Optix kernels not loading #89389
Closed
opened 2021-06-23 19:12:58 +02:00 by John E · 25 comments
Operating system: Windows
Graphics card: rtx 3090
Broken: (2.93 LTS Master Hash 84da05a8b8 2021-06-02 11:21)
Worked: (2.92 Master Hash 02948a2cab 2021-02-24 16:25)
*Experiencing this on May + June Studio drivers
2.93 In any scene optix kernels will not load. Set to optix and GPU only in system. When rendering or viewport preview it sits indefinitely
through troubleshooting I read to delete optix cache and let it rebuild. Still no fix.
2.92 works no problem.
Default scene otherwise I just downloaded it, has not worked. Cuda works fine though
Test File:
default7-5.blend
**System Information** Operating system: Windows Graphics card: rtx 3090 **Blender Version** Broken: (2.93 LTS Master Hash 84da05a8b806 2021-06-02 11:21) Worked: (2.92 Master Hash 02948a2cab44 2021-02-24 16:25) *Experiencing this on May + June Studio drivers **Short description of error** 2.93 In any scene optix kernels will not load. Set to optix and GPU only in system. When rendering or viewport preview it sits indefinitely through troubleshooting I read to delete optix cache and let it rebuild. Still no fix. 2.92 works no problem. **Exact steps for others to reproduce the error** Default scene otherwise I just downloaded it, has not worked. Cuda works fine though Test File: [default7-5.blend](https://archive.blender.org/developer/F10212214/default7-5.blend)
Author
Added subscriber: @jvemedia
#89764 was marked as duplicate of this issue
#89555 was marked as duplicate of this issue
Added subscriber: @chemicalcrux
Can you attach system information? You can save it from blender by going to Help > Save System Info. Drag the resulting file into the comment box and it'll be attached.
Can you attach system information? You can save it from blender by going to `Help > Save System Info`. Drag the resulting file into the comment box and it'll be attached.
Author
Sure. Thanks for your time. I've never come to the forums before
system-info.txt
> In #89389#1181613, @chemicalcrux wrote: > Can you attach system information? You can save it from blender by going to `Help > Save System Info`. Drag the resulting file into the comment box and it'll be attached. Sure. Thanks for your time. I've never come to the forums before [system-info.txt](https://archive.blender.org/developer/F10191300/system-info.txt)
Member
Member
Member
@jvemedia ,plenty of add-ons are enabled, disabling them may help you. So try again with default settings (File -> Defaults -> Load Factory Settings)
Attach .blend file if default settings does not fix the problem
@jvemedia ,plenty of add-ons are enabled, disabling them may help you. So try again with default settings (`File -> Defaults -> Load Factory Settings`) Attach .blend file if default settings does not fix the problem
Author
No dice still. Uploading my blend file. default7-5.blend
> In #89389#1187051, @PratikPB2123 wrote: > @jvemedia ,plenty of add-ons are enabled, disabling them may help you. So try again with default settings (`File -> Defaults -> Load Factory Settings`) > > Attach .blend file if default settings does not fix the problem No dice still. Uploading my blend file. [default7-5.blend](https://archive.blender.org/developer/F10212214/default7-5.blend)
Member
@jvemedia , thanks for the file. Time to load the kernel can be high but what exactly it results in? does it freeze or crash?
Author
Thanks for your help. If I press render it does just says loading indefinitely. If I try to cancel the render, or say I'm in viewport, when I switch back solid mode, blender as a whole freezes.
> In #89389#1187380, @PratikPB2123 wrote: > @jvemedia , thanks for the file. Time to load the kernel can be high but what exactly it results in? does it freeze or crash? Thanks for your help. If I press render it does just says loading indefinitely. If I try to cancel the render, or say I'm in viewport, when I switch back solid mode, blender as a whole freezes.
Member
@jvemedia , thanks for clarification.
Not sure but upgrading to recent version may help you: https://builder.blender.org/download/daily/
@jvemedia , thanks for clarification. Not sure but upgrading to recent version may help you: https://builder.blender.org/download/daily/
Member
This comment was removed by @PratikPB2123
*This comment was removed by @PratikPB2123*
Member
Added subscriber: @STANN.co
Member
Added subscribers: @TheCharacterhero-4, @Alaska
Member
Added subscriber: @deadpin
Member
Looking at the Jesse's comment #88800#1181651 I think the present behavior is expected.
@deadpin , anything you want to mention here. Think it will take a fare amount of time for compilation on very first time,
Same happens on AMD GPU with OpenCL (at least for me) when using GPU compute device.
Looking at the Jesse's comment #88800#1181651 I think the present behavior is expected. @deadpin , anything you want to mention here. Think it will take a fare amount of time for compilation on very first time, Same happens on AMD GPU with OpenCL (at least for me) when using GPU compute device.
I downloaded the new Nvidia 471.68 Studio driver. Now even on version 2.92 Rendering stopped working. I put back 471.41, but it stopped working there too. Even at 2.83.17 it does not work. YouTube
I downloaded the new Nvidia 471.68 Studio driver. Now even on version 2.92 Rendering stopped working. I put back 471.41, but it stopped working there too. Even at 2.83.17 it does not work. [YouTube ](https://youtu.be/aY2a3-akui0)
Works in Blender 3.0. Thanks to this patch:
https://developer.blender.org/rB08031197250aeecbaca3803254e6f25b8c7b7b37
In Blender 2.93.5 does not work.
Works in Blender 3.0. Thanks to this patch: https://developer.blender.org/rB08031197250aeecbaca3803254e6f25b8c7b7b37 In Blender 2.93.5 does not work.
Contributor
Added subscriber: @Raimund58
Contributor
Contributor
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
6 Participants
Reference: blender/blender#89389
