Case-insensitivity of catalog IDs #90541
Closed
opened 2021-08-09 13:09:29 +02:00 by Sybren A. Stüvel · 13 comments
Catalog IDs are intended to be simple, human-readable identifiers for a node in the catalog tree. For simpicity I think it's a good idea to have these case-insensitive.
A few options for technical implementations:
  • Always store catalog IDs as input by the user (and compare both sides of a comparison to lower case every time), or
  • always store catalog IDs as lower/upper case (and thus always compare the same case without having to do lowercasing every time).
I'm in favour of the first one, as that gives the most flexibility to artists.
Catalog IDs are intended to be simple, human-readable identifiers for a node in the catalog tree. For simpicity I think it's a good idea to have these case-insensitive. A few options for technical implementations: - Always store catalog IDs as input by the user (and compare both sides of a comparison to lower case every time), or - always store catalog IDs as lower/upper case (and thus always compare the same case without having to do lowercasing every time). I'm in favour of the first one, as that gives the most flexibility to artists.
Author
Member
Author
Member
Added subscriber: @dr.sybren
Added subscriber: @antoniov
As a Windows user, for me is more logic the Case Insensitivity. I know in Linux case matters, but in windows don't.
Author
Member
@antoniov You make a good point. In Windows you can't reliably change the case of a filename (so thename.txtTheName.txt); it might error out saying "This file already exists". This is something I want to avoid. My perspective on this is that people are intrinsically case-sensitive, they just don't want to care about it.
@antoniov You make a good point. In Windows you can't reliably change the case of a filename (so `thename.txt` → `TheName.txt`); it might error out saying "This file already exists". This is something I want to avoid. My perspective on this is that people are intrinsically case-sensitive, they just don't want to care about it.
Member
Added subscriber: @Jeroen-Bakker
Member
I would keep the casing to what the user entered. This will keep it readable when using pascal casing for example. And just convert to one casing when checking.
Member
Member
The catalog name that is displayed in the UI should use whatever case the user entered. E.g. entering "AbC DeF" should display the exact same way. When renaming it to "Abc Def" that should just work.
For comparisons and for writing the CATALOG_ID to the catalog definition files, it can just be converted to a lower-case format, e.g. abc-def. Or at least the case shouldn't matter for internal logic.
The catalog name that is displayed in the UI should use whatever case the user entered. E.g. entering "AbC DeF" should display the exact same way. When renaming it to "Abc Def" that should just work. For comparisons and for writing the `CATALOG_ID` to the catalog definition files, it can just be converted to a lower-case format, e.g. `abc-def`. Or at least the case shouldn't matter for internal logic.
I agree to keep case typed by user... I'm talking only internally for checking.
Maybe is something that never happens in these programming languages, but I had in the past some problems changing/comparing case in databases with different languages (character sets)...specially when using non Western Languages. I mean, for example, saving a catalog in a Russian system and open it in a Spanish one. I write this note to be sure we test that.
Member
Member
Closing this now, since it's become obsolete with #91378 (Use UUIDs for Catalog IDs).
Reference: blender/blender#90541
