.1, proc 8:4:4 processors, 8 GB, SMC
Graphics: kHW_AppleM1Item, Apple M1, spdisplays_builtin
Memory Module: LPDDR4
AirPort: spairport_wireless_card_type_airport_extreme, wl0: Apr  5 2021 17:07:06 version 18.50.40.6.7.8.118 FWID 01-cf679ea7
Bluetooth: Version 8.0.5d3, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB 3.1 Bus
USB Device: USB Receiver
Thunderbolt Bus: MacBook Pro, Apple Inc.
2.93 ARM64 Beta gets crashes on startup on MacOS 11.4 Beta + MacBookPro M1 base model. Specific build version is current daily build. April, 19-2.93.0-c75b2019e101. By the way, official build 2.92 works fine. and here's the full crash log. ``` Process: Blender [9332] Path: /Applications/Blender.app/Contents/MacOS/Blender Identifier: org.blenderfoundation.blender Version: 2.93.0 (2.93.0 2021-04-19) Code Type: ARM-64 (Native) Parent Process: ??? [1] Responsible: Blender [9332] User ID: 501 Date/Time: 2021-05-12 10:50:23.812 +0900 OS Version: macOS 11.4 (20F5046g) Report Version: 12 Anonymous UUID: DC7A5F50-5974-E457-91C2-D11DB53F8EE6 Sleep/Wake UUID: 82DBE68B-D77D-46F5-A871-E712D3DB131E Time Awake Since Boot: 31000 seconds Time Since Wake: 2100 seconds System Integrity Protection: enabled Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Application Specific Information: abort() called terminating with uncaught exception of type boost::locale::conv::conversion_error: Conversion failed Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 libsystem_kernel.dylib 0x0000000191cf0e48 __pthread_kill + 8 1 libsystem_pthread.dylib 0x0000000191d2343c pthread_kill + 292 2 libsystem_c.dylib 0x0000000191c6b4e0 __abort + 116 3 libsystem_c.dylib 0x0000000191c6b46c abort + 116 4 libc++abi.dylib 0x0000000191ce1b44 abort_message + 132 5 libc++abi.dylib 0x0000000191cd2e3c demangling_terminate_handler() + 284 6 libobjc.A.dylib 0x0000000191bcbca4 _objc_terminate() + 160 7 libc++abi.dylib 0x0000000191ce0f2c std::__terminate(void (*)()) + 20 8 libc++abi.dylib 0x0000000191ce3c0c __cxxabiv1::failed_throw(__cxxabiv1::__cxa_exception*) + 36 9 libc++abi.dylib 0x0000000191ce3bb8 __cxa_throw + 140 10 org.blenderfoundation.blender 0x000000010912f184 std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > boost::locale::conv::impl::iconverter_base::real_convert<char, char>(char const*, char const*) + 528 11 org.blenderfoundation.blender 0x000000010912e2e8 boost::locale::conv::impl::convert_between(char const*, char const*, char const*, char const*, boost::locale::conv::method_type) + 144 12 org.blenderfoundation.blender 0x000000010913897c boost::locale::gnu_gettext::mo_message<char>::load_file(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, int, boost::function<std::__1::vector<char, std::__1::allocator<char> > (std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&)> const&) + 1608 13 org.blenderfoundation.blender 0x00000001091378e4 boost::locale::gnu_gettext::mo_message<char>::mo_message(boost::locale::gnu_gettext::messages_info const&) + 2452 14 org.blenderfoundation.blender 0x0000000109136edc boost::locale::message_format<char>* boost::locale::gnu_gettext::create_messages_facet<char>(boost::locale::gnu_gettext::messages_info const&) + 36 15 org.blenderfoundation.blender 0x0000000109161434 boost::locale::impl_posix::posix_localization_backend::install(std::__1::locale const&, unsigned int, unsigned int) + 1684 16 org.blenderfoundation.blender 0x0000000109133b88 boost::locale::generator::generate(std::__1::locale const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) const + 440 17 org.blenderfoundation.blender 0x000000010913399c boost::locale::generator::generate(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) const + 68 18 org.blenderfoundation.blender 0x00000001034f4168 bl_locale_set + 360 19 org.blenderfoundation.blender 0x0000000102811994 BLT_lang_set + 240 20 org.blenderfoundation.blender 0x00000001027bef64 WM_init + 224 21 org.blenderfoundation.blender 0x00000001023c8d74 main + 808 22 libdyld.dylib 0x0000000191d41420 start + 4 Thread 1: 0 libsystem_kernel.dylib 0x0000000191ce8df0 semaphore_wait_trap + 8 1 libdispatch.dylib 0x0000000191b743f8 _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x0000000191b74abc _dispatch_semaphore_wait_slow + 132 3 org.blenderfoundation.blender 0x0000000106f7609c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 org.blenderfoundation.blender 0x0000000106f74ca4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 6 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 2: 0 libsystem_kernel.dylib 0x0000000191ce8df0 semaphore_wait_trap + 8 1 libdispatch.dylib 0x0000000191b743f8 _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x0000000191b74abc _dispatch_semaphore_wait_slow + 132 3 org.blenderfoundation.blender 0x0000000106f7609c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 org.blenderfoundation.blender 0x0000000106f74ca4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 6 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 3: 0 libsystem_kernel.dylib 0x0000000191ce8df0 semaphore_wait_trap + 8 1 libdispatch.dylib 0x0000000191b743f8 _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x0000000191b74abc _dispatch_semaphore_wait_slow + 132 3 org.blenderfoundation.blender 0x0000000106f7609c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 org.blenderfoundation.blender 0x0000000106f74ca4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 6 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 4: 0 libsystem_kernel.dylib 0x0000000191ce8df0 semaphore_wait_trap + 8 1 libdispatch.dylib 0x0000000191b743f8 _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x0000000191b74abc _dispatch_semaphore_wait_slow + 132 3 org.blenderfoundation.blender 0x0000000106f7609c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 org.blenderfoundation.blender 0x0000000106f74ca4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 6 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 5: 0 libsystem_kernel.dylib 0x0000000191ce8df0 semaphore_wait_trap + 8 1 libdispatch.dylib 0x0000000191b743f8 _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x0000000191b74abc _dispatch_semaphore_wait_slow + 132 3 org.blenderfoundation.blender 0x0000000106f7609c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 org.blenderfoundation.blender 0x0000000106f74ca4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 6 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 6: 0 libsystem_kernel.dylib 0x0000000191ce8df0 semaphore_wait_trap + 8 1 libdispatch.dylib 0x0000000191b743f8 _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x0000000191b74abc _dispatch_semaphore_wait_slow + 132 3 org.blenderfoundation.blender 0x0000000106f7609c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 org.blenderfoundation.blender 0x0000000106f74ca4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 6 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 7: 0 libsystem_kernel.dylib 0x0000000191ce8df0 semaphore_wait_trap + 8 1 libdispatch.dylib 