Modeling > Geometry Nodes > Utilities Nodes > Map Range Node - Corrections #90506
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#90506
Pagename:
modeling/geometry_nodes/utilities/map_range
Blender Version:
2.93
Documentation Language:
en
Permanent link
"By default, values outside the specified input range will be proportionally mapped as well."
should be:
"By default, Result is clamped to the target range [To Min, To Max]."
(By default "Clamp" is checked.)
Properties
"Interpolation Type" is undocumented.
It is documented in Attribute Map Range .
It implies documenting the "Steps" input too.
Maybe the following paragraph should be removed, as it relates to Compositing nodes rather than Geometry nodes:
"Usage
One important use case is to easily map the original range of the Z-depth channel to a more usable range (i.e: 0.0 - 1.0) for use as a matte for colorization or filtering operations."
Added subscriber: @Denis_NICOLAS
I can confirm.
Not sure if this is required.
This issue was referenced by 8441
