Cycles Render - Textures Disappear then Crashes the Render #89747
6 Participants
Reference: blender/blender#89747
Broken: 2.93
Broken: 3.1
Broken: 3.2
If I render this scene, the textures eventually start disappearing and turning pink then it crashes.
At first it renders the output just fine but eventually textures start disappearing then it crashes
Render the blend file above as an animation and it should start producing errors and crash at around frame 240.
ErrorTestRoom_Smallester.rar
One thing I noticed was this in the console (on every frame):
That message is the same as in #95651 (GPU error (Invalid graphics context in cuGraphicsUnregisterResource)), these might have the same underlying root cause, guess #render_cycles devs will need to check that
Then on the last frames rendered I get this:
Original report
Blend File and Textures Here (650MB)
How it's supposed to render
In the last few frames it renders with glitched out textures:
https://i.imgur.com/vNoCk39.png
https://i.imgur.com/fj1tqif.png
https://i.imgur.com/xKdk8vA.png
https://i.imgur.com/ErTXneV.png
Then it crashes.
Full render output here
Smaller File Size:
Smaller size file sample (180MB)
Even with less textures the error still happens.
This is how the render is supposed to look
Then last few frames it renders:
https://i.imgur.com/X3nhTh5.png
https://i.imgur.com/4UFJUYH.png
https://i.imgur.com/8v5Fvgc.png
https://i.imgur.com/LTfk5hY.png
Even more smaller rar file samples:
74MB
28MB
13MB
I won't repeat the description above, essentially same results even with less and less textures involved in the blend file. First 2 crash in the 80-90 frame range, smallest (13MB) crashes at around frame 130. No errors occur when there are no textures.
Render the blend file above as an animation and it should start producing errors and crash at around frame 80-90.
Extra Notes
I've tried both OPTIX and CUDA and GPU only and GPU+CPU rendering and it produces the same error. CPU only rendering produces same error.
Rendering the blend in 2.92 produces the same error.
This does not happen when rendered in Eevee.
If I start the render in the frames that it glitches out on it renders the frame without error.
Rendering with "Persistent Data" option on fixes the issue but I'm not sure if it's a real fix.
Added subscriber: @Fuegonasus
Added subscriber: @iss
Thank you for report, but provided sample file is very big. Please simplify it as much as possible by removing objects not needed to reproduce the issue.
It used to be a lot bigger because I thought reducing the number of objects and textures would fix the issue but it didn't. I will try to make it smaller and update the report.
I am unable to reproduce this issue.
Please upload sample fle directly to this site. Does this issue happen when you render with CPU only? I can't check GPU rendering.
Added a smaller size.
Uploaded the smallest file to the site. Haven't tried CPU only, will try it the next time I can.
CPU only rendering produces the same error.
Added subscriber: @lichtwerk
Sorry this has slipped under the radar for so long.
I have given
(some textures are missing here, but I assume this is intentional?) a try in 3.2:This rendered 243 frames, then indeed crashed (GPU memory and system memory consumption was pretty much stable throughout)
Added subscriber: @juang3d
This seems to be the same error I reported here:
https://developer.blender.org/T95651
The example scene I have there is way smaller.
I suspect is related to the Nvidia driver version, with 510 on Linux and 511 on windows this happens, but I had no opportunity to test it with older drivers
P.S.: sorry you already mentioned it, I missed that, I’m on the phone
We now have #95837 (Regression: GPU memory accumulation in Cycles render) with the same error message. Not sure if this is exactly the same, but I've made that one High priority (since it also shows that memory is not freed on the GPU)
Strange thing in this report is that I think I watched GPU memory (and I think it was stable...)
This issue was referenced by
e4b7d52fe4