0x0000000191b743f8 _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x0000000191b74abc _dispatch_semaphore_wait_slow + 132 3 org.blenderfoundation.blender 0x0000000106f7609c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 org.blenderfoundation.blender 0x0000000106f74ca4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 6 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 8: 0 libsystem_kernel.dylib 0x0000000191ce8df0 semaphore_wait_trap + 8 1 libdispatch.dylib 0x0000000191b743f8 _dispatch_sema4_wait + 28 2 libdispatch.dylib 0x0000000191b74abc _dispatch_semaphore_wait_slow + 132 3 org.blenderfoundation.blender 0x0000000106f7609c IlmThread_2_5::(anonymous namespace)::DefaultWorkerThread::run() + 64 4 org.blenderfoundation.blender 0x0000000106f74ca4 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (IlmThread_2_5::Thread::*)(), IlmThread_2_5::Thread*> >(void*) + 64 5 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 6 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 9: 0 libsystem_pthread.dylib 0x0000000191d1e5cc start_wqthread + 0 Thread 10: 0 libsystem_pthread.dylib 0x0000000191d1e5cc start_wqthread + 0 Thread 11:: AMCP Logging Spool 0 libsystem_kernel.dylib 0x0000000191ce8df0 semaphore_wait_trap + 8 1 com.apple.audio.caulk 0x0000000199a99934 caulk::mach::semaphore::wait_or_error() + 28 2 com.apple.audio.caulk 0x0000000199a836e0 caulk::semaphore::timed_wait(double) + 168 3 com.apple.audio.caulk 0x0000000199a835cc caulk::concurrent::details::worker_thread::run() + 44 4 com.apple.audio.caulk 0x0000000199a8330c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 96 5 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 6 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 12: 0 libsystem_kernel.dylib 0x0000000191ce8e08 semaphore_timedwait_trap + 8 1 libdispatch.dylib 0x0000000191b74474 _dispatch_sema4_timedwait + 64 2 libdispatch.dylib 0x0000000191b74a84 _dispatch_semaphore_wait_slow + 76 3 libdispatch.dylib 0x0000000191b85430 _dispatch_worker_thread + 304 4 libsystem_pthread.dylib 0x0000000191d23878 _pthread_start + 320 5 libsystem_pthread.dylib 0x0000000191d1e5e0 thread_start + 8 Thread 13: 0 libsystem_pthread.dylib 0x0000000191d1e5cc start_wqthread + 0 Thread 14: 0 libsystem_pthread.dylib 0x0000000191d1e5cc start_wqthread + 0 Thread 15: 0 libsystem_pthread.dylib 0x0000000191d1e5cc start_wqthread + 0 Thread 16: 0 libsystem_pthread.dylib 0x0000000191d1e5cc start_wqthread + 0 Thread 0 crashed with ARM Thread State (64-bit): x0: 0x0000000000000000 x1: 0x0000000000000000 x2: 0x0000000000000000 x3: 0x0000000000000000 x4: 0x0000000000000000 x5: 0x0000000000989680 x6: 0x0000000000000064 x7: 0x0000000000000300 x8: 0x4973dfb0b4699048 x9: 0x4973dfb1a5f76d08 x10: 0x00000000000003e8 x11: 0x0000000000000004 x12: 0x0000000000000000 x13: 0x0000000000000001 x14: 0x0000000000000010 x15: 0x0000000000000000 x16: 0x0000000000000148 x17: 0x0000000200c1ee90 x18: 0x0000000115b273bc x19: 0x0000000000000006 x20: 0x00000001119efd40 x21: 0x0000000000000103 x22: 0x00000001119efe20 x23: 0x0000000149643660 x24: 0x0000000000000040 x25: 0x000000016dbd3088 x26: 0x0000000000000002 x27: 0x000000000000005c x28: 0x0000000000000030 fp: 0x000000016dbd2a90 lr: 0x0000000191d2343c sp: 0x000000016dbd2a70 pc: 0x0000000191cf0e48 cpsr: 0x40000000 far: 0x0000000110fe2684 esr: 0x56000080 Binary Images: 0x10222c000 - 0x10b3c7fff +org.blenderfoundation.blender (2.93.0 - 2.93.0 2021-04-19) <44CF8416-B071-3102-872D-4111E49341B8> /Applications/Blender.app/Contents/MacOS/Blender 0x111734000 - 0x111797fff +libomp.dylib (0) <86EC26AD-86C9-39D7-9666-90CC1FFF8605> /Applications/Blender.app/Contents/Resources/lib/libomp.dylib 0x111934000 - 0x1119b3fff dyld (851.27) <339EDF59-EF26-3EEF-8B67-82BE83D98224> /usr/lib/dyld 0x191a7e000 - 0x191a7ffff libsystem_blocks.dylib (79) <2CED50D9-55BC-33F8-ADA9-4C630E48C42A> /usr/lib/system/libsystem_blocks.dylib 0x191a80000 - 0x191ab7fff libxpc.dylib (2038.100.48) <F304C08D-A098-3C01-B823-437A09B279A2> /usr/lib/system/libxpc.dylib 0x191ab8000 - 0x191acffff libsystem_trace.dylib (1277.120.1) <888E6227-F5B6-3FFD-B42E-F3783BAAD74A> /usr/lib/system/libsystem_trace.dylib 0x191ad0000 - 0x191b43fff libcorecrypto.dylib (1000.120.1) <DAABADB9-C651-3B63-ABE5-CBE6134AFFEF> /usr/lib/system/libcorecrypto.dylib 0x191b44000 - 0x191b6ffff libsystem_malloc.dylib (317.100.9.111.1) <E8EBD657-10CE-368D-BD74-D8C3F07BDC84> /usr/lib/system/libsystem_malloc.dylib 0x191b70000 - 0x191bb4fff libdispatch.dylib (1271.120.1) <6EC996CA-9F27-3AD2-936A-793E3753B908> /usr/lib/system/libdispatch.dylib 0x191bb5000 - 0x191beefff libobjc.A.dylib (824) <343E8C55-BF34-3567-B795-4D21CB358199> /usr/lib/libobjc.A.dylib 0x191bef000 - 0x191bf1fff libsystem_featureflags.dylib (28.60.1) <D8285F60-D29F-3D75-9DAB-8D0430E025C2> /usr/lib/system/libsystem_featureflags.dylib 0x191bf2000 - 0x191c73fff libsystem_c.dylib (1439.100.3) <30CBC13C-DD0D-3F0F-8920-B5916BE25B35> /usr/lib/system/libsystem_c.dylib 0x191c74000 - 0x191ccffff libc++.1.dylib (905.6) <632294A8-E3B8-3236-9A94-987D6926092C> /usr/lib/libc++.1.dylib 0x191cd0000 - 0x191ce7fff libc++abi.dylib (905.6) <8B6F0D27-CE69-34A8-AAE0-11692319C356> /usr/lib/libc++abi.dylib 0x191ce8000 - 0x191d1bfff libsystem_kernel.dylib (7195.120.38.111.1) <E924BEF2-0A38-3AEE-8EA9-C21689C4EAC5> /usr/lib/system/libsystem_kernel.dylib 0x191d1c000 - 0x191d28fff libsystem_pthread.dylib (454.120.1) <4FC8BC50-13F5-3060-85B7-0EB4780A1743> /usr/lib/system/libsystem_pthread.dylib 0x191d29000 - 0x191d6afff libdyld.dylib (851.27) <0BEDEA15-64BB-3F0B-9B30-9120B3AB5073> /usr/lib/system/libdyld.dylib 0x191d6b000 - 0x191d71fff libsystem_platform.dylib (254.80.2) <AA657FC3-38C2-3C1B-97C3-30FB26D137A5> /usr/lib/system/libsystem_platform.dylib 0x191d72000 - 0x191d9dfff libsystem_info.dylib (542.40.3) <E174A7F8-F02F-3C01-BA3D-1E4C4E76A581> /usr/lib/system/libsystem_info.dylib 0x191d9e000 - 0x19224cfff com.apple.CoreFoundation (6.9 - 1776.101) <F195FE40-2A56-3616-AD09-5B2800F8D680> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x19224d000 - 0x192484fff com.apple.LaunchServices (1122.36 - 1122.36) <C0FB8957-8CAD-3CA0-B1AE-03BA9AB74CD8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x192485000 - 0x19255efff com.apple.gpusw.MetalTools (1.0 - 1) <97547801-31DE-3530-95FB-81C417A13FA1> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools 0x19255f000 - 0x1927c9fff libBLAS.dylib (1336.101.1) <6B1D986A-82C8-3A2C-8F7C-E56CC3142502> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x1927ca000 - 0x192814fff com.apple.Lexicon-framework (1.0 - 86.2) <29806734-1740-387C-B29C-6B318B4E9944> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon 0x192815000 - 0x192878fff libSparse.dylib (106) <72926215-C598-355F-88C9-4CDDD33BF4B9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib 0x192879000 - 0x192900fff com.apple.SystemConfiguration (1.20 - 1.20) <4A4B8948-C1C0-3F0A-90F5-D2E299604E11> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x192901000 - 0x192934fff