Nodes Not Connecting 2.93.2 #90478
Reference: blender/blender#90478
Graphics card: GeForce GTX 1660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.93.2, branch: master, commit date: 2021-08-03 05:58, hash:
1eb06de260
Nodes not connecting in the Shader Graph and Compositor - only sometimes but looks like the panel is stuck in a selection or active as move. 293.2.mp4
NodesNotConnecting.blend
trying to connect any node to another. in the shader graph.
Added subscriber: @Sterling-Osment
Can not reproduce this on current master
6188c29603
May be loading the factory settings will fix the issue. (
File -> Defaults -> Load Factory Settings
)Added subscriber: @APEC
Can't reproduce, even with your file. I assume something with yours keyconfig was changed
Nodes_Connection.mp4
Ok thanks - if I load factory settings, will I lose my current setup ? Sorry I don’t want to disturb my other install of 2.92 for production.
Load Factory Settings, without backup your current, highly undesirable.
It's better to have a blender lower or higher version instead for this cases.
Loading the factory setting will open a new default scene with all factory preferences.
But reloading any other scene will cause the same problem again.
Instead, load factory preferences from
Edit -> Preferences
tab and save the preferences.May be this will help you
Ok thanks very much for your prompt reply, I will check it out and let you know.
ok, tested.
Load Factory Settings do not mess your configs if you do not manually save it.
So after close without saving and opening blender it loading your old configs.
Thanks for your help.. yes it’s the hot keys that are causing this issue.
Will close then. Thanks again for the report.
