How to use & transition to std::filesystem? #90379
5 Participants
Reference: blender/blender#90379
Motivation
C++17 introduces the
std::filesystem
library which contains plenty of useful functionality. Operating system specific handling is abstracted away into a standard library, there are very useful and carefully designed types & functions to interact with. For example it introduces a properpath
object type that is way more convenient and secure to use than the C-string manipulation we do in Blender currently.It would be great to be able to use this as it would make file system interaction much easier, better tested/maintained, better designed (arguably ;) ), better documented and actually standardized (hence more familiar for devs coming from other C++ software). Sybren and I would like to use it ASAP for asset system related code.
Platform Compatibility
According to the [C++17 compiler support overview ]] we can't use
std::filesystem
with our current minimum requirements. We'd need to drop macOS 10.13 and 10.14 and possibly Visual Studio versions until 2017 15.7 (current minimum version [ https:*wiki.blender.org/wiki/Building_Blender#Compiler_Versions | only states 2017 ).Notes:
Conclusion: We may be able to update our requirements before too long, but as of now it's too early. In other words, we can't use
std::filesystem
yet.std::filesystem vs. BLI functions
We have other options than using
std::filesystem
directly. But there's another discussion point:Blender already has library functions for file system and path handling, all written in C in BLI. Concerns were raised about using
std::filesystem
while the BLI APIs also exist with entirely different implementations. Porting the API would probably take quite some effort & time, and could cause dangerous regressions.Proposal
Short proposal:
std::filesystem
compatible implementation of the API: https://github.com/gulrak/filesystemWe could change the BLI API designs a bit, e.g. rather than passing paths as character arrays, have an opaque path handle that uses
ghc::filesystem::path
internally. Path operations would have to be done through the API then (which may have to be extended a bit). Generally we should aim for getting the API as close as possible tostd::filesystem
.Added subscriber: @JulianEisel
How to use & transition to `std::filesystem`?to How to use & transition to std::filesystem?Added subscriber: @dr.sybren
As an avid user of Python's pathlib module, I'm strongly in favour of this proposal. IMO we should move forward with this, unless there are concrete, technical issues that first needs resolving.
Added subscriber: @ankitm
Proposal 2
This has a high cost in terms of download/ space/ system configuration, but the pro is that we get
std::filesystem
right away!Use LLVM toolchain on every mac dev station.
I have been using the same for over a year now and Blender compiles fine, runs fine, and there's leak sanitizer which Apple toolchain doesn't have for the same compiler version.
We'd need to ship some additional dylibs but that has become easier after D11997 :)
Also, some
#define
s would be needed before including filesystem header to turn off platform symbol availability checks.Proposal 3
The argument against
boost::filesystem
was that third party libs shouldn't be used for core features.. butghc
seems fine for that.. how so?Added subscriber: @LazyDodo
ghc is header only and small enough to host inside
/extern
, so we can rely on it being available, while putting boost in there be undesirable due to its size and somewhat strange buildsystem.I'm not sure if the argument is really that 3rd party libs shouldn't be used for core features. I think it's more about boost specifically, for which consensus seems to be that we want to move away from it. Also, making boost a hard requirement (if it's not shipped in
extern/
) is rather problematic.@JulianEisel only downside I see in ghc; it relies on system headers (ie
Windows.h
) so i'd use it very cautiously, ie using it in an implementation cpp of assetbrowser is fine, using its types inside a very common blenlib/kernel header would be problematic both in terms ofWindows.h
doing some wonky stuff (like defining mix/max macro's that'll collide with stl's versions of them) and longer build times.Changed status from 'Needs Triage' to: 'Confirmed'
The GHC readme says:
So I'd say we just create a wrapper header,
BLI_filesystem.h
or so and defineWIN32_LEAN_AND_MEAN
,NOMINMAX
,NOGDI
,NOCOMM
, etc. in there. That also makes access easier, since you don't have to edit the local cmake file to includeextern/ghc
(or whatever it will be called), as long as BLI is included.Just confirmed one suspicion:
std::filesystem::path
usesstd::basic_string
internally (at least in theghc
implementation). But that means every time we construct a path from achar *
, there is a heap allocation (except when there is short string optimization of course, but paths are typically longer).Not sure if this is a deal breaker for using
std::filepath
(or equivalent) internally for the BLI functions. As long as these functions are sparingly used in performance sensitive areas it should be fine - and I guess this applies to file system operations generally anyway.There is still the option to have an opaque path handle to pass around in C, this would just require quite a bit more work.
That could work, but you'll have to undefine them afterwards otherwise it''ll cause issues when other code tries to make those same defines, the only way to do this with a minimum amount of warnings is the ugliness we have in
bli_task_hh
I did some initial work in D12117: Initial work for std::filesystem transition. Would appreciate some feedback there.
Using Gulrak/Filesystem seems pretty uncontroversial at this point.
Main question to move forward seems to be how to handle the BLI stuff: Is it fine to just introduce the filesystem library (as
bli::filesystem
) and use that for new C++ code? That is, planning to either transition the BLI APIs to usefilesystem
internally, or porting code using the API to C++ andbli::filesystem
directly.I think we use the the
blender::
namespace instead ofbli::
.In my opinion it's easier to use the new API in one place at a time, rather than refactoring parts of the existing API. Easier to test and the transition would probably be less messy? Just my 2 cents though.
D12210: Use LLVM toolchain to get std::filesystem
NVM
Quick update here, basically things are difficult...
Sybren and I were using Gulrak/Filesystem for asset stuff, and had too many cross platform issues with character encoding to justify sticking to it. It's like, 9.5 times out of 10, using paths would result in a failing unicode test on some platform (usually Windows since we were on Linux) and it still wasn't clear how to use the API to avoid that. That's fine if stuff is unit tested carefully, but we can't rely on that*that// much.
It's unclear if this would get any better with
std::filesystem
. While Gulrak/Filesystem by default interprets everything as UTF-8 encoded,std::filesystem
does not. Needs testing.However, another issue that worries me a bit is, Blender has different path semantics than
std::filesystem
. Namely the//
prefix we use would be interpreted differently and be another possible source of bugs.std::filesystem::path
is careful in its rules on how to interpret strings as paths (e.g. to identify a root name likeC:
), in Blender things are all over the place. This just makes transitioning even harder.So for the time being, I'd say let's not use
std::filesystem
. Some more experiments might be useful, but I'll put this task on ice for now.I think it would be good to have a
blender::filesystem
then, which would behave the way it should behave. It can then be left as an implementation detail whether it just detects the special cases and delegates the rest tostd::filesystem
or implements everything itself.
