Connect Curve Splines Node #89216
Reference: blender/blender#89216
This node join splines from the input geometry sets into a single spline, depending on the merge settings.
F
shortcut.F
and then deleting one control point in edit mode.Related Nodes
Further Questions
Implementation
A first pass should find which start and end points are within a merge threshold. Keeping this operation from having N^2 runtime will be important. Then >2-way intersections should be dealt with, then data should be copied to the result, or possible moved with
std::move
if no connections were made to a spline.Changed status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @GeorgiaPacific
Partially, this can be done now. By using
Points to Curves
:Main limitaion for now:
Select Curve Type
node.Drop Domain
node (for example, to adapt all attributes from curves to points). This will allow us to handle all curves attributes as points attributes in separate graph branch. After this,Drop Domain
again will move all attributes to curves domain back, with it value averaging.