libCRFSuite.dylib (50) <71114FAA-0C0B-3760-AE5A-F354CAF4D047> /usr/lib/libCRFSuite.dylib 0x192935000 - 0x192b63fff libmecabra.dylib (929.9) <89D395B6-586B-30E7-8DEF-1FA106D52267> /usr/lib/libmecabra.dylib 0x192b64000 - 0x192eeffff com.apple.Foundation (6.9 - 1776.101) <58F1E2E6-5998-3D3A-BABE-EB1E12306997> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x192ef0000 - 0x192fdffff com.apple.LanguageModeling (1.0 - 247.3) <7C470214-EA8E-347E-95BC-7DFB5E90F1F0> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x192fe0000 - 0x193102fff com.apple.CoreDisplay (236.4 - 236.4) <472BE30C-A9CB-3DE6-9B9D-0C9F140494B5> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay 0x193103000 - 0x193366fff com.apple.audio.AudioToolboxCore (1.0 - 1181.64) <74888403-4690-3F20-94F0-18CC6B7831BC> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore 0x193367000 - 0x193536fff com.apple.CoreText (677.5.0.3 - 677.5.0.3) <ADA16F61-9DEA-3143-AF37-0CF6A505E51C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x193537000 - 0x193b51fff com.apple.audio.CoreAudio (5.0 - 5.0) <E23DC572-59CE-3222-B7E6-CA98573CC295> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x193b52000 - 0x193eb5fff com.apple.security (7.0 - 59754.120.9) <63F64CF4-2AFD-360F-BA35-176615F79D90> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x193eb6000 - 0x194127fff libicucore.A.dylib (66112) <8A16DBEE-4A05-3348-B2ED-54617EF58F11> /usr/lib/libicucore.A.dylib 0x194128000 - 0x194132fff libsystem_darwin.dylib (1439.100.3) <B4565E40-67C8-373C-80DF-947799DB2776> /usr/lib/system/libsystem_darwin.dylib 0x194133000 - 0x194426fff com.apple.CoreServices.CarbonCore (1307.2 - 1307.2) <B4F3D631-0CF3-3911-A068-65907E1276C8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x194427000 - 0x194462fff com.apple.CoreServicesInternal (476.1.1 - 476.1.1) <1965E61F-ACAC-345E-ABB9-1E2448ED9BD8> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal 0x194463000 - 0x19449efff com.apple.CSStore (1122.36 - 1122.36) <B3952F41-9A7A-39E5-AAE0-8695C4DFFC94> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore 0x19449f000 - 0x19456afff com.apple.framework.IOKit (2.0.2 - 1845.120.5) <01D52842-7ADB-345D-B84E-60344FBB6DB3> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x19456b000 - 0x194576fff libsystem_notify.dylib (279.40.4) <80E87E4F-1567-3F00-BDE7-8273B41CA055> /usr/lib/system/libsystem_notify.dylib 0x194577000 - 0x1945c4fff libsandbox.1.dylib (1441.120.3) <416AACAB-855A-36BA-8FC9-525D09CBE905> /usr/lib/libsandbox.1.dylib 0x1945c5000 - 0x195304fff com.apple.AppKit (6.9 - 2022.50.104) <17F58B9C-0612-3CB8-B765-B306F06283FE> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x195305000 - 0x19552bfff com.apple.UIFoundation (1.0 - 728.7) <B3E73C57-A564-3657-A1E1-F1E60894195E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation 0x19552c000 - 0x19553efff com.apple.UniformTypeIdentifiers (636.9 - 636.9) <3149CCF8-A6BC-37C0-B2F9-A21C1CDF2DA6> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers 0x19553f000 - 0x1956a9fff com.apple.desktopservices (1.20 - 1346.5.1) <4E96CCCF-C226-3953-9E2F-AA0CDC7A13DC> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x195976000 - 0x1960b7fff libnetwork.dylib (2288.120.5) <22F5C582-BD00-3297-AF4D-8FA7185E0FBC> /usr/lib/libnetwork.dylib 0x1960b8000 - 0x196540fff com.apple.CFNetwork (1240.0.1 - 1240.0.1) <4C06A841-97B1-3B46-B376-03E383709D61> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x196541000 - 0x196550fff libsystem_networkextension.dylib (1295.120.5) <BB5691DB-71A5-3EE9-98F3-9FED1072CBD0> /usr/lib/system/libsystem_networkextension.dylib 0x196551000 - 0x196552fff libenergytrace.dylib (22.100.1) <DD882EE3-2743-3E93-8F0B-909EF31A20EA> /usr/lib/libenergytrace.dylib 0x196553000 - 0x1965a5fff libMobileGestalt.dylib (978.120.1) <D13EA97B-C4F2-3499-BF4D-B2DB43DEE75E> /usr/lib/libMobileGestalt.dylib 0x1965a6000 - 0x1965bdfff libsystem_asl.dylib (385) <97FF7122-7363-3A4A-ACA1-D187F59B9017> /usr/lib/system/libsystem_asl.dylib 0x1965be000 - 0x1965d7fff com.apple.TCC (1.0 - 1) <131655EA-7559-3795-91F4-B55CF6720C48> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x1965d8000 - 0x196942fff com.apple.SkyLight (1.600.0 - 586) <61850B0C-7A24-3F87-A8AD-23CF55B0C74A> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight 0x196943000 - 0x196f30fff com.apple.CoreGraphics (2.0 - 1463.14.2) <46E3D40A-B5A7-391B-8EED-64D6938F78A4> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x196f31000 - 0x197026fff com.apple.ColorSync (4.13.0 - 3473.4.3) <E14A5DA5-486D-3D42-A1D4-8FB76BC6E1C0> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x197027000 - 0x197082fff com.apple.HIServices (1.22 - 715) <BAED71F0-107D-3674-AC30-E7FD0E0DBDA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x1973dc000 - 0x197784fff com.apple.CoreData (120 - 1048) <0E3F15FB-2089-30A9-8630-86C8C6F4490D> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x197785000 - 0x19779bfff com.apple.ProtocolBuffer (1 - 285.24.10.20.1) <826FBECC-F1FF-38FF-9DFD-1FBC85EB6D54> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer 0x19779c000 - 0x197939fff libsqlite3.dylib (321.3) <AFACE79D-E5C7-33A2-8426-D936D49E3742> /usr/lib/libsqlite3.dylib 0x19793a000 - 0x1979aefff com.apple.Accounts (113 - 113) <F74FABDD-7EB7-3AF8-A26F-DD06F946B9BA> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts 0x1979af000 - 0x1979c5fff com.apple.commonutilities (8.0 - 900) <AAECA736-B6D4-3E4B-B8C1-6E47D2E955CA> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities 0x1979c6000 - 0x197a48fff com.apple.BaseBoard (526 - 526) <FF05EA0F-7BB9-328E-AF95-B5A8298DE161> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard 0x197a49000 - 0x197a96fff com.apple.RunningBoardServices (1.0 - 505.100.8) <75E9AEEE-7FC6-33B1-8A34-ED163C064772> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices 0x197a97000 - 0x197b0afff com.apple.AE (918.6 - 918.6) <2844474D-715D-3B8F-9BD7-483A0EEDBAB5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x197b0b000 - 0x197b12fff libdns_services.dylib (1310.120.1) <253B2038-3433-39EE-AFF2-F37CA582C550> /usr/lib/libdns_services.dylib 0x197b13000 - 0x197b1afff libsystem_symptoms.dylib (1431.100.22) <9D2D8857-D485-3F64-89EF-460CE7906297> /usr/lib/system/libsystem_symptoms.dylib 0x197b1b000 - 0x197c71fff com.apple.Network (1.0 - 1) <F1D4F682-4747-3691-A778-1BF9C00DC0CB> /System/Library/Frameworks/Network.framework/Versions/A/Network 0x197c72000 - 0x197ca4fff com.apple.analyticsd (1.0 - 1) <BF8C553C-BD73-3431-935D-B817C5DD5F73> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics 0x197ca5000 - 0x197ca7fff libDiagnosticMessagesClient.dylib (112) <8CA1B745-17A3-3B36-85F1-48496702DFA7> /usr/lib/libDiagnosticMessagesClient.dylib 0x197ca8000 - 0x197cf3fff com.apple.spotlight.metadata.utilities (1.0 - 2150.17) <0CD94349-7C55-314D-AD50-8F7202382572> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities 0x197cf4000 - 0x197d8dfff com.apple.Metadata (10.7.0 - 2150.17) <B5FC0247-9AA3-3DC9-BFD3-B46702458352> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x197d8e000 - 0x197d94fff com.apple.DiskArbitration (2.7 - 2.7) <20DC2DEB-8A8D-3572-8700-73FD3AFA2CB4> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x197d95000 - 0x19809ffff com.apple.vImage (8.1 - 544.4) <BA20545D-127A-33D3-8281-D13231C004BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x1980a0000 - 0x19835cfff com.apple.QuartzCore (1.11 - 927.18) <8BFE5237-8D23-390C-9BC9-FF0F8E106287> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x19835d000 - 0x19839efff libFontRegistry.dylib (309) <F8BE546F-7E42-3479-A7FA-372180DD5D23> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x19839f000 - 0x1984b6fff com.apple.coreui (2.1 - 692.1) <C01BBA9A-5297-3CE1-ABB9-81CB9B35F642> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x198597000 - 0x1985a1fff com.apple.PerformanceAnalysis (1.278.3 - 278.3) <0B218980-1B58-3819-9A53-74AFF5C0DB82> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x1985a2000 - 0x1985affff com.apple.OpenDirectory (11.4 - 230.40.1) <7251BC87-CA5A-3F45-AF0A-F30FDF9779E2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x1985b0000 - 0x1985cffff com.apple.CFOpenDirectory (11.4 - 230.40.1) <B4E46055-1C85-3B92-8BEA-CC759D820311> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x1985d0000 - 0x1985d8fff com.apple.CoreServices.FSEvents (1290.120.1 - 1290.120.1) <1F9993CA-44F9-30DD-AA7F-B4A30FE609E5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x1985d9000 - 0x1985fcfff com.apple.coreservices.SharedFileList (144 - 144) <04F87F10-14CD-3B47-91D2-5A7CFCB04043> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x1985fd000 - 0x1985fffff libapp_launch_measurement.dylib (14.1) <D30606D2-3CCC-38A8-B278-9E2F0BED8462> /usr/lib/libapp_launch_measurement.dylib 0x198600000 - 0x198642fff com.apple.CoreAutoLayout (1.0 - 21.10.1) <D4A2F546-0925-3CF4-AA91-2BE9C03C87C1> /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout 0x198643000 - 0x19872ffff libxml2.2.dylib (34.9) <F955296B-26F6-34DE-B679-204DF088FF1A> /usr/lib/libxml2.2.dylib 0x198730000 - 0x198783fff com.apple.CoreVideo (1.8 - 414.7) <53004F84-EBA2-306D-9827-7FE3EA67081F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x198784000 - 0x198786fff com.apple.loginsupport (1.0 - 1) <9C398F00-056D-3D13-B84F-575D317A3C84> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0x1987ae000 - 0x1987ccfff com.apple.UserManagement (1.0 - 1) <528AC561-7760-3526-88B0-B65BCA3EB4F4> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement 0x199964000 - 0x199975fff libsystem_containermanager.dylib (318.100.4) <7776B275-9187-3A56-9645-DDE4A33B36CD> /usr/lib/system/libsystem_containermanager.dylib 0x199976000 - 0x199987fff com.apple.IOSurface (290.7 - 290.7) <2F8F5618-2A0D-36D0-B4D5-D1AB5D687767> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x199988000 - 0x199991fff com.apple.IOAccelerator (442.9 - 442.9) <1BCBD1DD-E800-3693-A144-1A33989ADC3B> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0x199992000 - 0x199a80fff com.apple.Metal (244.201 - 244.201) <E766B61F-2FD6-387F-A847-1DD57B2370BD> /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x199a81000 - 0x199aa0fff com.apple.audio.caulk (1.0 - 70) <CBE64C48-D736-34D3-B9D3-43977A8A3D51> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk 0x199aa1000 - 0x199c42fff com.apple.CoreMedia (1.0 - 2775.15.4.1) <AF279EE9-48EC-3FFD-A78F-752E51A8ADBE> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia 0x199c43000 - 0x199d9bfff libFontParser.dylib (305.5.0.1) <B0B1A5D6-03C1-339F-A0A6-C74F27ADBC3D> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib 0x199d9c000 - 0x19a0a6fff com.apple.HIToolbox (2.1.1 - 1061.9) <9A6334A3-85B6-32C9-A95C-C5886F2EE693> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x19a0a7000 - 0x19a0befff com.apple.framework.DFRFoundation (1.0 - 266) <D9D4654C-632C-3C71-BE4E-B038B25E2A4D> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation 0x19a0bf000 - 0x19a0c2fff com.apple.dt.XCTTargetBootstrap (1.0 - 18119.1) <DB60E75E-6850-3ECD-9EC0-24A24813AC7E> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap 0x19a0c3000 - 0x19a0edfff com.apple.CoreSVG (1.0 - 149) <ADF4E449-7DB3-3C65-B193-8D31F0DB5453> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG 0x19a0ee000 - 0x19a30cfff com.apple.ImageIO (3.3.0 - 2130.4.7) <F46E2C32-72D0-36A2-A3C8-8FC6DD0CA0BC> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x19a30d000 - 0x19a625fff com.apple.CoreImage (16.3.0 - 1140.2) <2531067C-0F46-3889-8A0A-418814F7B812> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x19a626000 - 0x19a68afff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <F462C547-D6B5-3799-931C-DE51D3511B99> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore 0x19a68b000 - 0x19a68ffff libsystem_configuration.dylib (1109.101.1) <2D50FBA0-08BA-31AC-92C4-E111BB220475> /usr/lib/system/libsystem_configuration.dylib 0x19a690000 - 0x19a694fff libsystem_sandbox.dylib (1441.120.3) <BF2795D6-97AA-353F-82B9-267E28502DDF> /usr/lib/system/libsystem_sandbox.dylib 0x19a695000 - 0x19a696fff com.apple.AggregateDictionary (1.0 - 1) <294D63BA-ACB8-33C1-BF39-9BB5EE4DE584> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary 0x19a697000 - 0x19a69afff com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <4277E12B-2951-37B7-89D7-10FE21AFC2E5> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo 0x19a69b000 - 0x19a69cfff liblangid.dylib (136) <37805A64-058A-3C58-920A-0456DC6E2451> /usr/lib/liblangid.dylib 0x19a69d000 - 0x19a72afff com.apple.CoreNLP (1.0 - 245.2) <75FB6912-1FD7-31BA-AF40-0DB7776E7396> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP 0x19a72b000 - 0x19a732fff com.apple.LinguisticData (1.0 - 399) <872CBE77-1589-3684-8F1A-651EDF89BE0C> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData 0x19a733000 - 0x19abf1fff libBNNS.dylib (288.100.5) <FD95EC2C-3F2A-308F-80EC-B4D9137F9E86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib 0x19abf2000 - 0x19aca0fff libvDSP.dylib (760.100.3) <983DDC6D-7901-3D2A-8340-FF3DF4364403> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x19aca1000 - 0x19acb3fff com.apple.CoreEmoji (1.0 - 128.4) <DC1509BE-5096-3B24-811A-315DFB3DDD11> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji 0x19acb4000 - 0x19acbefff com.apple.IOMobileFramebuffer (343.0.0 - 343.0.0) <B435EF85-F00B-3F3E-BF66-A819316439B8> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/Versions/A/IOMobileFramebuffer 0x19acbf000 - 0x19ad87fff com.apple.framework.CoreWLAN (16.0 - 1657) <BFB53BD7-AFD3-37E0-865B-CAA1AD2D5897> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN 0x19ad88000 - 0x19af89fff com.apple.CoreUtils (6.6 - 660.36) <AE0D1FDD-33B5-3932-B24C-F0DB1181309A> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils 0x19af8a000 - 0x19afacfff com.apple.MobileKeyBag (2.0 - 1.0) <1C93B19E-0075-3EE0-A7C5-3C5DF8EE5F6B> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag 0x19afad000 - 0x19afbcfff com.apple.AssertionServices (1.0 - 505.100.8) <624803BB-8C1F-3D66-B9A8-0018BA6028D0> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices 