Can't download example file in Chrome - Mixed content blocked due to http URL #90251
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
6 Participants
Reference: blender/blender-manual#90251
Pagename:
modeling/modifiers/modify/normal_edit
Blender Version:
2.92
Documentation Language:
en
Permanent link
The linked example file at http://download.blender.org/ftp/mont29/persistent_data/sapling_CN.blend cannot be downloaded in Chrome as the URL uses http instead of https.
Added subscriber: @JohnLo
Added subscriber: @TusharAnand
@JohnLo , thanks for the report. Not sure what does that mean.
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
Removed subscriber: @TusharAnand
Added subscriber: @ankitm
Changed status from 'Archived' to: 'Needs User Info'
Very likely the link given under the image in [1]
The link is - [x] and it can be downloaded in Firefox (at least) here.
@JohnLo what response do you get in the browser ?
Added subscriber: @rjg
@ankitm It doesn't work in Chrome, unless opened in a new tab. The issue is that
http:
instead ofhttps:
is used.Changing the URL to
https:
resolves the issue.example blender file does not existto Can't download example file in Chrome - Mixed content blocked due to http URLChanged status from 'Needs User Info' to: 'Confirmed'
This issue was referenced by 8266
