Can't use add texture setup ( CTRL + T ) #89892
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#89892
Graphics card: NVIDIA GeForce 840M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.11
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash:
blender/blender@1b8d33b18c
Addon Information
Name: Node Wrangler (3, 38)
Author: Bartek Skorupa, Greg Zaal, Sebastian Koenig, Christian Brinkmann, Florian Meyer
[Even though i've turned on the node wrangler, CTRL + T or Shift +W - Add Texture setup does not work ]
Added subscriber: @cactomji
Anyone has solution for this problem ?
Don't think this is a bug or so. Select a shader node then use the key
CTRL + T
to add the texture setup. Otherwise it will not work.Closing the report since this is not a issue. Feel free to reopen and comment if problem is not fixed :)
Also, refer: https://docs.blender.org/manual/en/latest/addons/node/node_wrangler.html#add-texture-setup
Oh thx, i realize that i hadn't select any shader nodes before using that feature
