Immediate quit on started render with AO, Mist layers & denoising #89775
5 Participants
Reference: blender/blender#89775
Operating system: macOS-11.4-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 575 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.5.14
Broken: version: 3.0.0 Alpha, branch: cycles-x, commit date: 2021-07-09 16:01, hash:
9aa5aeee46
Worked: ( version: 3.0.0 Alpha, branch: cycles-x, commit date: 2021-07-05 15:23, hash:
048a515ef428
)(happens in master, too)
This apparently regressed in
0153e99780
[Open up scene and hit render button results in quitting immediately. Mist, AO layers + denoising in compositing used. Works in previous version (see above) except of cause for the AO layer]
[Open the blend file and hit the render button, and it will quit. Not so in previous blender version/s. Mac Crashlog attached.]
Blender_2021-07-10-131627_Quad.crash
distributor_06b.blend1
Thanks in advance
SG
Added subscriber: @Nurb2Kea
@Nurb2Kea ,thanks for the report. the tracker is yet not open for cycles-x bug reports. Branch is under development so sometimes unknown issue may occur.
I will close the task. Please reopen the ticket if you can reproduce the problem with the build from master branch :)
That's not very helpful for me and blender development either!!
I send you this file to look through, to find the problem to fix it. It's not in my scene, it's in the development.
The las two bug reports got fixed right away, because they looked into it. And was the same file!
THAT'S the REASON for A BUGREPORT to be reviewed !
Thanks in advance
SG
Changed status from 'Archived' to: 'Needs Triage'
Can confirm with 3.0.0 (
2289e26fa3
)I consider the problem appears on Cycles-X branch (as mentioned in the task description).
Will make sure what exactly the cause is before confirming the report
Added subscriber: @lichtwerk
Unsure what the tag would be. @lichtwerk can you please confirm? :)
Can confirm, will check further...
note: even when still good (prior to
0153e99780
), I got the following (not sure this is related):When bad I get a segmentation fault, but having trouble debugging this further (apparently my system [on fedora rawhide atm] cannot fetch debug info for Clang/LLVM...)
0153e99780
@JacquesLucke : mind checking?
This issue was referenced by
8e69409eed
Issue still continues with Blender 3.0.0 - cycles-x
July 13, 05:19:22 - cycles-x - 8988fcc49436 - Intel Release !
Start the blend file, send in the first bug report, and hit render !
Thanks in advance
SG
