Regression: Pen tablet navigation and continuous drag produces eternal rotation #89928
Closed
opened 2021-07-18 02:12:21 +02:00 by Vyacheslav Kobozev · 24 comments
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.47
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash: 1b8d33b18c
Worked: 2.79
As title says.
2021-07-18_03-05-01.mp4
2.79 just disable continuous drag for pen and all work fine. And this what I expect from pen with absolute cordinates.
2021-07-18_03-10-52.mp4
**System Information** Operating system: Windows-8.1-6.3.9600-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.47 **Blender Version** Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash: `1b8d33b18c` Worked: 2.79 **Short description of error** As title says. [2021-07-18_03-05-01.mp4](https://archive.blender.org/developer/F10226878/2021-07-18_03-05-01.mp4) 2.79 just disable continuous drag for pen and all work fine. And this what I expect from pen with absolute cordinates. [2021-07-18_03-10-52.mp4](https://archive.blender.org/developer/F10226883/2021-07-18_03-10-52.mp4)
Added subscriber: @Vyach
Added subscribers: @PratikPB2123, @lichtwerk
This comment was removed by @Vyach
*This comment was removed by @Vyach*
Removed subscribers: @lichtwerk, @PratikPB2123, @Vyach
Member
Member
Hi @Vyach , does the issue happen with 2.93.2 and not in 3.0.0? In that case you can reopen the ticket.
I don't have similar system to test the issue, may be Philipp Oeser has the wacom tablet.
Hi @Vyach , does the issue happen with 2.93.2 and not in 3.0.0? In that case you can reopen the ticket. I don't have similar system to test the issue, may be Philipp Oeser has the wacom tablet.
@PratikPB2123 Yes, correct. Please reopen. Still not fixed for 2.93.2
Also I made new report for walk navigation. May be it is related too #90491 (Walk navigation with pen tablet fails in 2.93.2 (continous rotation))
@PratikPB2123 Yes, correct. Please reopen. Still not fixed for 2.93.2 Also I made new report for walk navigation. May be it is related too #90491 (Walk navigation with pen tablet fails in 2.93.2 (continous rotation))
Member
Changed status from 'Archived' to: 'Needs Triage'
Member
Added subscriber: @PrototypeNM1
Member
Hi @PrototypeNM1 , can you replicate the issue on 2.93.2?
#90491 won't be related as walk navigation uses a different mechanism.
Continuous grab is disabled if an operator starts while a tablet is present. I'd bet to trigger this 1. the pen must not be in range of the tablet when the operator starts (e.g. when g is pressed) and 2. the tablet API is set to Automatic or Wintab. This issue wouldn't be present in 3.0 due to the Wintab rewrite.
#90491 won't be related as walk navigation uses a different mechanism. Continuous grab is disabled if an operator starts while a tablet is present. I'd bet to trigger this 1. the pen must not be in range of the tablet when the operator starts (e.g. when `g` is pressed) and 2. the tablet API is set to Automatic or Wintab. This issue wouldn't be present in 3.0 due to the Wintab rewrite.
Member
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Member
Not sure how to proceed here.
@PrototypeNM1 : do you think there is a chance of isolation some commit from the Wintab rewrite that could still fix this in 2.93 LTS?
Not sure how to proceed here. @PrototypeNM1 : do you think there is a chance of isolation some commit from the Wintab rewrite that could still fix this in 2.93 LTS?
oh, here this old report. Still actual sadly
@Vyach Could you check if the issue occurs if the pen is in range of the tablet before grabbing/rotating?
Tablet have absolute cordinates, so if mouse curson in the range of screen, it means the pen in the range of tablet.
An yes, it is. In the rangeof drawing area and in height range too
(I hope, I understand your question correct)
For me, as a user, it loks like issue appears just because pen continuously set same position of cursor but blender tries to set another one (as for mouse, on the other side of viewport).
in "mouse mode" (relative cordinates) for tablet there is no bug.
2021-11-07_06-47-59.mp4
Also ask Simon Tommes, he had same issue on the stream (with pizza) and i suppose, he use touchpad or pen.
> In #89928#1249333, @PrototypeNM1 wrote: > @Vyach Could you check if the issue occurs if the pen is in range of the tablet before grabbing/rotating? Tablet have absolute cordinates, so if mouse curson in the range of screen, it means the pen in the range of tablet. An yes, it is. In the rangeof drawing area and in height range too (I hope, I understand your question correct) For me, as a user, it loks like issue appears just because pen continuously set same position of cursor but blender tries to set another one (as for mouse, on the other side of viewport). in "mouse mode" (relative cordinates) for tablet there is no bug. [2021-11-07_06-47-59.mp4](https://archive.blender.org/developer/F11755616/2021-11-07_06-47-59.mp4) Also ask Simon Tommes, he had same issue on the stream (with pizza) and i suppose, he use touchpad or pen.
Added subscriber: @lichtwerk
@lichtwerk to fix this window->m_tabletInRange would need to be updated during WT_PROXIMITY (2.93) events. You can reference the changes in 3.0 for in vs out of range. Note that 2.93's WT_CRSCHANGE falls through to WT_PROXIMITY, so the two would need to be decoupled or the WT_PROXIMITY handling moved before the fall through.
Because of changes in 3.0 this issue shouldn't be present.
@lichtwerk to fix this `window->m_tabletInRange` would need to be updated during [WT_PROXIMITY (2.93)](https:*developer.blender.org/diffusion/B/browse/blender-v2.93-release/intern/ghost/intern/GHOST_SystemWin32.cpp$1471) events. You can reference the [changes in 3.0](https:*developer.blender.org/diffusion/B/browse/master/intern/ghost/intern/GHOST_SystemWin32.cpp$1606) for in vs out of range. Note that 2.93's WT_CRSCHANGE falls through to WT_PROXIMITY, so the two would need to be decoupled or the WT_PROXIMITY handling moved before the fall through. Because of changes in 3.0 this issue shouldn't be present.
Member
Added subscriber: @JulienKaspar
Member
I can't reproduce this issue anymore in master. Is this still an issue or can this be closed?
@JulienKaspar
Also not reproducible for me in:
3.3.0 Beta, c9a996790307, 2022-08-19 20:22
3.4.0 Alpha, branch: master, commit date: 2022-08-20 00:16, hash: acf083a5bf
So can be closed
@JulienKaspar Also not reproducible for me in: 3.3.0 Beta, `c9a996790307`, 2022-08-19 20:22 3.4.0 Alpha, branch: master, commit date: 2022-08-20 00:16, hash: `acf083a5bf` So can be closed
Member
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
Pratik Borhade self-assigned this 2022-08-24 08:12:51 +02:00
Pratik Borhade removed their assignment 2022-08-24 08:13:01 +02:00
5 Participants
Reference: blender/blender#89928
