?? #89346
Closed
opened 2021-06-22 01:45:35 +02:00 by hatem · 4 comments
Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: blender/blender@84da05a8b8
Addon Information
Name: Material Utilities (2, 2, 0)
Author: MichaleW, ChrisHinde
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71 **Blender Version** Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: `blender/blender@84da05a8b8` Worked: (newest version of Blender that worked as expected) **Addon Information** Name: Material Utilities (2, 2, 0) Author: MichaleW, ChrisHinde **Short description of error** [Please fill out a short description of the error here] **Exact steps for others to reproduce the error** [Please describe the exact steps needed to reproduce the issue] [Based on the default startup or an attached .blend file (as simple as possible)]
Author
Added subscriber: @ahmedhatem1459
Member
Member
Member
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
This report does not contain all the requested information, which is required for us to investigate the issue. Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem. A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
2 Participants
Reference: blender/blender-addons#89346