0x19afbd000 - 0x19b040fff com.apple.securityfoundation (6.0 - 55240.40.4) <4340FBBF-8DCD-34EB-A7FD-6F69A82DD43F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x19b041000 - 0x19b04afff com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <555EBF71-04FE-37CE-8DD4-384F31A39C66> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement 0x19b04b000 - 0x19b050fff com.apple.xpc.ServiceManagement (1.0 - 1) <E0A73971-E48E-3C7A-BF46-9BF6B1F0E054> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x19b051000 - 0x19b053fff libquarantine.dylib (119.40.2) <09225928-ADCF-3C9F-B718-5B72FCA9645A> /usr/lib/system/libquarantine.dylib 0x19b054000 - 0x19b063fff libCheckFix.dylib (31) <E6DF86BC-8069-3F8E-A46A-0E062BE8B938> /usr/lib/libCheckFix.dylib 0x19b064000 - 0x19b07afff libcoretls.dylib (169.100.1) <EF5F4EBC-CF05-3863-AF01-9DA3E6006CC3> /usr/lib/libcoretls.dylib 0x19b07b000 - 0x19b08bfff libbsm.0.dylib (68.40.1) <05E20C6D-9980-3642-BD03-0600E7078D16> /usr/lib/libbsm.0.dylib 0x19b08c000 - 0x19b0d1fff libmecab.dylib (929.9) <33DD036D-696C-37CC-8E37-EA1F09F2EF46> /usr/lib/libmecab.dylib 0x19b0d2000 - 0x19b0d6fff libgermantok.dylib (24) <3EE0C77B-F5E0-337C-BE6C-B10BF012E861> /usr/lib/libgermantok.dylib 0x19b0d7000 - 0x19b0ebfff libLinearAlgebra.dylib (1336.101.1) <FE897FBD-1016-317E-BD30-83B0C5C712EA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x19b0ec000 - 0x19b2effff com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <8D332E8E-02FD-3584-B8D0-6A38972E2853> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork 0x19b2f0000 - 0x19b339fff com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <F92FEB6C-41C8-3219-9D40-315299EAA51A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector 0x19b33a000 - 0x19b48cfff com.apple.MLCompute (1.0 - 1) <F3510480-5C81-3603-A80B-EACB0F56F269> /System/Library/Frameworks/MLCompute.framework/Versions/A/MLCompute 0x19b48d000 - 0x19b4bbfff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <5522AC5A-1841-3B86-9584-BFFF1A27F512> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix 0x19b4bc000 - 0x19b50efff com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <A38A23EF-BD5F-3D81-B6A9-A1D351EE67FE> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray 0x19b50f000 - 0x19b596fff com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <87C47D66-F126-3F93-95BC-7CA8C34B3547> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSImage.framework/Versions/A/MPSImage 0x19b597000 - 0x19b5a6fff com.apple.AppleFSCompression (125 - 1.0) <47040CE1-7106-37F2-83D4-0A75069EA57D> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression 0x19b5a7000 - 0x19b5b3fff libbz2.1.0.dylib (44) <18F31C75-AA8C-3A81-9B07-02BA08A8C013> /usr/lib/libbz2.1.0.dylib 0x19b5b4000 - 0x19b5b8fff libsystem_coreservices.dylib (127.1) <7A2AAE08-E6D8-3717-869C-F1A2480A6FB4> /usr/lib/system/libsystem_coreservices.dylib 0x19b5b9000 - 0x19b5e9fff com.apple.CoreServices.OSServices (1122.36 - 1122.36) <0D7E80C6-A517-396D-BEA3-7688A78B3292> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x19b5ea000 - 0x19b6fafff com.apple.AuthKit (1.0 - 1) <3652B326-A1D9-3DCF-97F3-BA5FC2E7FCE6> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit 0x19b79e000 - 0x19b7affff libz.1.dylib (76) <45DD96E4-F382-3E35-9A82-F9E26452F25D> /usr/lib/libz.1.dylib 0x19b7b0000 - 0x19b7ddfff libsystem_m.dylib (3186.100.3) <F5408287-14C3-35E1-A515-FD3F2DF0E31C> /usr/lib/system/libsystem_m.dylib 0x19b7de000 - 0x19b7defff libcharset.1.dylib (59) <1A50A6C2-55C9-3A9E-8230-2D839B6A2004> /usr/lib/libcharset.1.dylib 0x19b7df000 - 0x19b7e4fff libmacho.dylib (980) <8E20D029-EE0B-3C6D-8818-0F9D6FE14B72> /usr/lib/system/libmacho.dylib 0x19b7e5000 - 0x19b7fcfff libkxld.dylib (7195.120.38.111.1) <9378AA97-F2E6-3248-88B9-040D286EF7CB> /usr/lib/system/libkxld.dylib 0x19b7fd000 - 0x19b80afff libcommonCrypto.dylib (60178.120.3) <BA4F0410-543D-3A2F-BA99-C903AA027F96> /usr/lib/system/libcommonCrypto.dylib 0x19b80b000 - 0x19b815fff libunwind.dylib (201) <5784C399-94C7-319B-8B15-ACB748905285> /usr/lib/system/libunwind.dylib 0x19b816000 - 0x19b81dfff liboah.dylib (203.43) <05C0F891-2202-3AD8-9B71-A40BE2B1D85B> /usr/lib/liboah.dylib 0x19b81e000 - 0x19b826fff libcopyfile.dylib (173.40.2) <D474EABA-D3D0-31D3-86F1-5A72CFC3C0CC> /usr/lib/system/libcopyfile.dylib 0x19b827000 - 0x19b82afff libcompiler_rt.dylib (102.2) <60B2CCEC-E018-3F76-83B7-4EE08CB46665> /usr/lib/system/libcompiler_rt.dylib 0x19b82b000 - 0x19b82dfff libsystem_collections.dylib (1439.100.3) <98C45455-3D00-3BAA-B2F2-CA416CF1A4A2> /usr/lib/system/libsystem_collections.dylib 0x19b82e000 - 0x19b830fff libsystem_secinit.dylib (87.60.1) <1D5CCC13-FCF3-340C-8159-947759BE25B7> /usr/lib/system/libsystem_secinit.dylib 0x19b831000 - 0x19b833fff libremovefile.dylib (49.120.1) <CC7F49F8-C835-3105-9D89-B4BEDD6A2D6D> /usr/lib/system/libremovefile.dylib 0x19b834000 - 0x19b834fff libkeymgr.dylib (31) <3A9E84C3-E3F0-3CA7-9E69-3EE9D86C66EB> /usr/lib/system/libkeymgr.dylib 0x19b835000 - 0x19b83dfff libsystem_dnssd.dylib (1310.120.1) <FE4501F4-60F6-3A24-B521-0E1A97016D03> /usr/lib/system/libsystem_dnssd.dylib 0x19b83e000 - 0x19b843fff libcache.dylib (83) <4ECB7CD0-2974-3514-9B79-77A4D7EB8D66> /usr/lib/system/libcache.dylib 0x19b844000 - 0x19b845fff libSystem.B.dylib (1292.120.1) <7F7F586D-ED67-3443-B4CF-FD2DC1081ADE> /usr/lib/libSystem.B.dylib 0x19b846000 - 0x19b849fff libfakelink.dylib (3) <BD571918-C83A-38DD-954B-6446022B6BFE> /usr/lib/libfakelink.dylib 0x19b84a000 - 0x19b84afff com.apple.SoftLinking (1.0 - 1) <F1020F09-E873-3EF4-814B-058390FF5BD4> /System/Library/PrivateFrameworks/SoftLinking.framework/Versions/A/SoftLinking 0x19b84b000 - 0x19b886fff libpcap.A.dylib (98.100.3) <52955C6B-6C4E-3B89-9DDA-71380BA49885> /usr/lib/libpcap.A.dylib 0x19b887000 - 0x19b97cfff libiconv.2.dylib (59) <AB245F1B-B394-3351-811D-2716EC5ABF8C> /usr/lib/libiconv.2.dylib 0x19b97d000 - 0x19b98ffff libcmph.dylib (8) <72EC5116-0051-305C-9340-08555980FD7C> /usr/lib/libcmph.dylib 0x19b990000 - 0x19ba00fff libarchive.2.dylib (83.100.2) <B0BF9AE7-6C7C-32E4-BDCA-13A957266FF1> /usr/lib/libarchive.2.dylib 0x19ba01000 - 0x19ba71fff com.apple.SearchKit (1.4.1 - 1.4.1) <F2018FD6-E9E0-3C24-9F89-2F30DCB012ED> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x19ba72000 - 0x19ba73fff libThaiTokenizer.dylib (3) <2BC62E9E-421D-384A-8282-9DC4574E5681> /usr/lib/libThaiTokenizer.dylib 0x19ba74000 - 0x19ba98fff com.apple.applesauce (1.0 - 16.28) <D1BF4285-6820-3497-810F-342D16E864BB> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce 0x19ba99000 - 0x19baaffff libapple_nghttp2.dylib (1.41) <2AF641D7-C381-36FC-935B-FC7EB3E8C302> /usr/lib/libapple_nghttp2.dylib 0x19bab0000 - 0x19bac2fff libSparseBLAS.dylib (1336.101.1) <99CEB929-C133-3034-8EDC-1C6C54D5086D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x19bac3000 - 0x19bac4fff com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <293D171F-4E22-3F72-A978-B8972933A5CF> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders 