IVY changes #89511
Closed
opened 2021-06-28 15:13:13 +02:00 by CJ L · 6 comments
Changes for ivy usability.
Old: you had to do the right ivy at the 1st time. If you select other object, all your changes are lost and you got to restart till the beginning. This made the tool boring and useless ( too sensible to mis-click )
New: you can create multiple ivys in the same scene and come back selecting the branches to edit them from the step you were when clicking elsewhere.
Also you can use collections full of leaves instead of common square leaves. If collection prop is not filled, old square leaves are used.
Note i'm totally noob at python dev ! so it would be great a real python dev take a peek in the code to make it less shitty ;)
Hope you like it :)
Happy blending !
add_curve_ivygen.py
Changes for ivy usability. Old: you had to do the right ivy at the 1st time. If you select other object, all your changes are lost and you got to restart till the beginning. This made the tool boring and useless ( too sensible to mis-click ) New: you can create multiple ivys in the same scene and come back selecting the branches to edit them from the step you were when clicking elsewhere. Also you can use collections full of leaves instead of common square leaves. If collection prop is not filled, old square leaves are used. Note i'm totally noob at python dev ! so it would be great a real python dev take a peek in the code to make it less shitty ;) Hope you like it :) Happy blending ! [add_curve_ivygen.py](https://archive.blender.org/developer/F10204762/add_curve_ivygen.py)
CJ L self-assigned this 2021-06-28 15:13:13 +02:00
Author
Added subscriber: @pitibonom
Member
Member
Thanks for working on an add-on.
Did you discuss the changes with developers before creating the ticket?
Also: Submit the diff file for contributing the code.
To contribute blender, refer Contributing code wiki for contributing process.
Thanks for working on an add-on. Did you discuss the changes with developers before creating the ticket? Also: Submit the diff file for contributing the code. To contribute blender, refer [Contributing code ](https://wiki.blender.org/wiki/Process/Contributing_Code) wiki for contributing process.
Member
Author
Hi :)
no i did only discuss with people from BA forum. I don't know who are de devs of this addon nor where to get in touch with them...
I changed this addon for my needs and thought it could be usefull to the community ;)
Sorry for my 'noobiness', this is the first time i share some code on developper.blender.org
I'll try to make a diff file and submit it here :)
Hi :) no i did only discuss with people from BA forum. I don't know who are de devs of this addon nor where to get in touch with them... I changed this addon for my needs and thought it could be usefull to the community ;) Sorry for my 'noobiness', this is the first time i share some code on developper.blender.org I'll try to make a diff file and submit it here :)
Member
it could be useful to the community ;)
Then I would also suggest to create a post on devtalk: https://devtalk.blender.org/
> it could be useful to the community ;) Then I would also suggest to create a post on devtalk: https://devtalk.blender.org/
2 Participants
Reference: blender/blender-addons#89511
