Fix RNA_property_pointer_get creating data in non-thread-safe way. #90170
Closed
opened 2021-07-26 15:47:14 +02:00 by Bastien Montagne · 5 comments
Current RNA_property_pointer_get code creates the data if missing in IDProperty case (see rna_acces.c). With a comment that is is very bad to create data in accessor code...
This comes from initial twelve years old commit (4fb19159ea) and was never addressed since then.
This is currently causing memleaks in liboverride diffing code, which is parallelized on the ID level. The problem shows up when you have several overrides of the same linked ID, then diffing code can access concurrently to the same linked ID and generate IDProperty several time for the same entry.
I can think of several ways to solve this issue:
  • Add a lock (mutex, spinlock...) protection that specific bad piece of code.
  • Never generate IDproperty data for linked IDs (since it won't be saved in any case).
  • Try to actually fix that bad code - not sure what would be the implications of not silently generating those IDProperty data on access though... Have the feeling this could be quite API-disruptive?
Current `RNA_property_pointer_get` code creates the data if missing in IDProperty case (see `rna_acces.c`). With a comment that is is very bad to create data in accessor code... This comes from initial twelve years old commit (4fb19159ea) and was never addressed since then. This is currently causing memleaks in liboverride diffing code, which is parallelized on the ID level. The problem shows up when you have several overrides of the same linked ID, then diffing code can access concurrently to the same linked ID and generate IDProperty several time for the same entry. ------------------------------ I can think of several ways to solve this issue: - Add a lock (mutex, spinlock...) protection that specific bad piece of code. - Never generate IDproperty data for linked IDs (since it won't be saved in any case). - Try to actually fix that bad code - not sure what would be the implications of not silently generating those IDProperty data on access though... Have the feeling this could be quite API-disruptive?
Author
Owner
Author
Owner
Added subscribers: @mont29, @brecht
I suggest to just add a mutex lock. It's difficult to work around at this point.
The issue is that if you have some nested properties, like scene.cycles.samples, it would be nice if we could only allocate the cycles ID property group when one if its properties is set for the first time. But I can't think of a practical way to create an RNA pointer to scene.cycles when it does not exist yet, without adding a lot of complexity.
For the library diffing code specifically, it could perhaps not enter into that struct when it has not been allocated, but doesn't solve the potential issue in other cases.
I suggest to just add a mutex lock. It's difficult to work around at this point. The issue is that if you have some nested properties, like `scene.cycles.samples`, it would be nice if we could only allocate the `cycles` ID property group when one if its properties is set for the first time. But I can't think of a practical way to create an RNA pointer to `scene.cycles` when it does not exist yet, without adding a lot of complexity. For the library diffing code specifically, it could perhaps not enter into that struct when it has not been allocated, but doesn't solve the potential issue in other cases.
This issue was referenced by 317f09ebf9
This issue was referenced by 317f09ebf990ab4a5d033bab61a0aa8816772615
Author
Owner
Bastien Montagne self-assigned this 2021-08-05 12:15:41 +02:00
Thomas Dinges added this to the 3.0 milestone 2023-02-08 15:59:05 +01:00
Reference: blender/blender#90170