0x19bac5000 - 0x19bac9fff libpam.2.dylib (28.40.1) <8F1D1E88-3DB0-3657-90F6-FE0D1E20787B> /usr/lib/libpam.2.dylib 0x19baca000 - 0x19bae8fff libcompression.dylib (96.120.1) <4EECD5F9-58DF-3D30-9ED1-31289B605FF7> /usr/lib/libcompression.dylib 0x19bae9000 - 0x19baedfff libQuadrature.dylib (7) <756B04FC-6930-3AFC-8BF3-D1982B74A338> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib 0x19baee000 - 0x19bfaafff libLAPACK.dylib (1336.101.1) <47BFD025-75E3-30BE-8364-A8FB4ED3C885> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x19bfab000 - 0x19bffdfff com.apple.DictionaryServices (1.2 - 341) <961BF6C7-705F-3467-AB91-9B425472E182> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x19bffe000 - 0x19c016fff liblzma.5.dylib (16) <3DC963E2-4103-3D49-BC0C-336320841B0F> /usr/lib/liblzma.5.dylib 0x19c017000 - 0x19c018fff libcoretls_cfhelpers.dylib (169.100.1) <5B928E1E-3477-3FA0-984E-ED2E1C558AB4> /usr/lib/libcoretls_cfhelpers.dylib 0x19c019000 - 0x19c0fdfff com.apple.APFS (1677.120.1 - 1677.120.1) <CCD98309-34D5-3337-9A43-4B0D79286965> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS 0x19c0fe000 - 0x19c10bfff libxar.1.dylib (452) <2F55A8FC-2507-3238-8B19-33A73500BB26> /usr/lib/libxar.1.dylib 0x19c10c000 - 0x19c10ffff libutil.dylib (58.40.2) <6022B0A3-10A5-3366-B8A6-3944895804DB> /usr/lib/libutil.dylib 0x19c110000 - 0x19c139fff libxslt.1.dylib (17.4) <E22CAC49-EB61-383D-ABF0-BAD6D2BE6573> /usr/lib/libxslt.1.dylib 0x19c13a000 - 0x19c144fff libChineseTokenizer.dylib (37.1) <42F2E42A-F75B-359A-AC42-52B3923FCBE9> /usr/lib/libChineseTokenizer.dylib 0x19c145000 - 0x19c1b4fff libvMisc.dylib (760.100.3) <4FAA7747-C1DF-3FB3-B988-E88A096E293A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x19c1b5000 - 0x19c246fff libate.dylib (3.0.6) <1C02469A-9BA5-3292-9904-19A8FF69CF18> /usr/lib/libate.dylib 0x19c247000 - 0x19c24efff libIOReport.dylib (64.100.1) <2E8B790E-36BD-3835-A825-D74A7555FBF6> /usr/lib/libIOReport.dylib 0x19c34a000 - 0x19c351fff libMatch.1.dylib (38) <705C61A3-49D4-38FF-A258-65B50F386167> /usr/lib/libMatch.1.dylib 0x19c352000 - 0x19c3d5fff libCoreStorage.dylib (554) <F14C43A5-6291-3B1D-8347-B3136B3E6640> /usr/lib/libCoreStorage.dylib 0x19c3d6000 - 0x19c421fff com.apple.AppleVAFramework (6.1.3 - 6.1.3) <40FDE32D-B4C8-3BCE-A549-5C040514FE02> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA 0x19c422000 - 0x19c43bfff libexpat.1.dylib (26) <28B05BDE-E3A6-377E-86FD-763C83D5466A> /usr/lib/libexpat.1.dylib 0x19c43c000 - 0x19c444fff libheimdal-asn1.dylib (597.120.2) <9B69F08F-8FB7-3926-AB13-E31C2872BB94> /usr/lib/libheimdal-asn1.dylib 0x19c445000 - 0x19c457fff com.apple.IconFoundation (479.4 - 479.4) <7CD3E563-4780-3453-850F-1A929CC851BE> /System/Library/PrivateFrameworks/IconFoundation.framework/Versions/A/IconFoundation 0x19c458000 - 0x19c4bbfff com.apple.IconServices (479.4 - 479.4) <0EA391FC-873D-341A-B44D-4C21664673E1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0x19c4bc000 - 0x19c591fff com.apple.MediaExperience (1.0 - 1) <827EEC52-6FAD-3ECE-85DB-B1DD7D3D433E> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience 0x19c592000 - 0x19c5b8fff com.apple.persistentconnection (1.0 - 1.0) <CFAE4FDF-6A00-3B48-B443-25448414991B> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection 0x19c5b9000 - 0x19c5c6fff com.apple.GraphVisualizer (1.0 - 100.1) <FEE3573E-ECD6-3191-9E14-0E7436E7733D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer 0x19c5c7000 - 0x19c9d9fff com.apple.vision.FaceCore (4.3.2 - 4.3.2) <BD15FDE7-E3FE-331A-991E-334030F4EAB5> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0x19c9da000 - 0x19ca19fff com.apple.OTSVG (1.0 - 677.5.0.3) <4B9A7199-C6C4-393F-8D58-52577A788734> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG 0x19ca1a000 - 0x19ca21fff com.apple.xpc.AppServerSupport (1.0 - 2038.100.48) <AC37C623-37B4-39AE-B7A0-EC30F9BCEB49> /System/Library/PrivateFrameworks/AppServerSupport.framework/Versions/A/AppServerSupport 0x19ca22000 - 0x19ca30fff libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <52CD4656-D608-31DC-BC1C-D68EB4690A64> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib 0x19ca31000 - 0x19ca37fff libspindump.dylib (295.2) <3B5C46FD-C908-3F1F-80F0-24418BC50DE0> /usr/lib/libspindump.dylib 0x19ca38000 - 0x19caedfff com.apple.Heimdal (4.0 - 2.0) <FAA19FC1-3C27-353B-AA50-B4D6250DD0A6> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x19cc82000 - 0x19ccbcfff com.apple.bom (14.0 - 235) <B0F7555C-9577-3656-B13D-7F337B970915> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom 0x19ccbd000 - 0x19cd00fff com.apple.AppleJPEG (1.0 - 1) <5091006F-495E-3C1C-998D-64CF46074D49> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x19cd01000 - 0x19cde2fff libJP2.dylib (2130.4.7) <EA73CB27-2669-3FB0-975F-A9109E1766E0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x19cde3000 - 0x19cde6fff com.apple.WatchdogClient.framework (1.0 - 98.120.2) <E7114014-A41F-3B24-B923-7CFD12CE895D> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient 0x19cde7000 - 0x19ce1ffff com.apple.MultitouchSupport.framework (4440.3 - 4440.3) <C09CAE5B-1F73-310F-B37D-E943EDA1EEF9> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x19ce20000 - 0x19cfaefff com.apple.VideoToolbox (1.0 - 2775.15.4.1) <C984E94A-D14E-3045-ABA6-6696CF00E0B5> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox 0x19cfaf000 - 0x19cfe1fff libAudioToolboxUtility.dylib (1181.64) <F186CED9-B346-3C4A-BD5B-59069D3B0B41> /usr/lib/libAudioToolboxUtility.dylib 0x19cfe2000 - 0x19d008fff libPng.dylib (2130.4.7) <4C94F6D7-CCBD-3DCE-BD6B-78D4CD0FF7B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x19d009000 - 0x19d065fff libTIFF.dylib (2130.4.7) <0CC98D62-BCE7-3910-8118-C2122B8FFEB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x19d066000 - 0x19d084fff com.apple.IOPresentment (58 - 37) <41646B8C-5FFF-392D-A60C-A01FA23C0E96> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment 0x19d085000 - 0x19d089fff com.apple.GPUWrangler (6.3.2 - 6.3.2) <0E736E0A-6020-3C5D-88E4-F2B5AB6CD9BE> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler 0x19d08a000 - 0x19d08cfff libRadiance.dylib (2130.4.7) <828A6BB6-8611-3906-A80F-7A024F55D909> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x19d08d000 - 0x19d092fff com.apple.DSExternalDisplay (3.1 - 380) <5F874722-25A9-37FB-B573-7C24B74E8CA5> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay 0x19d093000 - 0x19d0b3fff libJPEG.dylib (2130.4.7) <B1400053-AAA8-3F42-9458-1AA173505DE4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x19d0b4000 - 0x19d0e3fff com.apple.ATSUI (1.0 - 1) <785A8C9A-031E-326C-AE71-3569EB15A801> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI 0x19d0e4000 - 0x19d0e8fff libGIF.dylib (2130.4.7) <C7111C48-2269-32D4-B194-3A4F66254865> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x19d0e9000 - 0x19d0f2fff com.apple.CMCaptureCore (1.0 - 82.4) <513AC7FE-BBCC-399A-8609-E6C39846554E> /System/Library/PrivateFrameworks/CMCaptureCore.framework/Versions/A/CMCaptureCore 0x19d0f3000 - 0x19d13afff com.apple.print.framework.PrintCore (16.1 - 531.1) <0E8B2ECC-230B-35C1-B639-3E0858C6261D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x19d13b000 - 0x19d1eefff com.apple.TextureIO (3.10.9 - 3.10.9) <528408FA-869B-3068-88F9-3800CB00CF67> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO 0x19d1ef000 - 0x19d1f7fff com.apple.InternationalSupport (1.0 - 61.1) <2C2B8BC3-8569-323B-A27A-9593C3A21927> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport 0x19d1f8000 - 0x19d26cfff com.apple.datadetectorscore (8.0 - 674) <D55F4857-7BE1-3FFC-9FF6-3F3AE7305883> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x19d26d000 - 0x19d2ccfff com.apple.UserActivity (439 - 439) <405F3A85-927F-3E68-A9CE-D79420E91EB1> /System/Library/PrivateFrameworks/UserActivity.framework/Versions/A/UserActivity 0x19e3c5000 - 0x19e3fafff libSessionUtility.dylib (76.69) <222B42E6-6CCE-3F68-AB20-3B184A302740> /System/Library/PrivateFrameworks/AudioSession.framework/libSessionUtility.dylib 0x19e3fb000 - 0x19e508fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <4676580D-38F3-35A0-8AD6-995FC8C33769> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x19e509000 - 0x19e570fff com.apple.audio.AudioSession (1.0 - 76.69) <E6A64A92-1C8A-3E12-8858-64BEC69E4586> /System/Library/PrivateFrameworks/AudioSession.framework/Versions/A/AudioSession 0x19e571000 - 0x19e583fff libAudioStatistics.dylib (27.64) <B8132A53-47F7-3AFB-AA68-F273799856A7> /usr/lib/libAudioStatistics.dylib 0x19e584000 - 0x19e597fff com.apple.speech.synthesis.framework (9.0.64 - 9.0.64) <A42FE559-1364-30FE-A673-A16B6EB900A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x19e598000 - 0x19e606fff com.apple.ApplicationServices.ATS (377 - 516) <23783698-397E-34CC-9F52-F9652E28AA27> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x19e607000 - 0x19e61ffff libresolv.9.dylib (68) <1E8126CB-911D-31F9-A103-002553CDB0FE> /usr/lib/libresolv.9.dylib 0x19e74c000 - 0x19e82bfff libSMC.dylib (20) <15B0366D-FFCD-3576-93B5-FEB652812B92> /usr/lib/libSMC.dylib 0x19e82c000 - 0x19e889fff libcups.2.dylib (494.1) <8B22B88C-DD0C-3482-8413-1B84D2399A78> /usr/lib/libcups.2.dylib 0x19e88a000 - 0x19e89dfff com.apple.LangAnalysis (1.7.0 - 254) <B15D7F8D-689C-3030-B335-974503B9869A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x19e89e000 - 0x19e8aafff com.apple.NetAuth (6.2 - 6.2) <D483D1A2-4435-3543-AA50-D65FA0C999DD> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x19e8ab000 - 0x19e8b2fff com.apple.ColorSyncLegacy (4.13.0 - 1) <FFE793E7-A8EA-3A49-8288-DBFE2CCEDD8D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy 0x19e8b3000 - 0x19e8befff com.apple.QD (4.0 - 416) <412A2EF3-042A-338B-9340-1426098A5462> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x19e8bf000 - 0x19eeaffff com.apple.audio.AudioResourceArbitration (1.0 - 1) <DB9897F3-9302-3417-9D3D-18CDD2FA3431> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration 0x19eeb0000 - 0x19eebbfff com.apple.perfdata (1.0 - 67.40.1) <0B3751C5-7F5B-3599-8245-8ABBC83B14F6> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata 0x19eebc000 - 0x19eec9fff libperfcheck.dylib (41) <E0F21E0A-3D49-3965-AD80-24E21CBF9D1F> /usr/lib/libperfcheck.dylib 0x19eeca000 - 0x19eedafff com.apple.Kerberos (3.0 - 1) <719C9664-CBB8-3880-8244-FC432F819267> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x19eedb000 - 0x19ef22fff com.apple.GSS (4.0 - 2.0) <6DE570C1-5883-3AAC-A2BE-C6EADE643B7C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x19ef23000 - 0x19ef32fff com.apple.CommonAuth (4.0 - 2.0) <084F6AB9-317C-3BED-8096-033B4AD89F4E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x19ef86000 - 0x19efa3fff com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <3C06DB73-1B86-36C0-BE35-536790EB44EC> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle 0x19efa4000 - 0x19efacfff com.apple.CorePhoneNumbers (1.0 - 1) <BB191DDA-D03B-3A0C-8F62-AC3D82942A74> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers 0x19f0f8000 - 0x19f0f8fff liblaunch.dylib (2038.100.48) <DF8E3F7B-AF35-391A-BF64-080236A90CAF> /usr/lib/system/liblaunch.dylib 0x19f8a7000 - 0x19f9e3fff com.apple.Sharing (1620 - 1620) <32AA747C-8806-36E8-BE93-13C7C79C93E7> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0x19f9e4000 - 0x19facefff com.apple.Bluetooth (8.0.5 - 8.0.5d3) <08B22D07-D6F4-360F-B8FA-21005A56B4F7> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth 0x19fae7000 - 0x19fb3ffff com.apple.ProtectedCloudStorage (1.0 - 1) <E0F4E066-5B2B-3DE3-88F8-196A25B7E416> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage 0x1a1333000 - 0x1a135afff com.apple.RemoteViewServices (2.0 - 163) <2CD5F397-A4D0-3A88-9DB9-8FFB7C40878D> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x1a135b000 - 0x1a136afff com.apple.SpeechRecognitionCore (6.1.23 - 6.1.23) <DCC312CE-8AC8-351B-9ABA-0CFD1586FA02> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore 0x1a136b000 - 0x1a1372fff com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <3F5F16E6-61A3-33C9-9604-9B86A5343D00> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x1a15a1000 - 0x1a15a1fff libsystem_product_info_filter.dylib (8.40.1) <D7907F14-A973-36D2-8565-4E4655EC44E2> /usr/lib/system/libsystem_product_info_filter.dylib 0x1a1674000 - 0x1a1674fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <31320A8A-4011-3A35-9960-3C22B56578D1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x1a1696000 - 0x1a1696fff com.apple.CoreServices (1122.36 - 1122.36) <AB0BA3BB-BAAB-3161-A3DD-301537FA9C8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x1a1852000 - 0x1a1852fff com.apple.Accelerate (1.11 - Accelerate 1.11) <71EB3025-AFEA-3D12-8403-18A582480B45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x1a20af000 - 0x1a210afff com.apple.CoreBluetooth (1.0 - 1) <B8721393-648B-30E6-BDA1-06ABF1B883B8> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth 0x1a210b000 - 0x1a2115fff com.apple.SymptomDiagnosticReporter (1.0 - 79.120.1) <61B02625-779B-3AB7-96F3-F4108EA490CB> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter 0x1a212a000 - 0x1a2135fff com.apple.AppleIDAuthSupport (1.0 - 1) <A7518B2F-E662-3F07-BA7B-61BBA70573BA> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport 0x1a2136000 - 0x1a21eafff com.apple.DiscRecording (9.0.3 - 9030.4.5) <CF92C988-0364-3538-8EEB-50E768E0C941> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording 0x1a21eb000 - 0x1a221efff com.apple.MediaKit (16 - 927.40.2) <C4891330-2CE9-37B8-9254-469E2E6AEDC1> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit 0x1a221f000 - 0x1a22fffff com.apple.DiskManagement (14.0 - 1733.100.4) <D55B3144-84CF-3192-A1BA-9E0BE1E5D16B> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement 0x1a2340000 - 0x1a2496fff com.apple.FileProvider (348.5.2 - 348.5.2) <C08E6657-396D-3D1A-B1F7-E5A5FECB33B8> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider 0x1a2497000 - 0x1a24b9fff com.apple.GenerationalStorage (2.0 - 323) <67CAFC6C-6C05-3AC2-B51F-A0235E1F802F> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0x1a2e70000 - 0x1a2eaafff com.apple.DebugSymbols (195.1 - 195.1) <C2BE0C8B-D71C-3012-A996-9236EE9671FB> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x1a2eab000 - 0x1a2f5cfff com.apple.CoreSymbolication (12.5 - 64544.69.1) <A8DDC912-FEC9-34B5-8F18-0B54FD62CED8> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x1a3e48000 - 0x1a3ea7fff com.apple.framework.Apple80211 (17.0 - 1728) <A43BEA13-584F-37DF-B65C-09A7A9F2EC56> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 0x1a3ea8000 - 0x1a3fd3fff com.apple.CoreWiFi (3.0 - 341) <E8F92CEF-6DD8-3C1F-9D5E-EACA1DB12910> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi 0x1a42ac000 - 0x1a42affff com.apple.help (1.3.8 - 71) <3DBF2D52-ABDD-3C4F-8C37-CF83D3B358E0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x1a42b0000 - 0x1a42b7fff com.apple.EFILogin (2.0 - 2) <06DF3E40-AF44-3166-8B6E-70AF19F7C287> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin 0x1a42b8000 - 0x1a42c3fff libcsfde.dylib (554) <83676304-860B-3549-BA97-CEF4038A5D89> /usr/lib/libcsfde.dylib 0x1a44f6000 - 0x1a44f6fff com.apple.ApplicationServices (48 - 50) <E2DEB08B-6BA2-3E10-AAD7-D6591D314CC2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x1a47e6000 - 0x1a47e6fff libHeimdalProxy.dylib (79) <6BF8928C-CF16-3268-943D-685C2E2E0221> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib 0x1a488d000 - 0x1a488dfff com.apple.audio.units.AudioUnit (1.14 - 1.14) <9509047A-2346-3D7A-8CC7-905F251C815B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x1a51fb000 - 0x1a5201fff com.apple.ASEProcessing (1.26.0 - 1.26.0) <53DEC230-187C-3F4B-8444-D3218C4A9774> /System/Library/PrivateFrameworks/ASEProcessing.framework/Versions/A/ASEProcessing 0x1a6178000 - 0x1a617bfff com.apple.Cocoa (6.11 - 23) <0F705E7C-094F-3DCD-9844-28C317968DA7> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x1a66a7000 - 0x1a66aafff com.apple.IOSurfaceAccelerator (1.0.0 - 1.0.0) <0ED40CA5-4630-30C1-8269-760F07254019> /System/Library/PrivateFrameworks/IOSurfaceAccelerator.framework/Versions/A/IOSurfaceAccelerator 0x1a76ff000 - 0x1a7726fff com.apple.openscripting (1.7 - 190) <2581CA4F-1078-373A-AEC9-A37BB6AB1C7A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x1a7727000 - 0x1a772afff com.apple.securityhi (9.0 - 55008) <8600AC67-C075-3589-9133-0FF756478C02> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x1a772b000 - 0x1a772efff com.apple.ink.framework (10.15 - 227) <D6511362-CB24-3D1A-90DA-3B328AA4B8B0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x1a772f000 - 0x1a7732fff com.apple.CommonPanels (1.2.6 - 101) <4A1FA67E-4465-3526-8B51-B27E2D75C7D4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x1a7733000 - 0x1a773afff com.apple.ImageCapture (1711.5.1 - 1711.5.1) <3A2FA348-7788-3CCE-9D8D-38082EF36290> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x1ada2c000 - 0x1ada2ffff com.apple.print.framework.Print (15 - 271) <608B63C4-B09D-3AB7-9FBA-E8D19B327883> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x1ada30000 - 0x1ada33fff com.apple.Carbon (160 - 164) <201024F3-8E53-389C-941D-252ADD8A6837> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x1adcfa000 - 0x1add16fff com.apple.private.SystemPolicy (1.0 - 1) <A34EC131-895E-399F-A364-0D4D733468BE> /System/Library/PrivateFrameworks/SystemPolicy.framework/Versions/A/SystemPolicy 0x1ae681000 - 0x1ae693fff libmis.dylib (274.120.2) <2929DB14-04E5-3850-A2BC-4D5BD87AC39A> /usr/lib/libmis.dylib 0x1b204a000 - 0x1b2063fff libCGInterfaces.dylib (544.4) <88487307-BD9D-3504-A10D-5432E3C4CAE4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib 0x1c5c8b000 - 0x1c5c8efff com.apple.ForceFeedback (1.0.6 - 1.0.6) <01FD8CDE-62B1-376A-B264-731D90EC87F3> /System/Library/Frameworks/ForceFeedback.framework/Versions/A/ForceFeedback 0x1cdc27000 - 0x1cdc4cfff libKoreanConverter.dylib (90) <B2018C0B-666B-3023-B163-86A20FF32963> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib 0x1d42d1000 - 0x1d42d7fff libCoreFSCache.dylib (200.8) <52F5662B-95C9-336F-831A-19DB2F71083C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x1d42d8000 - 0x1d42ddfff libCoreVMClient.dylib (200.8) <FC5A0CC0-8A28-3BC7-9D05-6017C0EC6A74> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x1d42de000 - 0x1d42edfff com.apple.opengl (18.5.8 - 18.5.8) <A22D5F11-17FF-31E9-84DA-54D03277A207> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x1d42ee000 - 0x1d42f0fff libCVMSPluginSupport.dylib (18.5.8) <5F3A8682-E665-3FC7-891D-50EA51F4739A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x1d42f1000 - 0x1d42f9fff libGFXShared.dylib (18.5.8) <2C0617B2-21F0-3D68-A614-76D6CED049B6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x1d42fa000 - 0x1d4332fff libGLImage.dylib (18.5.8) <BC775E59-040A-354D-BE44-D67EBCB50054> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x1d4333000 - 0x1d436bfff libGLU.dylib (18.5.8) <FCBA1FF8-DA58-3590-A85F-C12C89C6DFF1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x1d44d9000 - 0x1d44e3fff libGL.dylib (18.5.8) <AAC1D423-753E-302E-9905-41B7C5000D83> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x1d4677000 - 0x1d46d6fff com.apple.opencl (4.5 - 4.5) <93299FE3-0BF7-36B5-9501-08EEC05AD3A2> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x1d5e6b000 - 0x1d5e8efff com.apple.audio.OpenAL (1.8 - 1.8) <DF6C2066-65C9-35E6-919F-2702227D4088> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 0 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=860.4M resident=0K(0%) swapped_out_or_unallocated=860.4M(100%) Writable regions: Total=612.2M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=612.2M(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Activity Tracing 256K 1 CG backing stores 3840K 6 CoreGraphics 16K 1 CoreUI image data 160K 1 Kernel Alloc Once 32K 1 MALLOC 200.9M 33 MALLOC guard page 64K 3 MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated) STACK GUARD 272K 17 Stack 9728K 17 VM_ALLOCATE 1.0G 12 __AUTH 586K 132 __AUTH_CONST 8617K 279 __DATA 51.5M 269 __DATA_CONST 15.2M 278 __DATA_DIRTY 598K 98 __FONT_DATA 4K 1 __LINKEDIT 536.1M 5 __OBJC_CONST 1155K 110 __OBJC_RO 75.0M 1 __OBJC_RW 2576K 1 __TEXT 324.3M 296 __UNICODE 588K 1 mapped file 72.3M 13 shared memory 912K 15 =========== ======= ======= TOTAL 2.6G 1592 TOTAL, minus reserved VM space 2.3G 1592 Model: MacBookPro17,1, BootROM 6723.120.33.0.1, proc 8:4:4 processors, 8 GB, SMC Graphics: kHW_AppleM1Item, Apple M1, spdisplays_builtin Memory Module: LPDDR4 AirPort: spairport_wireless_card_type_airport_extreme, wl0: Apr 5 2021 17:07:06 version 18.50.40.6.7.8.118 FWID 01-cf679ea7 Bluetooth: Version 8.0.5d3, 3 services, 27 devices, 1 incoming serial ports Network Service: Wi-Fi, AirPort, en0 USB Device: USB 3.1 Bus USB Device: USB 3.1 Bus USB Device: USB Receiver Thunderbolt Bus: MacBook Pro, Apple Inc. Thunderbolt Bus: MacBook Pro, Apple Inc. ```
Author
Added subscriber: @pb29
Member
Closed as duplicate of #88877
2 Participants
Reference: blender/blender#88212
